Question about Drills
Metabo ics 10 charger
What does it mean when the "Defective" light flikers?
How do i fix drill machine battery charger
Many chargers have a fuse in them .take the bottom off and look for one .
Dec 07, 2015 | Metabo Asc30 Lithium-ion Battery Charger...
Ic-v85 battery wont charge
battery pack already exhausted or your charger is defective, check your charger by using voltmeter, if there is voltage output more than your battery voltage that means your battery needs replacement.
Apr 23, 2013 | ICOM Informatique Radio Communications
Batterys dont charge
Very rarely will you come across 2 bad batteries in a kit. If you have 2 batteries that will not take a charge and they are from the same kit. The common denomiater would be the charger. I would look into that. when some chargers fail the lights still work but the charger does not actually charge. If posible double check the same batteries with a different charger.
Aug 29, 2012 | Metabo BSP15.6PLUS 15.6 Volt Cordless...
Charging light does not go off
unppluget the base, and put contacts cleaner in the contacts charger buy it from radio shack or computer, and wait by 30 minutes.
2) try again, if work is o.k
3) if doesnot resolve the problem, the IC charger in power supply is defective repair go to the repair shop for fix it.
God bless you
Jul 21, 2012 | Clarity D613 Cordless Phone
Metabo we 14-150 runs then red light comes on and cuts out
this means the grinder is being over worked and is in the overheat protection mode. when this happens let the grinder continue to run at no load. just hold it and in about 20-30sec you will see the red light turn off and the grinder will go back up to speed. and you can get back to it.
Jan 30, 2012 | Metabo Saws
What is the frame output ic
Hello
Frame output IC means nothing, but the VERTICAL OUTPUT IC. Every TV will have it, which will scan picture vertically at 50 or 60 Hz. [1 HZ means one frame per second. Normally TVs will have 50Hz, 60Hz and 100Hz vertical frequency]. As vertical frequency rat increases, the picture fliker wil decrease. High level high-cost TVs will have 100Hz or even more frequency will be used for vetical scanning.
In the case of computer monitors, the vertical frequency will vary from 60Hz to 120hz. You can see its picture stability, at this high frequency.
The IC [Integrated Circuit Chip], which generates the vertical frequency and outputs it called the vertical output [frame output] IC. OK
Wish you a Proseperous and Happy 2012.
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 29, 2011 | Televison & Video
Charger model FY 4101 green light stay lite all the time, and hoveround battery is still dead
When the green light stays on regardless of dead battery, this means the battery is defective. The battery must present a load to the charger, which causes the charger voltage to drop, turning the charger on. When the battery is defective, it will not load the charger, and the charger voltage stays at full charge value. This of course, causes the green light to be switched on.
Sep 16, 2010 | Electronics - Others
I need a battery for a metabo sb impuls hammer dril and charger drill perfect working order battery and charger lost in mooving house. has on bottom of drill were battery conects pa6-gf30 can you still get...
I saw them in the latest Metabo leaflet. They are serious producer and they shoudl keep spare parts for few years after they discontinue some product. Try to call to Metabo in your country. Juraj
Jun 03, 2010 | Metabo Drills
I have a metabo battery charger c45 & it allways flashes red even when I put a battery in it! Can u help?
If it is flashing red without a battery installed, there is problem on the circuit board. It will best to replace the charger as repair componants are not available.
If it is only flashing when a battery is installed, it may be a bad battery.
Jul 05, 2009 | Metabo Drills
Metabo 18V cordless drill lithiom ion batteries not taking charge
Some batteries develop 'memory'. Run the batteries down until they are completely dead, then recharge them fully. Do this a couple times to get them back to normal.
Jul 02, 2009 | Metabo 685009520 COMBO 4.1 18V Cordless...
Drills Logo
124 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
