Question about Clothing
Ck7749s hello I need a part for sunglasses it is a long gold part length about 2,5cm is located on the end of the handle, can be seen when you want to bend sunglasses
Video on how to fix driver side door linkage on 2010 cad escalaid
On most cars the rods will only fit in one location due to the way they are bent and the length of each rod. In other words, if you put one end in the wrong location, the opposite end cannot be connected to anything.The ends sit inside a plastic holder then the shaft snaps in place to secure it. You may have a broken plastic clip that needs replacing, but a close look at the clips and any loose rods and you should be able to tell which rod goes where.
Feb 15, 2015 | Cadillac Cars & Trucks
Replacement arms
These guys can get authentic lenses and earpieces for Versace glasses. Send them a message here
http://stores.sunglassreplacementlenses.com/contact-us/
May 23, 2014 | Versace VE 4158 Sunglasses
Hello Im looking for to bay vouge sunglasses. vo3588 ( gray and black with green glas.
You can go to the official 'Vogue' website and look under store locator, if the site has the facility
Aug 04, 2011 | Vogue VO 3588 Sunglasses
The stem broke off right where the plastic meets the gold. clean break & can see plastic inside gold temple piece.
hi
i can see from your explanation that your glass has broken badly . first if your coolin glass in warranty period . if so please approach the authorised dealer and get the work doone for free or you need to paymoney for the work to get done i shall give you site adress trying check it out it may help you
http://www.sunglassreplacementlenses.com
If you are happy with my answer please vote four thumbs up. Thank you
Dec 13, 2010 | Tom Ford CLAUDIA Sunglasses
The plastic ends on the shades' handles have comes off due to the heat in dubai. Are there any better ones I can purchase which are heat resistant and strong?
hi
it must be really hot out there :) ok try these brands other than ray ban these asre best in market
gucci
diro
Carrera sunglasses
dkny
If you are satisfied with my answer please vote three thumbs up.Thank you
Dec 06, 2010 | Ray-Ban RB 3360 Sunglasses
The pull starter cord on my MTD Gold Series push lawnmower has broken. I have disassembled the housing and can access the feed holes for the cord. Can you give me advice on how to install the cord? This...
You have the cover off and are looking at the recoil from inside. Ok.
You need to get a length of cord equal to the old cord plus a few inches for tieing knots on the ends.
First put the length of cord through the hole on the top of the recoil cover. Feed it into the spool under the cover and get a pair of needle nose pliers to help you pull it through the hole in the spool. Now tie a knot in the end that just came through the spool and using a cigarette lighter singe the end of the rope to seal it. *(most true recoil cords have a little nylon in them that will melt to create the seal) This seal keeps the end from fraying or collecting moisture.
Now that you have one end fitting you are ready to put the handle end on. If your old handle is refittable then reuse. If not, you need to get another handle. Replacements are generally reuseable. Put the unknotted end through the new handle and tie and knot in it. Then do the lighter singe thing again.
Now the spool needs to be wound up. Looking at the spool you should see a notch on its outer edge. This is where you put the cord and use it to prewind the starter return spring. You put enough turns into it the when you release it the recoil pulls enough cord in that your handle rests in the appropriate spot *(either on top the recoil cover or on the mowers upper handle). Once you have the unit prewound you can reinstall it and try it out!
Good luck and be careful!
Jun 28, 2010 | Mtd 22" Yard Machine Push Mower
Clothing Logo
135 people viewed this question
Top Clothing Experts
treeeee
treeeee
shuyumeng
shuyumeng
Erin Wood
Erin Wood
Are you a Clothing Expert? Answer questions, earn points and help others
