LAVAMAT 795 SENSORTRONIC WASHING MACHINE
MACHINE IS NOT TAKING IN SOFTNER FROM TOP TRAY AND DOES NOT WASH PROPERLY
gittos73
  • 244 Answers
SOURCE: The fabric softner is not going into my washing machine
hi there just try washing the complete soap drawer again in boiling water leave in there for 10minutes to let the hot water work into the gaps and make sure u take all the holders out of the drawer u sometimes have to use a tooth brush to get into the small holes at the bottom of the little funnel what your softener holder goes over also get a small flat blade screwdriver and clean inside that funnel if thats not clean it will stop softener from going away if this doesnt work still then when your softener is supposed to be taken thru the programme make sure the washer opens the valve for the water to go into the fabric softener holder if it doesnt then the solenoid will need replacing as this could be faulty. LET ME KNOWHOW U GET ON PLEASE PETER
Posted on Nov 17, 2008
  • 3230 Answers
SOURCE: AEG Lavamat 86720 washing machine
This means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
post further comment for more help......
Posted on May 06, 2009
  • 118 Answers
SOURCE: Fabric Softner Tray
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Posted on Sep 02, 2009
supernova278
  • 1932 Answers
SOURCE: washing machine lavamat 74810
EFO error is a water leakage error.You need to call for service.
Thank you
Posted on Sep 10, 2010
  • 6277 Answers
SOURCE: Fabric Softner tray is full of water and won't
This is a common problem with many machines.
I suspect that it is the conditioner/softener tray which needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 26, 2011
Testimonial: "Problem fixed,,,,,,,,,,, THANX"
I had a power cut just as I set the aeg oko lavamat sensortronic to wash. When it cam back on the duration is showing 4h and any attempt to change shows error.
try unplugging for about an hour that should reset the brain if it dont ur probably gonna have to change the brain out sorry
Feb 25, 2010 | Dryers
Hi my haier washing machine does not take water into softner compartment of draw but does take in water. would appreciate any help thanks.
Could be faulty fill solonoid valve coil/ has 2 coils one for cold rinse water other for softner. could also be dirty soap tray of course..Good luckl
Oct 24, 2009 | Haier HLF11P 6 cu.ft. top load washer /...
Bleach & Softner not dispensing correctly
I finally figured mine out! Remove the dispensing tray then take a small brush, or maybe a q-tip and clean out the small hole right above the softener tray. Mine had mold in it and wouldn't let the water fill the tray, which is what causes the softener to dispense!
Jul 21, 2009 | Whirlpool Washing Machines
Washing machine does not take fabric softner
Obstruction, please take the whole soap compartment out and do better job with old tooth brush on the compartment in the sink and the machine itself. Should do it unless you live in very cold environment.
Apr 14, 2009 | AEG Lavamat 72640 Front Load Washer
Jetstream 1200 wont take away fabric softner
strip and clean out the soap tray then remove the tray and clean the fill water holes above it with a stiff washing up brush.
Mar 16, 2009 | Zanussi ZWF1430W Front Load Washer
Softner wont go into the washing machine
removing the front plate won't help you, take the draw out. Get a long bag tie or inner core of any mains twin and earth cable and push it into the holes in the top of the dispensor, move it about in/out etc, changing the holes as required, this normally works, if it doesn't the dispensor lid is available as a seperate part and is quite easy to change.
Jul 06, 2008 | Zanussi FJS1225W Front Load Washer
Softner remaining
Try diluting the softener, some softener are too thick. But first clean out the softenre tray, by pulling it out, or with a tooth brush. Do look into your user manual. Does water enter the soft tray, check this too.
Sep 08, 2007 | Zanussi FJS1225W Front Load Washer
are the holes that spray out the water partially blocked? if so the water will spray out at every angle filling all the tray slots. try popping out the soap tray and cleaning above it with a stiff washing up brush and then reducing the water pressure by turning the tap off a bit.
May 18, 2007 | AEG Lavamat 72640 Front Load Washer
Bosch wlf2260
I had a similar problem and found that the holes above the softner section were blocked by black mold. All I had to do was push a small wire into the holes to clear the blockage
Mar 11, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Front soap tray leaking
Possible the tray is clogged; you can pull it out to clean it.
Nov 02, 2006 | Hotpoint Aquarius WF220 Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
