Samsung CLP300 black & yellow cartridges do not have chips on them
The Black & yellow Toner Cartridges DOES NOT have any CHIP in my printer. is this reason for blurred images
  • 45 Answers
No, the black and yellow toner cartridges does not have chips because they are "starter cartridges", to solve your problem you must execute a "PERIODIC DEFECTIVE IMAGE" readjustment, you can download the service manual from here:
http://www.tradebit.com/filedetail.php/229896734-samsung-clp300-series-clp-300-xsg-service
Best regards,
Posted on Jul 15, 2013
SOURCE: "invalid toner cartridge" message remains
Try this
Turn the printer off hold down the menu button turn the printer back on while continuing to hold down the the menu, when you get a green light your ready to print
Posted on Mar 05, 2009
  • 30 Answers
SOURCE: black printing faded although toner not low
The black developer is defect, you have to call the service to solve this problem. and install FW Update V1.29.12.35
Posted on May 28, 2009
  • 51 Answers
SOURCE: Samsung CLX 3175FW printer toner cartridge
you need to get into technical mode, simply press menu > # > 1 > 9 > 3 > 4 and then press ok tech should be shown on the lcd screen, now go to the menu and data setup, look for memory clear or clear all memory, it should ask you for a destination country, if you choose your country at this prompt and press ok it should accept the toner
Posted on Nov 14, 2009
nakshatraipu
  • 241 Answers
SOURCE: Samsung CLP-315 eats toner. Cartridges last almost
YES WE HAVE PERMANENT SOLUTION FOR CLP 315
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Posted on Nov 18, 2009
PCGeek2010
SOURCE: minolta 2430dl X toner not installed
I had this same problem and discovered the CORRECT solution!! The Crum reader is not the issue. That is for reading the level of the toner and telling the printer when iti is low or out. The "Cartridge not installed" issue is caused by poor contacts on the LEFT side of the printer. Look at the toner cartridge on the LEFT side as you are holding the colored cartridge latch. Thos two copper contacts make contact with the 'springs on the left side of the cartridge holder. I user an eraser, alcohol and air to clean the contacts on the toner catreidge but ESPECIALLY the spring contacts on the outside of the cartridge holder. You should clean all four. I went a step further and took the left circuit board off, clean all the "spring contacts and took the black holder with long copper contacts out and cleaned those. The printer is now like a brand new printer. No errors at all!!
Posted on Jan 14, 2010
Supply memory error on screen
If you haven't yet, reseat the cartridges. The cartridges have a small chip on them that is read by the printer. If the chip is bad or missing, you'll get that error.Replace the toner cartridge that is causing the problem. If you just bought the cartridge return it, HP warranties them.
10.00.00 = black 10.00.01 = cyan 10.00.02 = magenta 10.00.03 = yellow
Aug 02, 2011 | HP Hewlett Packard LaserJet 3000dn Printer
CLP 300 toner cartridges invalid toner
the drum has chips encoded,need cartridges with chips.
May 29, 2009 | Samsung CLP 300 Laser Printer
Invalid black toner replacement cartridges
Hi, Please make sure what version printer you got? USA version? or Asian version or euro version?
After confirm what version printer you got buy corect version CHIP or toner it will works.
Use any of other area toner will result toner invalded.
Regards
May 20, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP 500
reseat the toner..could be the chip/fuse on the right side under the cover.
Mar 04, 2009 | Samsung CLP-500 Laser Printer
HP 2550L low yellow toner -- can i still print just black???
Unfortunately if one colour is out, then you cant print. These cartridges contain a chip and once depleted will not print until a new cartridges is installed
Dec 12, 2008 | HP LaserJet 2550L Printer
Error Message/Black toner empty
Most all new color laser printers employ an RFID reader adjacent to each of the 4 tomer cartridges. There is a unique RFID chip inside (under a small blue slide cover) each toner cartridge. Whan a new toner cartridge is installed, the printer "knows" such and begins a "countdown" of the number of prints that are made which utilize the toner in each of the 4 cartridges. Once a toner cartridge has "processed" the predetermined number of copies you will get a warning that the cartridge is almost empty and must be replaced. After an additional predetermined number of copies are processed, the integral computer within the printer will shut down the printer until the cartridge is "replaced". If you simply "refill" the same or original cartridge and re-install it into the printer, the same RFID chip is in the cartridge and the computer will not reset the print "counter", allowing you to start printing. You have to obtain another couple of new or "re-filled" cartridges (of the same color or black) from an outside source. The printers' internal computer does not keep a complete running list of all of the RFID chips that have been installed and used in the printer (maybe 2 or 3) and then then it is "1st in / 1st out" of the limited RFID memory of the printer. I have been unable to obtain a "Service Manual" for the OKI C3400n printer to determine how to do a "hard reset" of the internal computer. I know there is a way which would allow the "refilling" of the toner cartridges without having to buy an additional 2 of each color.
Dec 06, 2008 | OKI C3400N Single Pass Color Printer
CLP 300 toner cartridges don't have a chip
New Models of Samsung Laser printers come pre-packed with Cartridges that have no chips but an empty space where the chip should be. These chipless cartridges do not need to have a chip because the printer is pre-programmed to run for one cycle. These pre-packed cartridges can also be refilled in the same way but will need a reset chip.
Buy new chips from:
http://www.clp300.com/index.php?main_page=product_info&products_id=133
Sep 05, 2008 | Samsung CLP 300 Laser Printer
Laser cartridges with chips
you need to replace the chips so it will read the amount of pages printed by the toner cartridge.This chip is only for measuring how many pages printed.
Mar 30, 2007 | HP Q2613A OEM Genuine Black Laser Toner...
90 people viewed this question
jasbo
jasbo
