Question about Hotpoint 6.67 cu. ft. / 189 liter Chest Freezer RC32
Freezer green switch
How do u get the orange light off and the green light on??
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Sep 02, 2014 | Electrolux Freezers
Green light wont come on
Is unit running? Orange switch - is that the fast freeze switch? If on and running, green light faulty. If nothing happening, start with fuse, test the switch and make sure power is to the thermostat.
Apr 04, 2014 | Freezers
Skandiluxe freezer seals
Hi
Most freezer lights are screw on bulbs. Unscrew the bulb unticlockwise and replace with a new one.
Feb 15, 2014 | Freezers
Orange light is on instead of green light on freezer what does this mean
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees - orange light : pressing the so-called S-switch which means that the compressor is running continuously. The S-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
Dado
Jan 14, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
Does the orange switch on the front, at bottom of freezer, next to green light, need to be up or down? The green light shows either way.
try to shut off by unplugging the unit then after several minutes try to plug in then re start unit and obsreve.
Feb 05, 2011 | Fisher Freezers
Orange light is on instead of green in the freezer does this mean anything?
no. the orange light is the temperature light and the green light is the mains light.
Apr 06, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
An orange light is on next to the green light on my chest freezer
Normally orange signifys that the machine has been switched into fast freeze , check your controls
Sep 04, 2009 | Hotpoint 6.67 cu. ft. / 189 liter Chest...
Philips Freezer
I used to sell freezers.the green light tells you the mains is on and the freezer should work.The red light is to inform you the freezer is not low enough temperature,and the orange light is a fast freeze light to over ride the thermostat for use when introducing fresh food.It should not be used for prolonged periods as it may burn out the compressor although in your case you already have a problem and should seek advice or buy another freezer.If you get a cheap freezer thermometer it should confirm what I am saying.
Jun 24, 2008 | Freezers
Hotpoint 6.67 cu. ft. / 189 liter Chest Freezer RC32 Logo
44 people viewed this question
Top Hotpoint Freezers Experts
AJMAL KHAN
Victor Nwachukwu
Victor Nwachukwu
Gerard Curran
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
