Question about RTO Boating
Yamaha 55hp outboard
Changed battery leads yesterday because wher smoking when trying to turn over engine.they did fire the engine but with difficulty.now changed cables to more heavy duty type now engine seems to have no life at all
SOURCE: Yamaha outboard engine
Procedure for carb. adjustment for 1992 Yamaha 30 h.p. 2 cycle outboard motor
Posted on Dec 30, 2008
tellme2
  • 137 Answers
SOURCE: very heavy smoke from exhaust of Yamaha Virago
give the air filter a blow out m8,, and change the plugs to a hotter grade,, ie if u have ngk b8es or summat try b9,,that type of thing,
Posted on Apr 10, 2009
  • 18 Answers
SOURCE: yamaha outboard starting
New plugs and service
Posted on Sep 21, 2009
SOURCE: Black smoke on acceleration diesel x-type jaguar
can anyone tell me where the intercooler is on a 05 plate jaguar x type 2.0 diesel thanks
Posted on Nov 09, 2009
  • 4 Answers
SOURCE: 330 excavator with a c9 cat engine, heavy SMOKE
At the time you made all the above repairs, did you replace the "throw away" turbo charger? The turbo charger commonly sucks oil, and it is not repairable.
Run it without the inner & outer air cleaner. If it isn't the turbo, run the injector cut out test. If the injectors are ok, then you need to replace the injection system hydraulic pump, which is also unrepairable.
Posted on Apr 23, 2010
sloenoid bad maybe
Sep 05, 2014 | Boating
Yamaha 55hp outboard seems too be stuck in forward gear any ideas what could be wrong ?
When you take foot off can you change gears if you turn gear change shaft with pliers or vice grip ? To install,make sure gearbox is in forward and controls are in forward,can be a bit difficult if this is your first time. Upper gear change shafts can also corrode and twist or break. Don't force gearbox on as you can snap aluminium bracket that sits under bottom carb.
Aug 20, 2014 | Boating
1982 55 yamaha outboard ,water not coming out the water pump hole in strenght
First thing to check: Disconnect the tiny hose between the check outlet and the engine. Disconnect it at the engine side.
With an airgun, blow in the check hole from outside to engine side.
With an airgun, blow out the engine connection.
Start the engine, check waterflow out of the engine connector. If water, reconnect the hose and check the water at the checkpoint.
If still no water at the engine connection: replace the impeller!
Mar 28, 2013 | Clymer Marine Maintenance and Repair...
User manual for 55hp Suzuki
does the bulb get sucked out ?
if it does right at the tank there is a valve that have a little marble you just have topch it back or change the gas coupler that have the valve
Aug 21, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
54 people viewed this question
Top RTO Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a RTO Boating Expert? Answer questions, earn points and help others
