Question about Lenovo Ibm T540 9511-ag4 15" Rackmount Lcd Keyboard Trackpoint
Where can i find drivers for windows xp ? Tried a lot, nothing works
The red mouse button dose not work
Hi fay bart...
Your mouse driver files are corrupted
Go the following webpage and download the drivers you need to reactivate the mouse button
1...TrackPoint driver for Windows XP, 2000 - ThinkPad
2...TrackPoint Accessibility driver for Windows 98/SE/Me/NT/2000/XP/XP Tablet PC Edition 2005 - ThinkPad
Please take time to rate me
http://support.lenovo.com/en_US/downloads/default.page?
Sep 05, 2011 | IBM ThinkPad R31 2657 Notebook
IBM thinkpad problem. Mousepad isnt working. Mouse wont move, we have no mouse that we could plug in, help!
re-installing the mouse/trackpoint driver then restarting the laptop usually soles this issue.
if you are running windows XP or 2000 then the driver can be found here for free download-
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4KMUYL
if you're running a different version of windows let me know.
//javaftper
Jul 30, 2010 | IBM ThinkPad A31 Notebook
Need a driver for an old IBM keyboard for windows XP
Attach the device and see that it works or not.
If yes OK, if no, then visit the IBM's website and search for the product's drivers.
Mar 27, 2010 | IBM (1390131) Keyboard
Hello, I need driver help for 600e thinkpad
You will find all the drivers for your laptop (including trackpoint and power management) at the Lenovo / IBM support site here:
http://www-307.ibm.com/pc/support/site.wss/DSHY-3TLQ2L.html
Jan 04, 2010 | IBM ThinkPad 600E 2645 Notebook
Have reformatted the thinkpad t43 with windows xp. wireless adapter not visible in hardware devices. Help!
have you installed all the device driver for the hardware of the notebook? if not run all the device software including the driver for the wireless adapter, it will not appear if it is not windows compliant you have to provide the drivers
Nov 24, 2009 | IBM ThinkPad T43 Notebook
The pointer freezes or starts moving about without any reason, especially when my laptop is carried from one place to another
this is not a software driver issue... many IBM and Dell laptops that have the 'trackpoint" aka pencil eraser head between the G and H keys of your keyboard that control your mouse cursor cause this problem
If your laptop has the TOUCHPAD and the TRACKPOINT cheap fix OPTION #1) is to remove the keyboard and cut the ribbon cable that attaches to the trackpoint. Voila ! Problem solved if you never use the trackpoint (most people use touchpad instead anyways) or you can use external mouse as well. Next option is more realistic for most people...
OPTION #2) Buy a new keyboard cheap on eBay. Search: IBM T42 keyboard. Easy to replace. See this link, easy for even a novice
http://www-307.ibm.com/pc/support/site.wss/MIGR-46515.html
Hope that helps !
Jul 09, 2009 | Lenovo IBM ThinkPad T43 Notebook PC -...
Mousepad, right clicker problems on ibm thinkpad t41
you can try looking at the manufacturers website for a driver update to your trackpoint http://www-307.ibm.com/pc/support/site.wss/MIGR-46258.html#mouse
Try turning off the tap to click option. This should resolve accidentally dragging things where they don't need to be.
Better option...if you're using this laptop at home just invest in a wireless mouse and set the laptop to disable the trackpoint when an external mouse is detected.
trackpoint=mousepad=touchpad
Jun 10, 2009 | IBM ThinkPad T41 Notebook
How to enter into BIOS when trackpoint was broken.
Hi there.
Its something to do with the trackpoint, possibly the cable has become loose.
* If an emergency power down is made by switching the system off during or while an application is open, then immediately switching the system on creates a 8611 error.
* Repeatedly turning power off and back on without properly shutting down or allowing the system to shut itself down.
Solution
Wait at least 6 seconds or longer after shutting down the system or before restarting to correct the 8611 error.
See if that gets rid of the error, if not it could be a loose cable to the trackpoint.
Good luck
Jun 01, 2009 | IBM ThinkPad 600X Notebook
Trackpoint Malfunction
You are lucky that you have IBM machine. They provide a facility of RESTORE TO FACTORY SETTINGS.
Using it all such misappropiate settings will get cured and your machine will work like a BRAND new machine.
Also regarding your mouse sensitivity, you can go to CONTROL PANEL & then to MOUSE settings & there you can customize your mouse settings (sensitivity also).
Rate the solution if it was helpful to you...
With Regrards,
Shyny
May 28, 2009 | IBM ThinkPad 600E 2645 Notebook
Mouse pointer seems to randomly move around the screen
The problem is in the trackpoint itself, it is defective. The fix is to either disable the function of the trackpoint through software or by physically disconnecting it.
Disabling through software can be done usually through the BIOS or in the Control Panel in windows. If there is no way for you to disable it then you have to remove the keyboard and cut the connector that is coming from the trackpoint control board. Make sure that you do not cut the keyboard cable. The trackpoint cable is usually about 4 wires thick and is seperated from the thicker keyboard cable. The only other thing to do is to replace the keyboard.
Apr 03, 2009 | Dell Latitude D410 Notebook
Lenovo Ibm T540 9511-ag4 15" Rackmount Lcd Keyboard Trackpoint Logo
57 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
