Question about Hotpoint WMTL79 Top Load Washer
Failure to hold water
On any cycle, shortly after the machine starts to fill with water, it discharges the water and never completes a fill.
4 Suggested Answers
  • 619 Answers
SOURCE: Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Posted on Jan 05, 2008
SOURCE: wachine machine is only draining on K cycle
We have a Siemens A 08-16 front loader waching machine which doesnt appear to be emptying after its cycle. Any ideas about what the problem might be? Is it likly to be a blockage in the pipe?
Thanks
Posted on Jan 06, 2008
  • 123 Answers
SOURCE: machine fills with water but does not carry on with the cycle
hi there......this problem is generally caused by worn out carbon brushes in the motor..having isolated the power from the machine ....remove the motor..and relace the worn out brushes
regards Sir Galahad
Posted on Sep 03, 2009
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
There comes black stuff out of the washer when i spin. Isit the stasoft?
Fill your machine with hot water (if you only have cold water connected, then add hot water with a bucket) until the machine is filled to the top mark. Add a cup of dishwasher powder and stir it to dissolve. You can also let you machine run a short while, but be carefull that the water is not pumped out. Turn the machine off and let it stand overnight. Then turn it on the next morning and let it wash a complete cycle. You don't have to let the rinse part of the cycle complete. Just turn the machine off when the first water has been pumped out.
What this does: The machine builds of a residue between the drum and outer housing which is not removed in the normal wash cycle, especially if you don't wash with hot water. LG recommends that the machine is cleaned in the above way once "fluff" or black residue is starting to show in clothes after washing.
Mar 11, 2015 | LG WFT1071TP Top Load Washer
I have a adg7560/1. the cycle starts but ends after a few minutes. the light flashes four times
Run the dishwasher through a test mode
Test Mode
Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
Open the door and set the program to the first program. (Normally rinse).
Turn the power off.
Press and hold the start button and while holding turn the power on.
After a little while the start button will flash, release the button.
Press the start button once and close the dishwasher door.
The machine will now run through a diagnostic routine.
Should take about 20 mins.
The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the programme.
To exit diagnostics at any time just press and hold the start button till the programme is cancelled
Error codes
F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3 Celcius
F2. 2 Flashes. Water leakage. Floater switch LS6 in drip tray has switched.
F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Chack also cabling.
F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect.
F5. 5 Flashes. Sprayarm Blocked (not present on VBL version. On 1 digit display will show as F and flashing start led).
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
F8. 8 Flashes. Water level failure. Sieve strongly dirty or big amount of foam inside to less water.
F9. 9 Flashes. Continuously Water Inlet. Water inlet valve mechanically not closed or control board defect.
FA. 11 Flashes. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
FB. 12 Flashes. Motorised Diverter Valve
FC. 13 Flashes. Water Hardness Sensor Failure
A fault with no fault code indication = faulty module
Read more: http://www.diynot.com/forums/viewtopic.php?t=200838#ixzz2zKhYFHxt
Apr 19, 2014 | Whirlpool Dishwashers
Have a kenmore elite he3 which stops the cycle w/ 40 min. remaining and flashes back and forth the 2 initials ''F'' and ''H'' on the screen. Don't have a manual to check
If the control has turned on the fill valve and after 8 minutes the flow meter has detected 10.5 gallons of water and not detected a pressure switch trip, the valve will be turned off and the failure code will flash in the display.
  1. Unplug the washer from its electrical source and wait for 30 seconds.
  2. Replug the cord into the electrical source and try to start a normal cycle or a cancel drain cycle.
  3. The machine should start the pump out mode and empty the water.
If, after 30 second, the machine has not detected water entering into the machine, the valves will be shut off and the failure code of FH will be displayed.
  1. Check all hose connection and valves, both hot and cold, are turned on completely.
  2. Verify that water is at the fill hose connections at the back of the washer.
The main control has sensed a component failure in the machine and will be needing a diagnostic visit for a possible repair or replacement.
DrakeTech
Feb 23, 2010 | Washing Machines
Wash cycle and spin
you need to check a simple button called " no spin" may you will see it marked "aspiral shap" and has "x" over
good work !
Jul 05, 2009 | Zanussi ZWF1430W Front Load Washer
Washer will not discharge water after wash or rinse cycle
Pump failure. Unit probably has something stuck in pump....the washer eats the socks not the dryer. suggest shope vac to get water out, and then remove hose from pump and check to see if its clear.
Jun 08, 2009 | Kenmore Washing Machines
Washing machine stops on spin cycle
You need a new drain pump.
May 04, 2009 | Washing Machines
Kenmore 90 plus won't fill on regular orpermanent press cycle.
OK, Duh..... I guess there is about a 2 to 3 min. delay for the liquid soap dispenser to fill up and disperse the soap into the washer tub. After that short cycle is complete the fill cycle engages and fills at normal speed.
Mar 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Open Questions:
See all Hotpoint WMTL79 Top Load Washer Questions
Hotpoint WMTL79 Top Load Washer Logo
18 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
