C0910 bizhub c350 - Office Equipment & Supplies
    New Friend:
  • 45 Answers
Here is the service manual, best regards,
http://www.tradebit.com/filedetail.php/172751610-konica-minolta-bizhub200-250-350-service-manual
Posted on Jul 14, 2013
jmassengill
  • 345 Answers
SOURCE: Bizhub C350 - Print spooler not running after power outage
I would print out a copy of the network configuation of that printer and ensure it has the proper network settings (I.E. IP address, Subnet mask and Default Gateway. I just worked on a printer that I accidently pull the plug on and it lost it's network settings and wouldn't print until I changed them back to the correct settings.
Good luck
Posted on Nov 11, 2008
  • 30 Answers
SOURCE: bizhub c350 -cobao code
finisher elevator drive error. Check the finisher tray for blockage or something under the tray. If all else fails, unplug and disconnect the finisher
Posted on Feb 25, 2009
  • 24 Answers
SOURCE: Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Posted on Jun 25, 2009
herminio_hal
  • 210 Answers
SOURCE: I can't print from IMac to konica-minolta buzhub C350
Go to konicaminolta web site and download a mac driver. and install it to Imac. Make sure to download OS10.4 or higher.
Posted on Jul 09, 2009
djklermund
  • 3 Answers
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Posted on Oct 18, 2009
I ave problem on c350 error code 2160
BIZHUB C350 SHOWING ERROR CODE C-0900 AND
NOW C-0950
Sep 30, 2013 | Konica Minolta Bizhub C350 Digital Copier,...
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
ERROR C0910 KONICA MINOLTA BIZHUB DI 2010
2nd Drawer Lift-Up Motor Failure - The Lift-Up Sensor is not unblocked even after the set period of time has elapsed after the paper liftup operation for the drawer has begun.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Nov 27, 2009 | Minolta Office Equipment & Supplies
Delete error code C0910 or reset?
with the machine turned on open and close the front door
Sep 24, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Bizhub Password Reset
Konica Bizhub c350 default password is 12345678 give that a try
Mar 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
83 people viewed this question
k24674
jasbo
jasbo
