Question about Prima CV2011 TV
PRIMA TV has "IIC Release" on screen unable to turn off
The TV screen has "IIC Release" in the upper right hand corner. Set cannot be turned off by remote or TV power button
5 Suggested Answers
SOURCE: LC-23Y25 Problem with turning on power?
so i had the same problem. red light came on, but no blue light or anything on the screen. it turns out that there were some capaciters blown on the circuit power board. unless you have a good understanding of circuit boards, its not a quick fix. but for someone who knows their electronics, its not too hard, and its not expensive to fix, unless you bring it into a store. but the supplies needed arent expensive. good luck
Posted on Feb 20, 2009
jerryg50
  • 1689 Answers
SOURCE: I touch the on/off button on the Prima TV to turn
I am sure you had some strong static electricity. The static spark arced to inside of the TV in to the circuit board. Many of the low cost TV sets have poor static electricity protection.
In most cases there is damaged caused by static shock to electronic devices.
Just for curiosity, you can try unplugging the set from the AC mins and plugging it back in to do a simple reset, in case there is no damage and some logic device became hung up.
Last year I picked up my mobile phone and got a static shock from it. I had to get a new phone. This phone never worked again!
Jerry G.
Posted on Jan 19, 2010
Testimonial: "At least now I know what happened to it, thanks."
SOURCE: remote control code
Prima 4101 4138, 030,032,036,039,047,054,056,060,091,016,415
466,092,166,251,017,281
BIG SCREEN=166,019,035,154,451,037,068
Posted on Feb 24, 2010
  • 905 Answers
SOURCE: Tips to operate without remote
You might try hitting the MENU button on the tv itself to see if you are able to select input / source that way. Some TVs also have the Aux Inputs selected by scrolling through the channels until you come to the aux inputs.
Posted on Jun 22, 2010
How do you calibrate Nuvi 40LM when the calibration is so badly off?
Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Aug 17, 2016 | Garmin Nuvi40lm Nuvi 40lm Lower 48 Gps...
Garmin nuvi 1200 wont let me type the right letters
Try recalibrating the touchscreen. The procedure can be found here:
http://www.sharc.net/discus/messages/6/77.html?1315261162
Press each dot to recalibrate the screen.
Once completed the Nuvi will display Calibration Complete
Feb 28, 2013 | Garmin nuvi 1200 Car GPS Receiver
When i turned on the leapfrog and asked me to log in my name it doesn't let me go in when i press it with the leapfrog pen
the screen needs to be re-calibrated. Do this: while powering on the Leapster, hold down the ? key. If it's been worn off, it's the round key on the left hand side above the t-arrow keys and it's the middle button. A new screen will come up that lists Base Info Cart 1 Info, Cart 2 Info, Cart 3 Info. In the right hand corner is a "A" that you can touch with pen beside it, it says "Touch Calib" Touch on that.It will say starting...then in the upper left hand corner there is a +. touch it with pen. it will move to bottom left hand corner. Touch it with pen. It will move to right bottom corner. touch with pen. It will move to upper right hand corner. Touch with pen. It will move to the center of the screen. Touch with pen. Repeat until you come back to the Base Info screen. You're DONE! Power off and on again and you should be all set! Good luck!!
Feb 28, 2010 | LeapFrog Leapster 2 Learning System
I need 3 digit code for my Prima tv to program bell express vu
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Dec 16, 2009 | Prima C2012 TV
How do I make my control connect to my tv and my dish network?
In order to program the remote to the TV turn the TV on and put the remote in SAT mode by pressing the SAT button in the upper left hand corner of the remote.Now press and hold the TV button Next to the SAT button until all buttons light up across the top of the remote and release. Now press the small red TV button and release. This should result in the top clear TV being lit constantly. Now press the arrow up key slowly until the TV turns off. Once it does press the arrow down key once and then the arrow up key. The TV should turn on. Now press the pound symbol at the botttom right of the remote. The TV button on the top should flash three times. Now you can use the remote to control the TV. If you are unable to get the TV to turn off then the TV is not compatible with the remote.
If the remote is not controlling the receiver first ensure that you have the correct remote for that location. If you do and it is at the receiver location ensure there is nothing blocking the IR cells on the front of the receiver. If it is a duo receiver and the issue is with th TV2 location ensure that the small antenna is on the back of the receiver in the correct port. Verify the remote addresses of the remotes are set to the same addresses as the TV displays in the system info screen. If you need further assistance let me know. Thanks for using Fix Ya.
Mar 16, 2009 | DISH Network IR Remote Control
I would like to know how to pro. 103602 ir remote
In order to program the remote to the TV turn the TV on and put the remote in SAT mode by pressing the SAT button in the upper left hand corner of the remote.Now press and hold the TV button Next to the SAT button until all buttons light up across the top of the remote and release. Now press the small red TV button and release. This should result in the top clear TV being lit constantly. Now press the arrow up key slowly until the TV turns off. Once it does press the arrow down key once and then the arrow up key. The TV should turn on. Now press the pound symbol at the botttom right of the remote. The TV button on the top should flash three times. Now you can use the remote to control the TV. If you are unable to get the TV to turn off then the TV is not compatible with the remote. Thanks for using Fix Ya.
Mar 15, 2009 | DISH Network IR Remote Control
What button is the address button
SWINTEC 8014 S TYPEWRITER
Press "MAR RELEASE", one key right of "MAR LEFT" in the upper left hand corner.
Press back space in the upper right corner until it's where you want it and press "MAR LEFT" to set it.
Tab over to where you want the right margin and press "MAR RIGHT"
Aug 05, 2008 | Office Equipment & Supplies
Green dot in upper left-hand corner of screen.
you can try demagnetising your tv screen
Jan 13, 2008 | Emerson EWF2004 20" TV
Prima CV2011 TV Logo
22 people viewed this question
Top Prima Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Rommel Balcita
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
