Question about Dell E771p 17" CRT Monitor
T attach photos
When i start my monitor ,it displays for few seconds and then the screen vanishes upon tapping the screen reappears it is a continues process and also the display is not proper
CompuGuy44
  • 432 Answers
SOURCE: Menu and OSD Problem
Yep. Sounds like one of the buttons is shorting out and causing the icon to pop up. You can try canned air. If your good with tools, See if you can take the bezal(the plastic part around the screen) apart to clean the button contacts.
Posted on Jun 22, 2007
  • 36 Answers
SOURCE: monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Posted on Jul 12, 2008
ici1011
SOURCE: Dell 1703FP monitor issue
reduce the hardware acceleration on it. I resolved it by reducing acceleration and changing my screen size. It works. I wanted higher resolution but it doesn't seem to be possible for some reason.
Good luck.
Posted on Jun 20, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Posted on Jul 21, 2009
SOURCE: E193FPC
it's a bad inverter /power board
Posted on Mar 02, 2010
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
I have a Canon A720is (about 5 years old) that recently has started to show problems.
I think you immersed camera in water. This might have damaged corroded contact of LCD supply line and PCB.
Aug 19, 2012 | Canon PowerShot A720 IS Digital Camera
OUT OF RANGE: this words appear on my monitor, and it does not change. the monitor is black always.
The resolution your pc is set for is not compatible with the monitor.
To fix this, you need to start the pc in VGA mode. (640 x 480 lines) Start the computer and begin tapping the F8 key about once a second till you see a text screen with options displayed.
If you recieve a stuck key error, clear it (read the message) and continue to tap F8.
Choose the option to boot in VGA mode. When pc starts everything will look very big, like you're zoomed in.
Now you can change the screen resolution. Right click on background and choose properties, or display options, (depends on your operating system) find the option for resolution and change it to 800 x 600. (The screen will not change then and ther) Apply or OK the screen then restart the pc normally. Now you should be able to see more of the screen.
Go back to the resolution settings, and adjust it to your likeing and the limit of the monitor. Now it will apply immediatly, - click the save option that pops up with the change to lock in. If screen becomes unreadable, just wait 15 seconds and it will change back.
Dec 02, 2010 | BenQ Computers & Internet
Adjust screen brightness
Press the OSD ("On Screen Display") button on the bottom-front of the monitor. Use the other nearby buttons to "navigate" through all the settings, to select "Brightness", and to move the level UP/DOWN.
Wait a few seconds, and the OSD will vanish, by itself.
May 13, 2010 | LG Flatron L1750S 17" LCD Monitor
Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic Graphic VG2021m LCD Monitor
I have the VL193 monitor attached to my laptop via blue cable, have checked all connections and display options, resolution, etc. The desktop background photo appears on the monitor but no Windows icons or...
connect external monitor and look it works properly or not .if problem persists , then format and reinstall the' operating system' . use licenced OS(operating system) to install . before that verify that all drivers are present or not . if not , then take the back up of the drivers .
Apr 19, 2010 | Princeton Digital VL193 19 in. Flat Panel...
Continual pop-ups saying OSD Main Control locked followed by language choice, etc. I have tried the buttons on the monitor with no effect
I held down the OK button for several seconds and the message vanished. On releasing the OK button, the problem reappeared. I intend to put a rubber glue (one that can be removed) which hardens on application, to hold down the OK button in the pressed position. Hope this solves the problem.
Oct 12, 2009 | Philips 170S5FS 17" LCD Monitor
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
Jul 08, 2009 | Gateway Computers & Internet
Computer monitor switches off after few seconds
You have to make sure that the monitor settings in the display > settings section in the control panel are properly set up.
Mar 17, 2009 | HP Compaq Presario F730US Notebook
Dell E771p 17" CRT Monitor Logo
mukhtar21 shaikh
mukhtar21 shaikh
