Question about Dell Vostro Computers & Internet
Thermal paste Hi, I openned my labtop vostro 3500 as dell manuel suggest. After, I closed and I tried to turn on. But my laptop didnt turn on. What can be the problem and how can I fix it ? Thank you
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 45 Answers
What were you opening the laptop for? Depending on how much of it you had to disassemble, I would venture to say you probably left something unplugged. I would crack the case open again and check all connections, make sure the hard drive is fully locked into place, etc.
Posted on Jul 14, 2013
  • 73 Answers
SOURCE: my webcam doesn,t work at all , my labtop is Dell
go to this page it should help
http://support.euro.dell.com/support/downloads/download.aspx?c=ie&l=en&s=gen&releaseid=R155105&formatcnt=1&libid=0&fileid=206853
Posted on Mar 24, 2009
ginko
  • 19396 Answers
SOURCE: Dell Vostro 1400 LCD Showing Black Screen
If you connected the laptop to an external monitor via VGA and the display, then it is not "an NVIDIA GPU defect" .
The video chipset connected to the LCD screen is the same connected to the external VGA port, and is working fine since picture is OK on monitor.
More likely the problem is either LCD ribbon cable, or LCD display, the fact that the backlight is working means that the inverter is also working.
Posted on Apr 18, 2009
SOURCE: Dell Inspiron 1300 - When I re-open the lid,Screen stays Black !
Your laptop either goes to hibernate or sleep mode when you close the lid. Then, when you open the lid up, the screen is still off because your pc already hanged/froze and could not wake up at all (usual problem in vista). Off course, hard shutdown would fix it. But actual fix is under power options on your control panel. Check your current scheme and edit it. There are options there that you can select to "do nothing when closing the lid"
Hope this helps
Posted on Oct 01, 2009
  • 12 Answers
SOURCE: I cannot execute my integrated
Hello ,
Did you try using the software that is built into the computer to use your webcam? If not just search webcame in the start menu. I tried looking for the drivers but seems that there aren't any. Sorry if this wasn't much help.
Posted on Dec 12, 2010
jgroves705
  • 536 Answers
SOURCE: Dell Vostro 3500 suddenly shut
Try going back to the previous version of the BIOS to see whether the problem continues. You can download older versions from the Dell website and install them over the existing version.
If this does resolve the issue, I would report the problem to Dell and as a precaution inspect the fan and the ventilation screens and ducts for debris and clean as required.
If you're good with a screw driver and the laptop is no longer under warranty, you might even consider taking the laptop apart to clean out any dust build-up from the ventilation ducts.
If this answer is any help at all, please rate either 3 or 4 thumbs. (1 or 2 thumbs are considered "horrible" and "bad")
Thank you for using FixYa and have a Happy New Year!
Posted on Jan 02, 2011
Testimonial: "thanks for time and pacience and happy new year!!"
My dell vostro 3500 keyboard doesn't work. I have noticed that the keyboard deos work in the bios
It is probably a driver problem. Which keyboard are you reffering to? Is it an external keyboard or the keyboard that comes with your laptop? I suggest that you update the keyboard driver of your computer. You can install RadarSync software so that you can scan your computer. This software will grab the correct driver update so you don't have to search for the driver anymore which is usually very hard to find.
David
Aug 09, 2013 | Dell VOSTRO 3500 Notebook
How to replace dell vostro 3500 keyboard ?
1) Remove ALL power. Remove the AC adapter, (Charger), and Battery.
2) Click on the Blue -
Dell Vostro 3500 Service Manual (8530KB)
[This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds, before the first page comes up ]
In the Service Manual click on the blue -
Removing and Replacing Parts
Click on Keyboard in the right list.
NOTE*
The Keyboard Cable STAYS attached to the Keyboard. It removes from the motherboard connector.
There is NO plug connector on the motherboard side, of the Keyboard Cable.
The Keyboard Cable is a FFC. Flat Flex Cable.
This is a general example of a FFC,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
Note the flat metal strips. These are Contact Strips. They mate up to Contact Pins, in the motherboard connector.
The Keyboard Cable MUST be reinstalled, as it was in the original position.
For this reason you may wish to make a mark, (Sharpee?), on one side of the Keyboard Cable; and a matching mark on the same side of the Keyboard Cable motherboard connector.
The motherboard connector is a type of ZIF connector.
Zero Insertion Force.
It is rectangular shaped, and composed of two parts, BUT does NOT come completely apart.
The bottom piece is the larger of the two. It is stationary, and mounted to the motherboard.
It is the Body.
The top piece is also rectangular in shape, smaller in size, and is movable. It is the Locking Bar.
The Locking Bar is designed to wedge the Keyboard Cable; in the Body, when in the Locked position. (Closed)
IF, the Locking Bar is removed from the Body, it is Broken.
IF, the Locking Bar is broken, or the Body, you are looking at MOTHERBOARD REPLACEMENT, and why I am being so detailed.
Use your thumbnails, or fingernails, to EASE open the Locking Bar. (Unlocked)
Metal tools have the tendency to slip, and break the motherboard connector.
There are Three types of Locking Bars used, to my knowledge.
(Forgot about one in the past)
The Slide type, and the Flip Up type.
I can't make out in the Service Manual what style is used. I think it is the Flip Up type. However;
Slide Lock Bar,
Closed; (Locked),
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-11.jpg
The Brown tabs pointed out by the Yellow arrows, are the sides of the Locking Bar. These are what is eased forward by the thumbnails.
The distance is 2mm. That is a little more than 1/16th of an Inch, or about the width of this capital letter -> O
Slide Lock Bar,
Unlocked; (Open),
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-12.jpg
Flip Up Lock bar,
Locked; (Closed),
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-13.jpg
Flip Up Lock Bar,
Unlocked; (Open),
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-14.jpg
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 20, 2012 | Dell Vostro 3500 PC Notebook
Need step by step instructions on replacing a palm rest on the dell vostro 3500
try this easy step by step instruction. hopefully it's of use to you
http://support.dell.com/support/edocs/systems/vos3500/en/SM/Palmrest.htm
Oct 16, 2012 | Dell Vostro 3500 Laptop Computer (Intel...
Water pilled in my dell vostro 3500 , i left it to dry for several days and till now it doesn't work , the screen is off even the power is on , and also fan on , light is fine to. what is the pro
The water is inside the machine on the motherboard and is causing a short, I recommend removing the main battery unplug the power supply open up laptop and lay it face down on a thick towel to assorb any moisture coming out from the keyboard, but I strongly suggest a pro take it apart for a cleaning provided the main board can be saved.
Jul 21, 2012 | Dell Vostro 3500 Laptop
I have dell vostro 1520 my laptop was working good until tomorrow now today i turned it on but its battery keeps on disconnecting and reconnecting itself. whats the problem
First, please check that if your Dell Vostro 1520 battery and laptop connection place is clean, please clean them and test if it will get better.Else, you can find something useful in this article's last post: battery can't be detected by laptop
Apr 30, 2011 | Dell VOSTRO 3500 Notebook
Hello sir.. in my labtop, my volume icon not shown n not working..... plz give solution... model is dell vostro 1014.. 4m sravanthi
hi...
  • install audio driver and real tek too.
  • definetly it work else you have to re-install it..
  • else you have to check hardware...
  • If it's useful for you means plz rate me the 4 Thumbs ....
Feb 08, 2011 | Dell Vostro 1014 Laptop Computer
I have a vostro 3500, after i installed A10 bios upgrade from Dell.com my laptop suddenly turn off 2 minutes after i turn it on can anybody please help me?
hi eily81,
good day!We have the same problem last time I troubleshoot dell laptop.But I just wait for a minute before I turn it ON..but still turned OFF..so I tried to pull off the battery and power it directly in line.Then keep pressing the power ON..then it begin displaying.
If you can do that..try it.
mastergani
Jan 02, 2011 | Dell VOSTRO 3500 Notebook
My dell vostro 1500 laptob sound problem.perfect driver instaled but sound not perform
Solution 1: Try downloading this driver : http://tinyurl.com/ycbadsn.
restart your computer.
Solution2: If that didnt worked then update your bios..open this link
http://tinyurl.com/yasnhjx
and download the bios driver..save/run it.restart the computer it will work.
Dec 10, 2009 | Dell Vostro 1500 Notebook
How to switch my bluetooth on my laptop dell vostro a860 and got windows vista.
easy.
#does your laptop have a bluetooth connection?
#if not you will need a dongle.
May 12, 2009 | Dell Vostro A860 Notebook
Computers & Internet Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
