How do I set the time on a aiwa FR-A47U - Audio Players & Recorders
Want an instruction book for Aiwa Model #WNA555
Manuals Lib has the manual here: https://www.manualslib.com/products/Aiwa-Sx-Wna555-159268.html . You can download it or read it online. The speaker system has the model number SX-WNA555. The main part of the stereo system has the model number CX-NMA545.
I hope this helps.
Nov 26, 2016 | Aiwa Audio Players & Recorders
In what format i should burn cd`s for aiwa xp 100
The format is usually CDA
But if you use a sftware to cerate yous cd you should not have any problem it will use the right format for you
i use CDBurner XP it is FREE and is working perfectly every time
https://cdburnerxp.se/fr/home?lang=en
Nov 25, 2015 | Aiwa Audio Players & Recorders
How do i set the time on the aiwa cx-naj22
If you don't have the remote, go to CD mode and power off. Push the "pause" button, when the blinking clock appears, quickly press the "pause" button again. Use the back and forward buttons to set the time.
May 09, 2012 | Aiwa Audio Players & Recorders
How to: Aiwa CRDL101 am/fm stereo (2x4 handheld unit) no manual
Sony bought Aiwa in 2002. You can download the manual from Sony's web site at
http://www.docs.sony.com/release/CRLD101.pdf
Jun 24, 2010 | Aiwa CR-LD101 AM/FM Radio
I have an MTD8 timer, that fits into my main electrical board
MTD8 Timer - Instruction manual
1. This timer has a total of 8 ON / OFF programs.
2. MANUAL ON / AUTO / MANUAL OFF for easy setting.
3. Switchable 12 / 24 hour mode.
4. 16 timer combinations are available as follows:
Monday
Tuesday
Wednesday
Thursday
Friday
Saturday
Sunday
Mo, Tu, We, Th, Fr, Sa, Su
Mo, Tu, We, Th, Fr
Mo, We, Fr, Su
Mo, We, Fr
Tu, Th, Sa
Mo, Tu, We
Th, Fr, Sa
Sa, Su
Initial operation:
1. When the timer is first connected to mains power, it will take up to 12 hours to charge the internal battery.
2. The settings can be defaulted by depressing the R (reset) button.
Setting Current Time.
1. Press the C+ (clock) button and hold, then simultaneously press the W+ (week) button until the actual day is displayed. Continue by pressing the H+ (hour) or M+ (minute) button until the current hour or minute is displayed. When setting, the W+, H+ and M+ buttons can be held down for rapid forward counting.
2. Release both buttons. The weekday and time will be set according to your selections.
3. To set incorrect time (etc.) repeat the settings.
Settings for programs:
1. Press the Timer button (Clock) and release. The first ON setting can now be made.
2. Press the W+ button to set the day or blocks of days. Select the ON time by pressing the H+ button and then the M+ button.
3. Press the Timer button (clock symbol) again to finish the first ON setting and enter into the first OFF setting. Repeat step 2 to set the first OFF setting.
4. Press the Timer button again to finish the first OFF setting and enter into the second ON setting. Repeat steps 2 and 3 to program the remaining settings.
When setting block dates, the ON and OFF times apply to all dates in the block.
I.E. Selecting block Mo, Tu, We, Th, Fr, Sa, Su and setting ON to 10:00 and OFF to 16:00 means that the selected times automatically apply to all the indicated days in that block.
Specifications: 230Vac 50 or 60Hz. 16A Inductive load. 20A Resistive load.
Battery backup >100 hours. Accuracy: +/- 1 minute per month. Temp: -10 to +40 deg C.
Apr 18, 2009 | Hardware & Accessories
Clear all the pre-set channels
There's no clear all settings there. You need to manually delete each saved station. Try to unplug the power of the unit for few hours and check if that clears all.
Mar 16, 2009 | Aiwa Audio Players & Recorders
Clock on system
Please download Aiwa NSX-AJ310 User Manual here.
Hope this manual will help you to adjust clock time.
Sep 30, 2008 | Aiwa NSX-AJ310 Shelf System
Slowdown more than an hour
Maybe the clock is trying to set itself back to its home time;)
Depending on which parts of china you're in, there may be radio wavelengths that is interfering with clock you have, therefore, slowing down the transmitter. of the time.
Nov 21, 2007 | Aiwa FR-A530 Clock Radio
Buttons
i think the best thing to do about it is reset your clock / the button should work than if not i will you some more with it
May 11, 2007 | Aiwa FR-TC5000 Clock Radio
49 people viewed this question
 Grubhead
Grubhead
