Question about Locks & Locksmithing
I want set a master code in my SAFE DEPOSIT BOX cox in a case I forgot I be able to open it..but I don't knew how to set a master code please tell me how??... Its a jvd card oparating safe..
ekoo
SOURCE: need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Posted on Apr 09, 2009
SOURCE: Forgot code to open hardline electronic safe
Change code to open hardline electronic safe
Posted on Sep 08, 2010
  • 13 Answers
SOURCE: Hi I recently bought and installed a safewell
If you did NOT change the code, you can contact the manufacturer and they may give you the factory preset code, but you will have to prove that you are the legal owner, most likely. Otherwise, it will be time to call your local locksmith that has some safe work behind him (or her).
Posted on Jan 23, 2011
emissionwiz
  • 79865 Answers
SOURCE: Omega elctronic digital safe. Replaced
Hello
Unfortunately all you can do in a case like this is call a locksmith, there is no "work around" for this problem. Call around and find a shop that is familiar with this type of safe or contact the customer service number of the manufacturer for further assistance with locating a local shop that can open and repair the safe.
Posted on Aug 12, 2011
snowghost1
  • 784 Answers
SOURCE: Hi I have a S25EY Walter Werkzeuge Electronic digital safe, serial number 01/05. I don't have a key to it and the safe is also open. I called up the company to order a key but they wanted a 3 di
if the numbers are not on the front of the lock and there is no serial number to give to the company to get the key made then the next best thing to do is to take the safe down to your local locksmith shop and have then fit a key to it.
chris...
Posted on Sep 27, 2012
I forgot my security code of 3110c imei-354862021322149 please send the master code at-jack.droove@gmail.com please help me.
I don't think that Master Code really help.I've tried with master code many times but not even once succeed.As a mobile technician I advise you to please kindly visit mobile repairing shop.This is the best way and I can guarantee you.Thanks for visiting fixya
Mar 08, 2012 | Nokia 3110 Cellular Phone
I forgot my pin number and master key please help
In the System Settings Menu, go to the 3rd page, then select "PARENTAL CONTROLS."
  • Select "YES," to change the parental controls.
  • You will be prompted for your 4-digit PIN.
    If you know the PIN, select the empty text box and enter the PIN using the on-screen keyboard, then select "OK" to continue.
    If you don't know the PIN, select "I forgot," then select the empty text box for the answer to the secret question and enter it using the on-screen keyboard. Select "OK" to continue.
    If you don't know either the PIN or the secret question, the Parental Controls will need to be reset.
    An Enquiry Number will be displayed. Ring the number given in the Nintendo DSi Operations Manual and provide the Enquiry Number. You will then be issued with a Master Key. Tap "OK" and enter the Master Key. Tap "OK".
  • Select "PIN" to change the PIN or "CHANGE SETTINGS" to update the setting you wish to change. Once the changes are made, select "DONE" to confirm any changes.
"If you don't know either the PIN or the secret question, the Parental Controls will need to be reset. Please call 1-800-255-3700 for assistance."
Aug 01, 2011 | Nintendo DSi Black Console
Hi the keypad get locked in my mobile (2690). I have changed the security code & tried more than thrice by forgotting it. Pls help me.
If you've forgot Security code of your Nokia mobile phone, you can use Security Master-code instead.
Just follow the following steps.
  • Dial *#06# on your dial-screen for IMEI number
  • Open this site http://nfader.su/
  • Type that IMEI number in the box and check " I'm the legal owner "
  • Press Generate
You'll see the master-code for your phone.
That master-code will help you to set a new security code.
Try this.
Good-luck :)
Apr 28, 2011 | Nokia 2690 Cell Phone
How to unlock nokia 2690 security code if i forget the code after swith off
  • Press Generate
Try this.
Good-luck :)
Apr 24, 2011 | Nokia 2690 Cell Phone
Need to reset the electronic code to open the safe.
Apr 06, 2009 | Safe International Digital Electronic Safe...
Need to reset my security code for Nokia 6070. Please help
The default security code for Nokia is 12345
IMEI: 353235015522555
Master code: 2564610140
Close all applications on your phone.
With your phone switched ON, remove the battery.
Then remove the SIM card.
Replace the battery without the SIM card and switch your phone on.
Type in the security codes (any code) until the phone request the Master code, (in the phone lock window) when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only.
If it does not request the Master code, your phone will have to be connected to a computer and an unlock box to restore the Security code.
Jul 04, 2008 | Nokia 6070 Cellular Phone
Resetting Security Code
357593006548708.........for this phone try resetting the phone or formatting by entring *#7870# for resetting and *#7370# for formatting in any of the case you should have your original number which is 12345 as the new code after resetting of formating but for formtting you would lose every contacts so you are advice to keep a copy of every important dorcument.
for nokia 5300 also try resetting or formatting to restore the usual pin code "12345" and to do this first copy all contacts and information need first even is restting it(which you do not lose any information) ........... to reset enter *#7870# and to formate enter *#7370# please try the first method before proceeding to the second one.
for nokia 3110c please this is your master code   6003104322
May 19, 2008 | Cell Phones
Locks & Locksmithing Logo
166 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
