Question about Kenwood TS-480SAT
Kenpro Keyer
Hi I tried my Kenpro squeeze keyer KP-100 in both keying the sockets but it doesn't operate, can you pease help Thanks Roger
Connect cw to IC-735
The ic-735 has to have the keyer option to use with a paddle, if it doesn't you will have to use an external keyer with it
Jan 17, 2014 | Radio Communications
How to connect sb-200 to ic-7600
you really need a amp keyer interface, these new radios are voltage sensitive, I use ameritrons http://www.ameritron.com/Product.php?productid=ARB-704
Nov 19, 2013 | Icom Ic-A110 - VHF Air Band Transceiver...
Fit
hi there!
The program doesn't fit on computer screen because the resolution of computer screen is too low. could you right click on the desktop and change resolution of screen to higher. I guest your current is 800x600. Change it to higher will fix your problem.
( another way to change to enter button is using Tab key on the keyboard. Every time you hit Tab key, it will move to next button on the program.Try Tab and hit Enter on the keyboard.)
Hope this will help.
Jul 30, 2013 | Avanquest Fix-It Utilities 10...
Ok my 97 grand prix has a no start condition when the switch is turned the engine turns over its getting spark it has a new fuel pump. But the fuel pump doesn't come on when the switch is turned on and...
Hi
I would strongly suggest you get a diagnostic test carried out to verify this fault, althoug it sounds like a main engine relay or ecu problem.
I am sure there are mobile technicians in your area who can pop round and test this fault for you.
Thanks
Roger
Apr 24, 2017 | Cars & Trucks
Try to hook up cw key but it keeps beeping
I cannot say for sure with that particular model, however I did have a radio that would do the same thing, and found that the wiring was shorting out at the terminal end causing the cw key to key itself multiple times. you might check that, or make sure that the wiring is correct for that particular radio.
Feb 21, 2013 | Alinco Dx-Sr8T 1.9 - 29Mhz Ssb/Cw/Am/Fm...
How to get my puk code in online help
Hi do not enter any number if you don't make sure,First try to enter the number which is written on the back side of the Sim card for once.If it doesn't help call/contact your sim card operator.They are the only one who can solve your problem.Personal Unlocking Key is a unique key which is maintain by particular Sim Card operator.If you enter wrong key repeatedly your sim card will damage.So, do as what I have said to avoid "Sim Card Rejected".Thanks for visiting fixya
Jul 09, 2012 | Nokia 3110 Cellular Phone
Heathkit hd-1410 keyer owners manual
try to search in goggle or ask your provider how you can get this manual.
Dec 08, 2011 | Office Equipment & Supplies
Windows 7 drivers for my fx 5500 graphics card, tried using the vista drivers and they wont load pease help
This video card is not compatible with Windows 7 - it doesn't meets the minimum requirements: it's not Dx9.2 capable, only Dx8.0.
You will need to buy a new video card.
May 08, 2011 | Nvidia GeForce FX 5500 Video Card Graphic...
Mitone Mitac100 S/No : Mitac 100 BK 00174, purchased at Frankfurt International Airport Taxfree zone on 19 november 2010 with 2 year worldwide guarantee. Connected to my Hi-Fi system but never...
hi there, i also bought my MiTone MP4 player from Frankfurt Airport, and definitely it was the worst product i have ever purchased, from the first day i was defected, it was blinking power ON/OFF as i touch it, i had to keep it fixed beside me to keep it working, after repairing it, i found out it is not charging the battery...
Dec 29, 2010 | Audio Players & Recorders
Roger black treadmill.
i can repair or supply any roger black parts that you would need. contact me on 01706 371711
Jan 27, 2008 | Baby Gear
Kenwood TS-480SAT Logo
35 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
