Question about Home
Galaxy gl1000 lx shower
Ive got a shower a galaxy one r these central heating showers or electric ones please
  • 171 Answers
SOURCE: shower too hot
Hi sallypenn
I'm Harvey the Master Plumber.
Your question seems to be how to adjust the temperature of a shower valve?
I'm going to assume this is a single handle faucet. Most are adjustable under the handle. This is the responsibility of the installer but sometimes they forget and you can't get them back. Anyway this requires a little mechanical ability and a few tools.
First be sure to turn off the water to the faucet, then remove the handle (allen wrench or small screw driver). Most have a temp. adjustment ring right there. Simply pull out, rotate and replace. With some you have to remove the sleeve or bonnet under the handle to expose the adjustment fitting. Reasemble and turn on. It is not uncommon to have to do this two or three times before the customer is happy with the setting. The adjustment fittings usually don't have tenp. setting numbers to go by so it might take a few tries.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 10, 2008
  • 44 Answers
SOURCE: triton opal electric shower overflow pipe
hi rob the problem is due to an activated thermal overheat switch, you cannot reset this unit as once it is activated it will require a new unit, its a nuisance i agree as i come across this regularly, however its condusive of a scaled up unit so you eventually turn up the shower setting higher to get the water hotter, & inturn activates the thermal switch.
According to which model it is the part is not that overly expensive, you can phone triton direct 7 they will post a new spare to you
Kindly
Richie
Posted on Dec 15, 2008
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
  • 14 Answers
SOURCE: Grohe 24'' Relexa Shower Swivel Hand Shower Holder broke!
Try going to this web page and looking up the nearest parts carrier in your area.
http://www.groheamerica.com/t/25_3859.html
sanray
Posted on Dec 29, 2008
  • 659 Answers
SOURCE: Just moved house today, have a sirrus shower 1600- cold water
There is something caught in the hot side of the faucet manifold (main faucet body). You have to remove the trim and guts to access it. Use a flash light and look inside. Hopefully you can find the object. Oh by the way, you need to turn the water off to the whole house to do this. If you don't see anything have someone turn on the water slowly with the valve out of the manifold to rinse out the pipe leading to the valve body. Hopefully it will remove whats in there. If what you see is a white looking material that is stiff but brittle, then it's from the water heater and the water heater needs to be replaced. Sometimes there can be small stones that get "washed" into the lines when the main is worked on within the area of your home. But most likey it's from the water heater. Good luck! Don't forget to turn the water off before you remove the faucet guts.
Posted on Mar 21, 2009
Problem with Shower Hardware
i am not sure as to how your central heating has anything to do with your shower, is this feed from your heating system, i would find a plumber and have it looked at
Nov 22, 2013 | Home
I have a Potterton Combi Puma 80e When I use the shower the pressure seems to drop and shower goes cold! except when the central heating is on shower works fine
Does the red status led in the centre of the control board come on when hot water is drawn? You need to remove ONLY the front decorative cover to see the control board, two fixing screws at the base of it. If not the boiler won't fire when the CH is off.
The trigger for this is a pressure switch, replacement of which is beyond DIY scope.
FYV
Feb 11, 2013 | Water Heaters
My galaxy aqua 2000 shower has started to cut out the last 2 after 10 mins. I'll turn it off n leave it for 10 mins ten turn it back on then it will happen again. I've taken the head off n
my Galaxy Aqua 2000 Electric Shower keeps running (cold water) even after swithing power OFF it used to completely shut down b4..what should I do 2 rectify the problem ...Please advise.... Thanks a bunch
Oct 18, 2012 | Galaxy Aqua 2000
8" shower head with thermostatic
your litre per minute usage is probley greater than the recovery time on the cylinder..install a dual coil cylinder and pipe a heat exchanger off central heating system through second coil and you shall double the recovery time on tank,both coils should be controlled through pipe stats for effiency purposes
Jan 15, 2011 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
Electric shower hot and cold
it sounds like the flow is too low and causing the heat chamber to overheat ( or the heat sensor is faulty and thinks it is too hot) is the water too hot before it goes cold?
Mar 18, 2010 | Home
Triton jade 2 shower not generating sufficient heat
your element needs de caling i suspect
Nov 11, 2009 | Home
All my radiators dont heat up
I must go to bed now but you may want to try going to http://en.allexperts.com/q/Heating-Air-Conditioning-696/2009/1/COLD-RADIATORS.htm
to see if this helps!
Hopefully someone else at FixYa will help you while I'm sleeping!
Good Luck!
0dc2daf.jpg jackiaria
Jan 31, 2009 | Combi Centre DX - Mango
Water not hot on my eletric shower
replace electric heating elements, probably the bottom one
Jan 14, 2009 | Home
Triton electric shower runs cold
Just a thought!
Dec 01, 2008 | Home
Electric shower
water pressure not sufficient
Mar 21, 2008 | Heating & Cooling
Home Logo
35 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
