Question about Ovens
Omega 00910xa door doesn't seal / close
Tip
Omega europa oven control settings
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
on Aug 30, 2010 | Ovens
I have Omega wall oven model 00652xb 6yrs old, there are dribble marks in between the glass in the door. How do I clean it. I can't see how it comes apart. Thanks
The oven glass is a sealed double pane. it is not designed for removal, separation, cleaning, and reassembly.
May 12, 2016 | Ovens
The door on my la germina oven will not close properly
Sorry, I sent this by accident. Anyway, you can adjust the door to close a bit closer to the frame.
Feb 25, 2013 | Ovens
My JenAir oven door doesn't close fully
most likely you have bad door hinges if the door doesn't close correctly,i don't know if you know this but alot of parts are no loner available for this model,it must be old,the only thing you can get for the door is the hinges and that's it,you'll need the rest of the model number to get the right hinges you're missing the last two letters,you can go here put your model number in to look up parts.
https://www.searspartsdirect.com/model-number/JMW8527CAB/1266/0125300.html
go to door and look at part 16 the hinge,hope this helps you out,when you open the door,if it sags down lower to the ground the hinges are bad,when open it should be at a 90 degree angle
Feb 01, 2018 | Jenn-Air JMW8527C Electric Double Oven
Oven door springs won't close door properly
get an engineer to change the springs for you.
Dec 15, 2011 | Ovens
Can not close the door
how do you mean it won't close?it doesn't latch or are the hindges damaged and the door isn't closing tightly
Apr 16, 2011 | Whirlpool RBS305PDS Electric Single Oven
Omega oven model number is OO910XA
If it is a common problem with Omega, they may not be ready to admit it. Since it occured 2 times, possibly the hinges use nylon rollers for smooth and quiet operation, but the hinges are not well shielded from the hi heat of 500-600 degrees and the nylon parts fail after a few months constant heat exposure. There is a common problem that happens with oven doors when they do not seam to close tight: besides being old and normally worn, if a door is leaned on while it is open, the hinges could be stretched and then they will never allow the door to close tight. This has happened to many ovens regardless of age, and the customer never realized that the weight or pressure they applied to the door when in the open position has done damage; yet they wunder why the door does not close well. Goodluck,Macgivor
Jan 27, 2010 | Ovens
Omega Europa 20-1 oven. What do the symbols mean?
Oct 03, 2009 | Ovens
Oven door not closing
I was having the same problem with my frigidaire oven door. I was thinking that it was the seal getting in the way at first, but then I realized that the hinges needed to be repositioned. I wasn't in the mood for that kind of reengineering, so I came up with a better solution. Magnets. Not those **** fridge magnets either. Neodymium magnets. Place them on the upper part of the inside of the door, near the door lock (outside of the seal). You'll only need about three or four depending on the size. (get the fatest ones you can). If you know a computer geek you might be able to get a few free magnets from an old hard drive. I used five of these and I can just about pull the oven out of it's place while trying to open the door. The onhly problem is that heat destroys magnets and I can't say how long these will last because I just figured this out tonight.
Dec 27, 2007 | Frigidaire Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
