Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
Toshiba 46h84 got new screens. dont know how to install?
  • dennis e younce Jul 14, 2013
    i cant find anywhere where it says what order they go. there is three of them a Screen, Fresnel Screen, Lenticular and Screen, Protector ? any help is appreaicted
    Champion:
  • 247 Answers
Remove the front face u will find the screens start with the one that its inside face is facing the back cover then next and the last as u replace u will have to match the last removed screen and replace it as the first then the 2nd and lastly the one u removed first n there u have it as originallly fitted
Posted on Jul 14, 2013
What order do i install screens
You may want to search for the service manual which should have a exploded view of the screens, the outer one is of course clear and just protective/anti glare, the two inner ones must go in the correct order and both have a side that faces front.
Jul 14, 2013 | Toshiba 46H84 46" Rear Projection...
When i turn my toshiba tv model #46h84 the green bulb lights up the screen but then shuts off and there is no picture! please help me out!!!
I have the same exact problem...for a few weeks the TV would turn off and the red power light would blink. Then the other day I started having exactly the problem you describe...green screen for a few seconds and then total shutdown.
Feb 08, 2011 | Toshiba 46H84 46" Rear Projection...
Sirs: We were just changing channels and the
THE projection bulb is blown if no sound tv probably broken
Jul 31, 2009 | Toshiba 46H84 46" Rear Projection...
Can anyone tell me approx. how much it is to fix a convergence problem on a Toshiba 46'' 46H84 tv? Would it be over $300.00?
Hello, If you were able to do the job yourself the part runs around $80 to $100 but this would require you to understand how to solder. I would say if you this is the case it would be worth fixing. If you took the tv to a repair man it would run you somewhere around $400 to $600 to have it repaired. Im sure you know how much these cost and know that you could buy a better tv for that kind of money. I hope my information was helpful and if it was please dont forget to rate my answer. I hope you have a great weekend. :>)
Jun 12, 2009 | Toshiba 46H84 46" Rear Projection...
Toshiba 46h84 rear projection shutting down
I have a Toshiba 46h84 with similar problem that needs a new green crt. Mine does not have a cooling fan. I don't know if having a cooling fan would help the problem, but mine didn't come with one. There are rear projection TV's that have bulbs in them that require a fan. This particular model uses a red, a green, and a blue crt to generate the picture and probably doesn't need one.
May 19, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 46H84 46 in
the tube will be around 400.00 and then the repair tech will want maybe 150 to install. Try this link they may be able to get you one some what cheaper and give free tech support so you could install it yourself.
http://servicemanuals.vstore.ca/
Apr 29, 2008 | Toshiba 46H84 46" Rear Projection...
Blue crt assmbly maybe?
its very possible that the blue CRT is horting the set out. Heres how you can test it. Remove the speaker grille and access panel behind the grille and you will see the crts. remove the blue crt circuit board from the end of the blue crt and make sure it isnt touching anything then try powering up the set if it doesnt shut down then you have found the problem and you will need a new crt. or you can switch the blue circuit with the green and try it iwth the blue on green and the green on the blue then if the screen turns green before shutting down you will know that its a problem in the blue drive circuit and not the crt. lety me know if you need further assistance.
Apr 01, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 46H84
May you should buy for another one or if it has a waranty , go for a replacement, or check for a nearest TV Electrician!
Apr 05, 2007 | Toshiba 46H84 46" Rear Projection...
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
