Question about Asko D5654XXLHS Hidden Control XXL Dishwasher - Stainless Steel
Display showing door is not fully open, will not go away.
Flashing symbol of door not fully open. Seems like a bad sensor somewhere. Anything I can do myself to get this machine going ?
Hotpoint washer wont work
From the manual page 24:
'Door' is flashing in the display window...
?Shut the door firmly, until it clicks.
The symbol should now go out.
I suspect the door sensor has failed. It thinks you haven't closed the door, so it refuses to do anything at all. It's called a Door Interlock, it has a switch or sensor built into it.
First try unplugging the washer for 60 seconds and plugging back in to try to reset the controller. (Dry hands only!)
If the door interlock is a simple switch, you should be able to check it with an ohmmeter. I would check it first before buying a new one.
The part number is HPTC00085194 or C00085194, here are a couple places you can buy one. You can also find them on ebay.
Washing Machine Door Interlockby Indesit
Door Interlock Washing Machine
WASHING MACHINE DOOR INTERLOCK C00085194 design may vary
Sep 21, 2016 | Hotpoint Ultima WF860 Front Load Washer
Zanussi zwf14280w has a lock symbol on the time display and won't let me do anything. Have checked filter
The lock symbol is indicating that the door is not locked, and until it is, the washer will not commence the programme.
Make sure you have the door fully closed, and that it is latching properly, if it still does not work, then you may have a faulty lock, or a broken spring in the door handle.
Hope this helps
Nov 03, 2012 | Washing Machines
Display shows flashing 'door' warning,even though door is closed.....then when door is opened/closed a couple of times display will dissapear and re-appear every 3 seconds or so. Help!
The symbol indicates there is a problem with the door lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention. Sorry- Service call!
John C
Mar 09, 2011 | Washing Machines
I have had a zanussi zwf16581g for 1 month and has been working fine until today. Its beeping at me and a loock symbol is flashing on & off. it wont let me do anything.
Hope this helps.
Jan 09, 2010 | Zanussi Washing Machines
Door lock symbol showing on screen and door will
Assuming child lock is not on...Water not fully going away/ blockage @ filter.
Nov 02, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
The garage door opener is not cycling all the way closed, before returning fully opened. It is traveling about two feet down before stopping and gong back to the opened position. There is no obstruction in...
If the main lights are flashing 10 times it is a door sensor problem. If the lights are not flashing it is a bad RPM sensor board which is a small printed circuit board just in front of the motor. It can be purchased at Sears or any good door opener service company.
Sep 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Fisher and Paykel model RF610 approx 4 months old door warning goes off as soon as fridge or freezer doors are opened. error code F24 showing in display screen also spanner symbol icon thingy flashing.
The F24 error show that the sensor in the ice maker is out of normal ranges. The usual fix is to replace the sensor in the ice maker.  Also worth checking it to see is the water to the ice maker has frozen up in the value (switch the fridge off for a day). If the error still exists after that you will need to replace the ice maker sensor. You have a 2 year warranty on these parts so the fix should be free.
Dec 19, 2008 | Refrigerators
Ricoh Aficio340
Well, you sound like you figured out part of your problem. If the open door symbol is showing, then you need to find out which door the machine thinks its still open.
Check all the doors, front, both right and left doors, and if the machine has a bottom console, then check those doors also.
I would open every door and reclose them again and see if you can get the DOOR OPEN symbol to go away. Need to start with the basic first.
Once this is cleared then we can see if we can troubleshoot any other problems.
(Most doors have a little stub that sticks out that either goes in between a sensor, or pushes on a switch to tell the machine that the door is closed.
If after opening and closing each door, and the machine still says Door open, then Next step I would take is to see if there are any places on the door that looks like a small piece of plastic might have broken off.
Let me know what you find.
Good luck.
Mac
Mar 29, 2008 | Office Equipment & Supplies
Beeping, flashing, oven door locked, display shows F-1
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) BUT you also need to check the Oven Temperature Sensors The Oven Temperature Sensors should read room temperature, 70°F, the resistance is 1000-1200 ohms. make sure you pull off the wires to measure the sensor's resistance and it reads open it is bad. and you will have to replace it too. hope this helps.
Sep 05, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Asko D5654XXLHS Hidden Control XXL Dishwasher - Stainless Steel Logo
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
