Question about Garden
Don't know the correct choke switch position up or down to start
  • 53 Answers
Remove the air filter cover and filter, look at the front of the carburetor and move the choke lever until the butterfly in the front of the carburetor closes, that is the start position.
Posted on Jul 15, 2013
How do you start it/
Check:
- Gas in gas tank
- Oil level correct.
- Tiller drive in off/disengaged position.
Start procedure:
- Fuel selector - ON
- Ignition switch - On
- Choke - On
- Throttle position - Slow
- SAFETY - No children within 10 feet/
Pull Starter rope......
Repeat 3 - 5 times only.
If engine starts, release choke as required until engine runs smoothly.
If no start,
- set Choke to OFF, Throttle to FULL,
- pull starter rope 3 - 5 times only.
- if start, reduce throttle to obtain smooth idle
- if No start, start check for:
- Spark at plug
- Fuel in the jug
May 22, 2015 | Garden
Husqvarna 236 brand new will not start
1. Make sure you have used the correct fuel to oil mix in the tank.
2. Set on/off switch to ON position.
3. Pull out the choke switch to (full choke position)
4. Prime the carb by pumping the primer bulb on the carb until fuel fills the bulb.
5. Pull over saw until the saw fires.
6. Push in the choke switch.
7. Pull over and the saw should start.
May 09, 2013 | Husqvarna Garden
1985 c10 choke stuck open it's cold and damp
Absolutely not, the automatic choke is defective. Replace that and it should be fine. It will need to be adjusted when cold to fully closed position. Check vacuum lines as vacum pulls the choke back when engine is started.
Nov 18, 2017 | 1983 Chevrolet Silverado
Homelite chain saw MODEL UT109460 will not start up I don't have a manuel and need help to figure out why it won't turn on at all.
Hello again Asher, I'm back. Let's just check a few things:
Gas may be old and stale, this happens when you don't use machine for a long while. Empty old and put in new. Cap should have measurement.
If this is a fuel/oil mixture machine, did you use straight gas? Not good if you did. This could damage your engine.
Do you have spark? If not did you move OFF to ON switch?
Did you put on choke and pull cord till engine almost starts?
If it does this did you then put choke to 1/2 choke?
If you get to this point and engine does start, let it warm shortly and put choke to open.
If still no start it is possible that you have a carburator problem, and need a rebuild. Please let me know how you made out, GOOD LUCK.
Oct 22, 2011 | Homelite ZR10926 16 Chain Saw
I can't start my echo leave blower - 4131H, should the choke be in the high position?
There really aren't any "choke" diagrams on your model. There ARE parts listings, but they don't list the orientation of the choke lever is start position. Try removing your air filter element . Then open the throttle all the way. This will allow you to view the choke plate on the carb itself and what it is doing.
Sep 09, 2011 | Garden
My Luxpro psp511 ca is locked and I don't know how
TO LOCK THE KEYPAD: Start with the System Mode switch in either the
HEAT or COOL positions, and the Set Slide switch in the RUN position.
Perform a single press of each button, in the following sequence: NEXT,
NEXT, NEXT, HOLD.
TO UNLOCK THE KEYPAD: Start with the System Mode switch in either
the HEAT or COOL positions, and the Set Slide switch in the RUN position.
NEXT, NEXT, HOLD. The padlock should no longer be present, with the
thermostat now unlocked. If the padlock is still on the screen, please try
to enter the 4-button sequence again.
Jun 01, 2011 | Heating & Cooling
Bike wwould not run today without choke pulled all the way out. yesterday much colder choke only half out then pushed in when warm....bike did sit for 5 yrs. added seafoam and 92 octane fuel yesterday...
You are correct, the mixture needs altering.
Start up with the choke in position were it will start, run a few minutes to warm up engine.
Turn mixture screw all the way in, don't screw hard in (Gentle) could damage screw seating, listen to engine when it starts to faulter gradually turn screw out, listening to the engine sound till she is running smooth on tickover. Reve up quick shut down on throttle, and if setup correctly should return to tick over without stopping. Lucky person.
May 26, 2011 | 2005 Triumph Triumph Bonneville
Hi, I bought a used motorcycle (hero honda splendor+), I dont know anything about choke lever. Please tell me what is the use of it ? Advantages & disadvantages of it? And finally which position...
How to use your choke correctly. The choke is only to be used for starting a cold engine. If it is a lever, usually you pull it up for on , and push it down for off. look for some type off arrow, or up & down. To start your cold engine, turn on fuel tap, give full choke, turn key on and press starter or kick start, it is very important that you do not use the throttle while starting with the choke, just turn the key on, and press the starter with full ckoke, and no throttle. Once the bike fires and starts, turn down the choke a little and find a idle, after a few minits, you can turn off the choke and ride off. The use off the choke is only for starting a cold engine.
Aug 02, 2010 | Hero Honda Splendor Motorcycles
Forgot which position switches should be and choke on/off position
choke on when starting one pull or two choke off when running. line up/ down is full choke , slant line is no choke.
Apr 22, 2009 | Garden
Garden Logo
129 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
