Posted on Jul 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannon MP492 printer not acknowledging my doc to scan
I am trying to scan a document and it doesnt acknowledge it.....but makes all the sounds as if it's working. I have unplugged and cleaned the plate glass, although it's not dirty as I don't use it too often.
Iulian_d
Level 2:
New Friend:
  • Expert 46 Answers
  • Posted on Jul 15, 2013
Iulian_d
Expert
Level 2:
New Friend:
Answers
46
Questions
0
Helped
22688
Points
131
But, you can print?! When you scan to PC the page is blank?
Testimonial: "I can scan to a sd card but not direct to my laptop for some reason. It's worked before, so don't know what my problem is!"
5 Related Answers
Anonymous
  • 6487 Answers
  • Posted on Aug 13, 2008
SOURCE: My Cannon Pixma MP500 multi-function
Yes you can follow what mastersaintx solution about uninstalling/reinstalling the device and if still the same problem, the scanner is bad and may need a replacement already...
Anonymous
  • Posted on Sep 11, 2008
SOURCE: Brother MFC 8840, Document Feeder is not workting
ITS PROBABLE THAT A CONNECTOR CAME OUT.REMOVE BACK CORNER PANEL AT FEEDER CABLE TO CONFIRM.
hogie155
Jeff Hogancamp
  • 287 Answers
  • Posted on Feb 10, 2009
SOURCE: scanner is not working and its brand new
ARE YOU USING VISTA? OR WHAT OPERATING SYSTEM ARE YOU USING?IF VISTA YOU MAY NEED TO GO TO THERE SITE AND DOWNLOAD NEW DRIVERS FOR THE PRINTER TO WORK PROPERLY.
Anonymous
  • 375 Answers
  • Posted on Oct 16, 2009
SOURCE: The printer does not acknowledge a cartridge is
So the Printer is not recognizing the Cartridges. In this case, you need to clearly see 2 things:
  1. The Cartridges are compatible with the Printer of yours.
  2. The Contact or the Attaching socket of the printer is absolutely clean and dust-free.
Please see the above points and reply me so that we can proceed further. Thank you Sir, Have a nice day.
Anonymous
  • Posted on Feb 24, 2010
SOURCE: I want to copy something from the glass and not
were you able to figure this out? I'm having the same problem!
Printer wont acknowledge ink loading
Make sure you are using genuine Lexmark cartridges. Refilled cartridges won't be able to register ink levels. If you are using original supplies, it could be just a slight cartridge communication error. Try the steps below:
  1. Make sure the printer is on. Open the printer cover.
  2. The carrier should move to its loading position. Open the latch and remove the cartridges.
  3. Close the latch.
  4. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-insert after 10 seconds.
  5. When the printer turns on, re-insert the cartridges. Close the printer cover.
  6. Check on your computer if ink level is acknowledged.
  7. Try to print a document to verify that the problem is fixed.
2answers
I just bought canon mp492 all in one , trying to print word doc from memory card, but its not working
Memory cards are only for image files. to print a word document, you need to use your computer.
I have a Cannon MX860 printer that is set up for wireless. My linksys wrt54g router is also configured for wireless - I can access the internet wirelessly from my mac but the router will not acknowledge...
You need to scan and view available wireless network in printer select your home network (linksys).
Once the printer is ready to go, plug it in and power it on. There should be an interactive set up screen on the printer that you can use to indicate the appropriate wireless settings. You'll want to use the same security settings on the printer that you have set on your wireless router. I recommend using the WEP settings so you are not broadcasting any of your documents or online activity the neighborhood.
Canon doc 203 both light blinking
1. Switch off the printer (the button Power ).
2. Holding button Resume , include the printer (press the button Power ).
3. Holding button Power , release button Resume (indicator of the feeding/readiness must glow green)
4. Not releasing button Power , two times press button Resume and release both buttons
- under each striking the button Resume indicator of the feeding/readiness changes the colour (one striking yellow, the second striking green). Beside printer, having more one indicator indication is switched (indicator of the feeding/readiness green, indicator mistake yellow)
- after buttons will be отпущены, indicator of the feeding/readiness certain time will twinkle green (time моргания depends on models of the printer), then green fires constantly
- if after these action instead of constantly burning green printer continues to show the mistake, that or you mistakenned in points 1 4 (switch off the printer and repeat with point 1), or beside printer additional mistake, which necessary to avoid, otherwise he will not fall into service mode (that means this mistake possible hear here).
5. Four times press the button Resume (under each striking the button Resume indicator of the feeding/readiness changes the colour, but beside printer, having more one indicator indication is switched: readiness/ mistake).
6. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press once again.
For some printer (for instance, iP2000) for switching off it is necessary to press Power once again i.e. three times contract.
Some printers have two counters абсорбера Main and Platen (Bordless), and if after unset Main waste ink counter ( as is described in this instructions ) after leaving from service mode printer continues to show indication an overflow абсорбера repeat all points to instructions before point 5 inclusive, then instead of point 6:
# For printer iP2000 and iP6220d
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then once press the button Resume (the choice counter Platen waste ink counter) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press once again.
# For printer iP3300, 6210d, pro9000, pro9500
or
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then two times press the button Resume (the unset simultaneously two counters) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press once again. (For printer pro9000 and pro9500 in documentation is specified only this variant of the unset)
Same problem Microsoft document scanner cannot see scanner
did you change o/s //some cases you need a different driver/check their home page(cannon)//oz
169helpful
4answers
My mp620 is out of ink but I just want to scan and it won't let me what do I do?
I have the same model. The only thing that work was simultaneously holding down the HOME and STOP buttons for about 5 seconds. The blinking yellow light stopped and I was able to scan.
It's not scanning anymore!!
If your PC acknowledges your scanner and the scanner does not try to start (no sound or noise) you have a component failure. Without seeing it or knowing more details I cannot offer any more possibilities.
Flashing lights
3. Holding button Power , release the button Resume (the indicator of the feeding/readiness must glow green)
4. Not releasing button Power , two times press the button Resume and release both buttons
- under each striking the button Resume indicator of the feeding/readiness changes the colour (one striking yellow, the second striking green). Beside printer, having more one indicator indication is switched (the indicator of the feeding/readiness green, indicator mistake yellow)
6. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press else raz.
For some printer (for instance, iP2000) for switching off it is necessary to press Power once again i.e. three times podryad.
Some printers have two counters абсорбера Main and Platen (Bordless), and if after unset Main waste ink counter ( as is described in this instructions ) after leaving from service mode printer continues to show indication an overflow абсорбера repeat all points to instructions before point 5 inclusive, then instead of point 6 :
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then once press the button Resume (the choice counter Platen waste ink counter) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press else raz.
or
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then two times press the button Resume (the unset simultaneously two counters) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press once again. (For printer pro9000 and pro9500 in documentation is specified only this variant sb
2answers
Lexmark Z33 Cable Problem
hi dear
trying to change port of usb where your connect, or try to change your USB cable
oke
Reminders and wake-up-alarm problems
Here is how to hard-reset your MDA/Wizard using a key combo - courtesy of a smart T-Mobile tech support help desk guy who wrote a note about it as it's not in official help doc's: 1. Simultaneously hold down the Communication Manager and Voice Dial buttons and put the Soft Reset 'button' with the stylus tip - all at the same time. 2. You see a very scary looking black screen with white letters in System font reading something along the lines of ?Are You Sure? Press Send key to continue.? 3. When you push the 'Send' key, the Green pick-up the phone key process starts 4. Next you will see what made me smile like a kid - Formatting FAT partition and very briefly in matter of few seconds began normal first boot.
k24674
ADMIN Andrew
ADMIN Andrew
