Error code E000020 0234
Please help a know E000020 - is a drum problem 0234 - ?
    New Friend:
Computer conected with machine
Posted on Jul 14, 2013
How to clear error code from my copier?
turn it off at the wall
start again
if error still there need more information to help
what model cannon copier
Sep 03, 2016 | Canon Office Equipment & Supplies
How can I correct SC29-04 on Konica 7255?
The sensor is located on the left side of the drum cartridge it is a sensor that is covered with a white cover to the rear of the drum you must remove the drum to see it clean with cloth not a vacuum cleaner Static from vacuum can destroy it. The clear glass sensor is for paper jams! Located in the middle of the cartridge. Mite also want to know when the last 250K copies PM was done?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 28, 2012 | Konica Minolta TN601K Toner for 7155,...
Canon ir c3220 color copier error E000020-01b0. What means? How solve that error?
Canon Error Code E000020 01b0
Although the yellow drum is indicated, in the link above, please note it may not be the yellow drum if instead it is the:"laser shutter or the plastic actuator on the right side of the front door."
Jan 24, 2018 | Office Equipment & Supplies
Error code sc396
Drum motor bind. mechanical bind or defective motor. Hard to tell without a model #
Mar 05, 2012 | Savin Office Equipment & Supplies
F2 error
Well F2 error codeis on a variety of Sharp copiers, the F2 error code would normally be accompanied by a sub code that indicates the fault, You may please check out the following -
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
You may post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
Sep 10, 2010 | Sharp AR-5316 Advanced Digital Imager...
Canon IR C3200--error code E000020-01b0 explain this code please
Hi there
Error code E000020-01B0
That code relates to the yellow drum unit.
The unit was probably damaged taking it in an out.
Needs to be replaced.
Or try.
1. Information UPDATE UPDATE - the Drum units are as follows:
Yellow - 746
magenta - 215
Cyan - 758
Black - 9
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 04, 2010 | Canon imageRUNNER C3200 Color Printer
I have an e 000012-0002 error on my ir 3100 - can you help please?
Hi error code refers to a drum drive motor error code,
more than likely you have a tight Drum. remove drum and see if you can turn it by hand if not replace the drum unit
Oct 02, 2009 | Canon imageRUNNER C3200 Copier
Cp error code in toshiba
the error code CP indicates that the Main Motor is locked,
**** do not try any of this while the power is plugged in****
****Do Not touch the surface of the drum and do not leave it exposed to light****
Try:
  • opening up the copier and look to see if the fuser unit (under the red cover) is not melted together.
  • if you know how remove the drum and developer unit. (please ask if you need instructions on this) check that everything in there turns freely.
Please let me know if this helps or if you need further help / any parts for this model.
Dec 16, 2008 | Toshiba 1370 Black and White Copier
Systems Error E100
Problem with Canon IR1024 Now the screen is reading System Error E100 PLEASE HELP!!
Oct 02, 2008 | Canon Image Runner 1630 Copier Copier
I need help with workcentre XD130df
J2 means the life of the drum has expired.
If replacing the drum does not fix it let me know.
J2 means the drum has met it's 18,000 page life.
Apr 04, 2008 | Xerox WorkCentre XD130DF Laser Printer
50 people viewed this question
k24674
jasbo
jasbo
