How to connect brother mfc7369n to computer
I connected 1 line to wall tele and 1 line to usb
5 Suggested Answers
  • 333 Answers
SOURCE: connecting printer to computer
The manual shows USB connections for this printer.
http://welcome.solutions.brother.com/bsc/public/eu/gb/en/doc/manual_index.html?reg=eu&c=gb&lang=en&prod=mfc5440cn_all&type2=8&flang=English&dlid=
Posted on Apr 19, 2008
SOURCE: Brother MFC-240C
lift the scanner cover until locks into the open position.
you will see the usb socket. plug it
route the cables through the trench out the back of the printer
Posted on Dec 30, 2008
wayneard
  • 1901 Answers
SOURCE: Correct USB cable
Any good USB cable will work. There is a note, however in the user guide that it should not be longer than 6 feet. (1.85M)
For reference: HL-5240 User Guide
Posted on Jan 13, 2009
micromaster
  • 3614 Answers
SOURCE: I have a Brother HL2070N
hi there,
Because printers and networks vary, the best instructions for setting up and networking your printer should be in its users manual. Also, your network-ready printer may have come with installation software that can help you share the printer over the network.
There are three main steps you need to take when networking a printer, including the following: Enable the File And Printer Sharing setting, Make the printer available to all users, and Direct PCs to the printer.
For detailed instructions on sharing printers at home, please refer to the "Get Your House In Order" article in the "See Also:" section below.
For detailed instructions on sharing printers in a small business, please refer to the "Select & Share The Right Printer For Your Small Business"
Posted on Apr 14, 2009
Check connections
The connection of the USB cable
Verify that the USB cable is connected between your Brother machine and your PC.
The connection of the LAN cable (if applicable)
Verify that the network cable is connected between your Brother machine and access point and the machine is powered on.
1.Access point/router
2.Wired Network machine (your machine)
3.Wireless capable computer connected to the access point/router
4.Wired computer connected to the access point/router
The connection of the Wireless network
2.Wireless Network machine (your machine)
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 7840W Printer
Need to hook up a brother MFC-210c so it can fax
Install the software (Brother MFLPro0 relevant to the printer. If you do not have the original CD download the appropriate suite from Brother Solution Center.
When you install the software you will be asked to choose USB, or Local Network. You can always install the USB and connect the printer to the calculator through USB. Different installations for different connection types (USB, LAN)
After you configure the software, you can open the Control Center 3 software and use the fax.
To be able to fax, you need to connect a telephone cable to the port marked line. After you do try pressing the unhook button. If connection to the phone line is correct you will hear the tone.
The MFC can fax without being connect to a computer, just the phone line.
Jul 30, 2012 | Brother MFC-210C All-In-One Printer
Help connecting brother fax machine
1. Connect the handset.
Connect the curled handset cord to the bottom of the handset and to the left side of the machine.
2. Connect the power cord.
3. Connect the telephone line.
Connect one end of the telephone line cord to the jack labeled LINE on the left side of the machine. Connect the other end to a modular wall jack.
WARNING
 This machine must be grounded using a three-prong plug.
 Since the machine is grounded through the power outlet, you can protect yourself from potentially hazardous electrical conditions on the telephone line by keeping the power to your machine on when you connect it to a telephone line. When you want to move your machine, protect yourself by disconnecting the telephone line first, and then the power cord.
 Lightning and power surges can damage this product! We recommend that you use a quality surge protection device on the AC power line as well as on the telephone line, or unplug the lines during a lightning storm.
Dec 30, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Want to use printer to scan document to my computer, printer says to check connection when scan button is pressed. printer is directly connected to computer via USB. what do I do now
USB/PARALLEL CONNECTION USERS:
The Check Cable message generally indicates that there is a communication or connection loss between the computer and the Brother Machine. To resolve this issue perform the following steps:
PART 1: VERIFY THE CABLE CONNECTION
1. Verify that you are using the proper interface cable with your Brother machine. Brother recommends you use an interface cable that is 6 feet (2 meters) or less, directly connected from the Brother machine to an available port on your computer.
a) For USB cable users, a type A/B 1.1 or 2.0 USB cable is recommended.
b) For parallel cable users a Shielded IEEE 1284 compliant cable is recommended.
c) Other cable configurations may work, however connection loss is common. For troubleshooting purposes, do not connect your interface cable through any hubs, splitters, docking stations, or other pass-through devices.
2. Check the cable connection to the brother machine. Remove the cablefrom both the computer and the Brother machine. Leave them unplugged for a few seconds, and then reseat the cable on both ends to ensure a secure connection. For USB users, ensure the USB cable is plugged into the Brother machine's USB Port, not the LAN port if applicable.
3. Restart the Brother machine. Cycle the power off for 15 seconds, and then back on.
PART 2: VERIFY THE DRIVERS ARE INSTALLED
1. Open the Scanners and Cameras Control Panel: Click START -> (SETTINGS) -> CONTROL PANEL -> SCANNERS AND CAMERAS (Note: You may first have to click on PRINTERS AND OTHER HARDWARE or HARDWARE AND SOUND)
2. Verify that the Brother scanner is listed. If the Brother scanner is listed, continue to PART 3. If the Brother scanner is not listed, continue to PART 6 to install the driver.
PART 3: RESTART THE WINDOWS IMAGE ACQUISITION (WIA) SERVICE (WINDOWS XP/VISTA USERS ONLY)
1. On the computer, Click on START -> RUN or in the START SEARCH line.
2. Type: SERVICES.MSC and press ENTER.
3. Locate WINDOWS IMAGE ACQUISITION (WIA) Service, and double click on it.
3a. If you are not able to locate the service, this indicates and operating system issue. This service exists on all Windows XP/Vista computers. Contact your computer OEM for further support.
4. Check the STARTUP TYPE, and make sure it is set to AUTOMATIC. If itis set to anything else change it to AUTOMATIC.
5. Verify the Service Status.
a) If the Service is STARTED, press STOP, and then press START to restart the service.
b) If the Service is STOPPED press START to restart the service.
*Note: If you receive any error message while restarting the service, orare not able to start the service this indicates an operating system issue. This service controls all scanning operations. If the WIA Service is not started, you will not be able to scan from any scanner, and refer to the Computer OEM for further support.
6. Close WINDOWS IMAGE ACQUISITION (WIA) Service, and close the Services window.
7. Attempt another test scan using the SCAN button on the Brother machine. If the scan is unsuccessful, continue to PART 5.
PART 5 - APPLY THE SCANNER PATCH BrWIARegRepair.exe (WINDOWS XP/VISTA USERS ONLY)
1. While connected to the Internet, on your computer, Click on START -> RUN
2. Erase anything in the open box and type: http://209.215.81.199/download/mfc/BrWIARegRepair.exe
3. Click OK
4. Click SAVE. For the Save-In location choose DESKTOP and click SAVE again. This will save the file to the Desktop.
*NOTE: If DOWNLOAD COMPLETE appears, click CLOSE
5. Go to the Desktop and locate the zip file BrWIARegRepair
6. Click UNZIP. You will receive a message stating: 1 file unzipped successfully. Click OK and close the WinZip Self Extractor window. Thefile will automatically be extracted to a Brother folder on the desktop.
7. Go to the Desktop and locate a Brother folder. Double click the Brother folder and then double click the BrWIARegRepair.exe file in the folder.
8. When you see the following message: SETUP COMPLETED PLEASE CLICK OKAND THEN RESTART WINDOWS FOR THESE SETTINGS TO TAKE EFFECT. Code X. (NOTE: X will be 1, 2, or 3). Make a note of the code and restart your computer.
9. Once the computer restarts attempt another test scan using the SCAN button on the Brother machine. If the scan is unsuccessful, continue toPART 6.
PART 6: UNINSTALL AND REINSTALL THE BROTHER DRIVERS
Before you perform the uninstall, ensure that you have the software CD or access to the Internet to download the software needed to reinstall.
1. On the computer click on START -> (ALL) PROGRAMS -> BROTHER -> MFL-PRO SUITE -> UNINSTALL. If the software is not present continue to step 4.
2. When asked to confirm that you want to completely remove the software, click OK.
3. When the uninstall is complete, you will be prompted to restart the computer. Click YES.
4. Once the computer restarts, reinstall the software. For instructions, refer to the solution: How do I setup/install my Brother machine with a local (USB/Parallel) connection? #OR- How do I download and install my Brother machine using a local (USB/Parallel) connection?
5. Once the software has been reinstalled, attempt another test scan using the SCAN button on the Brother machine. All drivers have been reinstalled, and the issue should be resolved.
Oct 31, 2010 | Brother MFC-685cw InkJet Printer
I got a new computer EMachine. I wanted to hook up my Brother MFC 420 using my CD, but no luck. Maybe I have it hooked up wrong. My last computer had a telephone line hook-up. but new one doesn't. I...
Hello s_fields75. I just read your problem and was wondering if you checked your cable connections. You stated that you may have hooked it up wrong. I would definitely make sure your cable connections, USB, etc., are correct. The printer is an all-in-one and should just automatically find the connection through your modem for the fax feature. If not, you might need to get a splicer for your phone line (you can pick one up at radio shack for less than $10). Unhook your phone line from the wall jack. Plug in the splicer into the wall jack, then plug the phone cable into one jack and your fax phone cable into the other. That should do the trick. If not, you may need to download an updated driver from emachines or brothers' websites. Hope that helps!
Sep 22, 2010 | Brother MFC 420CN All-In-One InkJet...
Connect mfc 7340 to pc without phone line
The MFC-7420 connects to the computer using a USB cable.
May 10, 2010 | Brother MFC 7420 All-In-One Laser Printer
Yes you will need to install the drivers and connect with a USB cable. The CD that came with the machine. Remember to connect the cable only when the installation says to.
The only thing that will require phone lines is for the fax. You need to connect the phone lline in the jack called line on the machine and other end should go straight to the wall jack.
Apr 02, 2010 | Brother MFC 7420 All-In-One Laser Printer
Don't know how to connect with phone and computer
USB Cord (Included with Printer) ---Connects to PC (computer).
Phone Line Goes From Wall To Printer (For Fax)
There Should be a seperate jack for both Line-In/Fax....and Phone......The Phone goes out to your phone handset
Apr 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
Setting up my mfc-440cn brother
Im guessing the "Brother" is a printer....the Printer should connect using a usb port, Unless its an ethernet port for the printer then you will need a router to connect both printer and computer. Are you using a High Speed connection or a dial up connection?
Nov 17, 2007 | Computers & Internet
41 people viewed this question
k24674
jasbo
jasbo
