Question about Brother ML-300 Typewriter
New Cartridge Will Not Drop
We installed a new cartridge in an ML-300 and not the print cartridge will not drop down to near the print wheel. I have tried the control Q (reset) with no luck. When you turn on the typewriter it will only move to the left side and make a few noises and then start beeping. Any suggestions? Thanks.
  • lovebohn Aug 31, 2007
    I checked the print hammer and it sits in the same spot as another working brother typewriter. I tried pushing it ahead more and it did not change anything. Any other ideas?
  • 481 Answers
Make sure the print hammer is pushed forward as far as possible so that it is latched
Posted on Aug 29, 2007
HOW DO I INSTALL INK
Sir/Madam
Tell Me Your HP Printer Model Or You Can Perform These Below Step To Change HP Printer Ink cartridge,
Step 1: Open the printer
Turn on the printer. Press the Power button if it is not lit.
Open the printer cover, then wait until the print cartridge cradle moves to the right side of the printer and is idle and silent.
Figure 1: Raise the cover
Step 2 - Remove old cartridges
1 Press down lightly on top of the cartridge latch.
2 Pull out the bottom of the latch to unhook it.
3 Slide the cartridge out.
Step three: Use a cartridge protector
If you are temporarily removing a working cartridge (for instance, removing a Black cartridge in order to install a Photo cartridge), put it in a cartridge protector. Cartridge protectors come with Photo cartridges.
4100022b-6f18-428e-a2bc-bbd00a59c50f.gif 12806acc-4ccc-4074-b41c-6ca5d04702b4.gif
Step 4 - Make sure the new cartridges are compatible
Step 5 - Install the new cartridges
Figure 6: Remove the protective tape
Figure 7: Contacts and nozzles
1 - Contacts
2 - Nozzles
Hold the print cartridge so the nozzles are down and the contacts face toward the printer, then slide the cartridge into the carriage.
Cartridges marked with a triangle go into the left carriage slot.
Cartridges marked with a square or pentagon go into the right carriage slot.
Figure 8: Put each cartridge into the proper slot
3 Push down on the print cartridge latch until it snaps closed.
5e2afb9d-cef4-415d-bd5c-a6c08dc7a1c6.gif acbe1f2c-5f74-4596-9d01-84173e86e0c8.gif
4 Close the printer cover.
Print cartridge maintenance
After removing the print cartridges from the printer, it is necessary to follow basic care and maintenance guidelines to keep them from drying out. The following guidelines will help maintain HP inkjet print cartridges and ensure consistent print quality.
Do not reattach the plastic tape that covered the ink nozzles since this can damage the nozzles.
Store the print cartridge(s) in a print cartridge protector or airtight plastic container. If the cartridge is stored in an airtight plastic container, make sure the nozzles face down and are not in contact with the container. Do not use plastic bags: this may damage the print cartridges.
Placing a moist paper towel in the airtight container may help to keep the cartridges from drying out.
A print cartridge protector is provided with the photo print cartridge.
To insert the cartridge into this protector, slide the cartridge at a slight angle into the protector and snap it securely in place.
To remove the cartridge, press down and back on the top of the protector to release the cartridge. Slide the cartridge out of the protector.
Do not drop the print cartridge since it could be damaged.
In case You still Having Problem Then I suggest You Visit HP Printer Official Website
Removing and Installing Print Cartridges
Or
still Having Problem Then Follow Us On:
HP Printer Support
Feb 13, 2014 | HP PhotoSmart Office Equipment & Supplies
I do not know how to replace the ink in my canon ip2600.
Open up printer cover. Search for button on printer with ink drop printed on it or near it. Press that button, and print head will move to position from where you can change ink cartridges. To get one cartridge out, pull a small lever on cartridge end and it will pop out. To put new cartridge in, just get it into position and click it in.
Mar 06, 2011 | Canon Pixma iP2600 Photo InkJet Printer
I just installed a new color cartridge for an HP 5650 Deskjet printer but it only prints in black. I'm printing from a MacBook, OS 10.6.6
Hi, Try printing whatever you were wanting to print but click the drop down arrow right next to the printer selection tab. Then you should see a drop down menu about halfway down the menu, click it and select print settings. You should see another drop down menu called color, just click it and change it from grayscale to color.
Hope this helps, Justin
Feb 13, 2011 | Apple MB985LLA 15.4" Macbook Pro Notebook...
Lexmark X3650 all-in-one Printer, have refilled colour cartridge with inkjet refill kit but still indicates low-ink level, and will not function. Do I need a resetter?
Go to all in one program
at the top left click on Maintain\Troubleshoot
Right window click on Device Status And Ink Levels
that will open a new window
Click on The button that looks like 4 different colored ink drops
Click on Install a new print cartridge
Click on Next
Now you should be in Select The cartridge installed
Open lower drop down window and click on No its new
Follow the prompts from there or click OK
This should fix the problem.
Oct 21, 2009 | Lexmark X3650 Printer
Epson CX8400 ink cartridges run out early
Epson gives you a miserable 12 ml of ink. Then it reports empty when there is still 10-15% of the ink left. I saw someone set up a brand new CX8400, print a single 4x6 photo and it said he was out of cyan. I use reusable cartridges from http://www.ccs-digital.com They hold 20 ml, which is 2/3 more ink. The chips automatically reset to full if you take the cartridge out and put it back in, so you get to use every drop. The ink is in a separate container inside the main cartridge. When it's really empty, you pop out the ink tank and pop in a new one. The tanks are under $3 each. I think this is brilliant because it's like refilling only it avoids the risks and mess of refills.
Jun 14, 2009 | Epson CX8400 All-In-One InkJet Printer
ML-1640 Series + Toner exhausted.+ how to reset the printer.
Jun 09, 2009 | Samsung ML-1640 Monochrome Laser Printer
How do i move the print cartridge to middle
on my printer its a button near the power button, looks like a drop of ink, i have to press it twice, then i can remove the old cartridge and add the new 1
Apr 09, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Samsung printer ML 2510 series
Maybe the toner is low... According to the manual, a blinking red light:
• A minor error is occurring and
the printer is waiting for the error
to be cleared. When the problem
is cleared, the printer resumes
printing.
• The toner cartridge is low. Order
a new toner cartridge. You can
temporarily improve print quality
by redistributing the toner. See
page 8.3.
• The toner is totally exhausted.
Remove the old toner cartridge
and install a new one. See page
8.4.
• The toner cartridge reached the
end of its life.
Feb 24, 2009 | Samsung ML-2510 Laser Printer
New cartridge won't work; old cartridge works (and re-instals) fine.
Check if the Toner is all the way in, you should hear a click, if not then something wrong or you installed it incorrectly.
i had that issue before, i didn't push it all the way in. and it whirrs but doesn't print.
Aug 24, 2008 | Samsung ML 1610 Laser Printer
Samsung ML 2510
It could be a transfer roller thats worn out.
If can be fixed by a technician.
Jun 14, 2008 | Samsung ML-2510 Laser Printer
Brother ML-300 Typewriter Logo
87 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
