Question about Gear4 Lucky Voice Party Box Karaoke Machine
Power supply for lucky voice party box
I lost the power supply adaptor, whats is the power supply of this unit?
No powerfrom the outlet source
The AC adaptor of my Casio Keyboard has reversed polarity from the Standard Power AV adaptor you get in the market. The center is NEGATIVE. When you try to use a new power supply that is NOT a CASIO original, you may need to reverse the polarity of the plug. Check that.
Jun 29, 2013 | Casio CTK810 61 Key Keyboard
I have a electro-harmonix , voice box , harmony machine and vocoder! I need to know what kind of power supply to use , as I have lost mine !
Takes a 9 volt DC 1 amp (1000 ma) center positive adapter. Not too common, search online and at Ebay.
Jul 28, 2011 | Music
I lost the AC/DC adaptor and the PC-via UBS interface for my UBS-24 Digital Voice recorder. Can you help me? How I can receive or find such tools? Thank for your kind reply. Best regards Luigi...
I checked online to see if I could find their website, and I couldn't even do that. Your best bet for finding these things (in my opinion) is going to be on a website such as ebay. Maybe you will find someone who lost their recorder and is just looking to get rid of their leftover parts. Not to mention parts from first party are typically astronomical in price. As far as the USB plug (unless it's special to this device, which I doubt) you can easily take it to a local store such as BestBuy and they should have the appropriate USB plug available for about ten bucks if you can't find it with the AC/DC adapter.
Mar 03, 2011 | Denpa USB-24 Digital Voice Recorder
Brand new Garmin Nuvi 1490 T out of the box. How do I charge it? The only devices in box were a car charger (my commute is 5 minutes daily) and a USB connector? Should I just plug the USB into my computer?...
Garmin satnavs come with a charge out of the box.
In some cases your device may have lost a charge during shelf life. In this case you can charge these units in three ways:
  1. Place unit on computer with USB cable for approximately 8-12 hours
  2. Place unit on Garmin specified AC adaptor for approximately 4-6 hours
  3. Place unit on 12V vehicle adaptor for approximately 4-6 hours.
Some cars continue to supply power to the cigarette lighter socket when turned off and others don't. If yours doesn't you can charge it from your computer. There's no indicator to show that it's charging or when it's charged. However when you disconnect the satnav from the computer and turn it on there's a battery state indicator which shows if it's fully charged or not.
Aug 16, 2010 | Garmin nuvi 1490T GPS Receiver
Lexmark printer x73
you can get the proper power adaptor at just mention them the proper model number of your printer and they will provide you perfect adaptor
www.radioshack.com
thanks
Sep 18, 2008 | Lexmark X73 All-In-One InkJet Printer
2wire 1800hg wireless gateway/router not functioning...
Your power adaptor might be faulty.  Yes, you can measure to have 6 volts.  But due to faulty electronic component in the power adaptor, the 6 volts will be dropped to a very low level due to "loading effect"  when you connect to the router.
I had the same problem but could not find the original power adaptor.  I replaced it with a 3rd party power adaptor.  You must ensure that the 3rd party power adaptor can provide 6V output with minimum 2000mA (2 amperes) and correct connector size.
Apr 07, 2008 | 2wire 1800HG Router (RG1800HG00)
Gear4 Lucky Voice Party Box Karaoke Machine Logo
70 people viewed this question
Top Gear4 Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Gear4 Audio Player and Recorder Expert? Answer questions, earn points and help others
