Toshiba 37c3000a WILL NOT AUTO OR MANUAL TUNE FREE TO AIR DIGITAL CHANNELS
INSTALLED NEW COAX TO TV--TRIED DIFFERENT TV AND GOOD SIGNAL. START SCAN, BUT NOTHING HAPPENS...TOSHIBA SAYS NO SIGNAL
SOURCE: Toshiba D-VR650KU can't "see" digital channels
On the Notification screen with Cable highlighted I found that left clicking on Cable gave a drop down menu with TV on it for selection. The manual says that while Cable is highlighted, use the up or down arrows to get TV to be an option and then select it and Yes and enter. Hope this helps. I have other problems with my monitor on Line Out, the screen oftens turns blue indicating low or no video using Line 1 or 2 inputs.
Posted on Mar 09, 2008
  • 362 Answers
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler, I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth. http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Posted on Jan 13, 2009
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
SOURCE: LCD 32 inch Auto Scan issue
I have experienced exactly the same issue on two Westinghouse sets. Try turning the set off when it reaches 83%. When I turn mine off and back on, it has saved the channels -- at least the ones it had found before it got hung up.
Posted on Jun 21, 2009
SOURCE: Unable to tune my LG Electronics Digital TV (Model 37LC2d-ec) to receive digital channels (have tried auto and manual program). TV will only receive basic standard channels. TV bought in Uk - now livi
My LG plasma TV 50pc3d when power-on only see vertical bars. what 's going on. please help. Thank you
Posted on Jul 22, 2009
New Element TV auto-scan missed some over air channels like channel 6, 6/2 and 6/3
Fine tune the position of the antenna. Sometimes it only takes a slight movement to capture those channels.If you don't have an amplified antenna, get one. That may solve your problem. The tuner will not manual tune if there isn't a strong enough signal for the tuner to see.
Sep 08, 2017 | Element Televison & Video
Cannot tune in my 19 inch Alba tv to main channels ie bbc and itv
POOR AERIAL SIGNAL, CHECK THE COAX JACK IS ON PROPERLY. NO OUTER STRANDS OF WIRE SHOULD BE TOUCHING INNER COPPER CORE. OR CHANGE CABLE & GO INTO THE BACK OF A SKY BOX TO THE TV, THEN RESCAN.
Jan 15, 2017 | Alba Televison & Video
Toshiba Freeview Tv, Model 19A 615 DB. Re-tuning I pressed Menu, Set-up, Restore Defaults, then Yes to delete previous settings, and OK. Absolutely nothing happens, Help please?
hi,
To Re- tune your TV you have to go to the Auto tuning option in the menu. do the following procedure for auto scan all the available channels.
To tune the free view analogue channels do the following procedure.
1. Press the Menu/setup button on the remote.
2. Select Auto tuning and press enter.
3.Select the country and press enter.
4. Select start and press enter.
The automatic tuning will search for available broadcasts and should store the channels in the correct order. During the search the sound is muted. When all programs have been stored, the normal TV screen will appear.
If you can sent your email address through fixya then i will sent the user manual for Toshiba 19A 615 DB.
ok
Sep 07, 2011 | Televison & Video
I have an Audiovox TV Model no. TV92722. There is no Channel 52, 53, and 54 when cable was installed. When it is in channel auto search, it stopped searching. But if manually searching for channels 55 to...
first, make sure the TV in in American Cable mode (ntsc). next do this, menu... tuner... cable... scan... the reason maybe the TV is on TV air mode; but now is receiving cable. from the antenna coax cable. . another reason is that many cableco's now use Switched Digital Video ( a more robust setup) that now requires the Digital Tuning Adapter... also to help prevent free-loading. a last possibility is your (old) TV does Not work on the new cable. A new TV usually cures this ...!
Oct 26, 2017 | Audiovox Televison & Video
Have tried with different ariels and still cannot get any digital channels on tv can get analogue with a struggle tv keeps telling me no signal
First check there are digital channels come in your area?If yes then select digital channel to auto tune. If still have problem then need to replaced tuner.
Nov 04, 2010 | Televison & Video
My digital tuner does not work
have you tried entering the "tuning mode" and scan for possible channels?
if not , check for screen "menu" go to "tuning mode" and select auto scan
Jan 13, 2009 | RCA TruFlat 27F520T 27" TV
Cannot find freeview/digital on our new TV
You can only get the freeview / digital channels through cable by subscribing to a package which includes them. They will then supply the necessary decoder to get the channels. Otherwise you will need a digital aerial and a freeview box if you tv is not dtv ready.
Jan 03, 2009 | Televison & Video
Don't get ABC or NBC local channels anymore
ATSC tuners ("D/A converters") pick up signals off the air just like old school television. It sounds like you are just not getting a signal of sufficient strength. A weak analog signal looks like a "snowy" picture, which most of us are used to. But, the new digital channels quickly go from a perfect picture to none at all. It's basically all-or-nothing.
Try attaching an antenna to your converter. I know you can buy a new antenna from your local big box electronics store which is labeled "Terrestrial HDTV" or something, but that really doesn't mean anything. You can use any old TV antenna. Even a quality FM antenna (with an F-Pin coax connection) may work just fine.
When setting up the antenna, keep in mind that different channels are transmitted from different towers, in different locations with different strengths. Move the antenna placement and position around (just like grandpa had to do). You may have to make a compromise to get the best signal for your favorite channels.
May 15, 2008 | Insignia Digital-to-Analog Converter for...
Feb 21, 2008 | Toshiba D-VR650
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
