Question about Konica Minolta magicolor 2300DL Laser Printer
Magicolor 2300dl My color printer has ssen a lot of use. Now there are shadows across prints like it is dirty. Can I clean something to fix this?
  • 20 Answers
Clean the fuser, opc drum, and the basic inside of the printer with a vacumm. Suck don't blow with the vacuum.
Posted on Sep 05, 2007
In addition to the good suggestion previously posted, it is possible that your toner waste bottle got overly full and that waste toner has backed up into the opc unit (which may be carefully disassembled and cleaned.
Posted on Oct 31, 2007
SOURCE:
Magicolor 2300DL toner all over left of paper
what color toner? cleaned how? might have bad image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 02, 2015 | Konica Minolta magicolor 2300DL Laser...
Why won't my minolta 2300DL print on any kind of vellum? So strange.
well..some printers can't grab that slick of a paper medium..let me show you an old trick we used to use
May 27, 2008 | Konica Minolta magicolor 2300DL Laser...
Red filter on images
replace the color image units with OEM cartridges
Apr 29, 2012 | Konica Minolta magicolor 2300DL Laser...
My Magicolor 2300dl prints light (black and/or colors) on the left side. The right side is fine. I changed the black toner and the drum but no improvement.
This is caused by dirty laser optics. This is a common problem in this series as well as similar HP series color laser printers. You can try cleaned the laser optics **** glass from the cartridge side of the printer but almost always the problem is internal in the optics unit and this requires quite a bit of dis-assembly of the printer. All I can say is if you remove the toner and drum cartridges you will need to look for a thin strip of glass running from one side to the other. Use a cuetip cotton swab to clean the glass then re-install the cartridges. If your lucky this will eliminate or at least make it better. If not then you will need to have the printer serviced.
Good Luck and thank you for using Fixya.
Mar 12, 2010 | Konica Minolta magicolor 2300DL Laser...
Our 2300DL is leaving streaks when printing
Out of one or more toners. If you have removed and replaced a cartridge in error the % remaining is reset to 100%. Try to determine which color is missing in your print out (usually black), and then follow menu instructions to replace that cartridge. The ends are color coded so be sure you change the correct one. This will insure the remaining cartridges % remaining is correct.
Jan 13, 2010 | Konica Minolta magicolor 2300DL Laser...
Poor print quality 2300dl
first did you try to clean laser glass ? and maybe you need a new 2'nd transfer roller.
open front cover and under the pc drum there is a blue knob, pull it out and clean the glass
May 28, 2008 | Konica Minolta magicolor 2300DL Laser...
Magicolor 2300dl ghosting and smear - black only
if only black does that, then it can be black toner, but the best way to find out, print something and when printer starts to take paper open front door, remove waste toner box and take out pc drum and transfer belt and check the printed page from there, if it seems ok, print nex page and open door when page comes out from fusin unit, if quality goes bad before fusing unit, it may lead to 2'nd transfer roller / pc drum and transfer belt quality was ok / if after FU then you have a problem in fusing unit.
Apr 01, 2008 | Konica Minolta magicolor 2300DL Laser...
MagiColor 2300DL Printing Wtih Vista over Wireless Network
I am using Vista 64 and a 2300DL in the same manner as abertola003. I downloaded the Latest driver from Konica Website and everything is working well.
the driver is named Konica-Minolta 2300DL (unidrv)
Cartridge Removal 2300DL QMS Minolta
magicolor 2300 DL procedures
a)From the display, select the menu “Engine”.
b)Select “Replace Toner”.
c) Select each color toner cartridge from this
menu to remove it.
Nov 26, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
446 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
