Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
Blinking codes sony kv bz14m70
Blinking 5 time and pause then repeat again
Vrya
  • 62 Answers
SOURCE: SONY WEGA KV-32XL90E
Hiii...
what chassis your tv set ?
Thank's
[Vrya]
Posted on Feb 19, 2008
Slinteriors
  • 8617 Answers
SOURCE: SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
Posted on May 27, 2008
welcomejee
  • 10594 Answers
SOURCE: KV-32FS120 Standby Timer blinks nine times
what exact model number of your Sony tv is? I need it to arrange the service manual or schematics.
Posted on Aug 12, 2008
  • 30 Answers
SOURCE: My sony TV wont turn on.
Un plug and let stand for one minute. If it still does blink then use the reset on the remote and press it while pressing the power button on the TV.
Posted on Feb 07, 2009
  • 41 Answers
SOURCE: Sony KF-50WE610 Tv won't turn on, red light blinks 6 times
3 times means Lamp and 6 means you have lost a voltage. You may have a thermal fuse blown.
This set has a common trouble with overheating caused by the drum fan located on top of the lamp housing clogged up with dust. When the lamp is getting old it runs hotter and that combined with the fan being clogged the thermal fuse blows. You must replace the lamp and thermal fuse. You must also clean out or replace the lamp fan. This drum type fan should be cleaned out every year or two depending on the environment.
Posted on Apr 16, 2009
How to clear the code fault on my Onan 4000 generator. What causes a fault & why???
what model is it KY KV need that and Spec. If it blinks 3 times it indicates a lower service fault. While blinking hit the stop button 3 times fast, then read the code. It will blink, pause then blink again and repeat. What is that code and I can help you. IE 4 blinks pause and 3 indicates code 43
Nov 13, 2014 | Watts Onan Portable Generator - 4000 ,...
Sony xbr6 standby light blinks 14 times, pauses and repeats
Just count the number of blinks occur at one time. 14 blinks to trinitron TVs are not possible. It might be 10. If so,
  1. Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board. If you wish to know more about blinking codes to Sony Trinitron models TVs, check this link. If it is Intermittent problems? This is a great feature. You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
Jan 25, 2013 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony wega trimitron tv stand by timer is flashing
Check to see if the blinks are in a pattern should blink X number of times pause and repeat sometimes more than 1 sequence will appear. this link has a list of blink codes and what they mean.
the tv dude
Jun 06, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony trinitron
Need a little information here...
1. The TV remains on, yet there is no picture and no sound? Or does the TV turn off altogether?
2. Are the blinks constant and continuous? Meaning, does it blink two times, pause, blink two times and go on and on like that?
3. Can you turn the TV on? Or can you not get it to turn on?
Answer those questions and I can give you some more information or send you to the place where you can get it.
Nov 14, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV-32fs120 Does Not Turn On
i have a unvirasal remote how do iget the codes for it
Sep 29, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32HV600 won't turn on.
If the blink repeats the same number of times (up to 6 or 7) between pauses, the number of blinks is a trouble code. Determine that number (count), then search this site and the web for your TV model and that code. Also look on the rear of the set for the chassis number, and search on that keyword.
Sep 15, 2008 | Televison & Video
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
46 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
