Question about Refrigerators
Wrn52h whirlpool litre size - Refrigerators
Cubic feet of my fridge and freezer model #ED5CHQXVQ00
The model number usually depicts what size fridge it is. ED 5 ?? That would suggest 5 cubic feet. ?? In Australia, fridges are measured in litre size. IE/ a fridge with say a model of HE550 would suggest 550 litres ( a reasonably big fridge)
Apr 09, 2015 | Refrigerators
What does the 4.7 liter stand for on my engine?
That is the size of the engine, they use to use a designation like a 350 cu inch or a 454 cu inch now the use the liter system
Feb 13, 2015 | Cars & Trucks
What size in litres are the 2ovens?
Hi, for the top oven:
Actual capacity 39 litres, Usable capacity 35 litres.
for bottom oven:
Actual capacity 59 litres, Usable capacity 50 litres.
Jan 17, 2015 | Stoves 720EF Electric Double Oven
What is liter capacity 2008 Nisan Dualis?
depending on the engine size, the oil capacity is 4.3 litres for the 1,5 litre engine , and 4.4 litres for the 1.6 and the 2. litre engines
Dec 27, 2014 | Cars & Trucks
Hi there, I've got a wrn52h whirlpool and the lights in the fridge section have both gone out. Fridge still working and switch is ok as motor kicks in/out when i push/release switch. Globes too are...
You will need to replace the electronic control located to the left of the compressor in the back. This board controls the light circuit and I have seen this issue tracing back to the board. The longer you delay in replacing this board, will start to have other issues like dispenser problems and total shut down could be next. I don't mean to scare you but this has happened in the past, all caused but the same failure in the control board. I would need a complete model number with revision number to get the correct part number for you..
Looking forward to help you.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 03, 2011 | Whirlpool ED2FHEXN Side by Side...
What is the litre size of a 2002 hyundai sante fe?
The 4 cylinder engine is 2.4 litre, and the v-6 is 2.7 litre.
Jan 03, 2011 | 2002 Hyundai Santa Fe
TRYING TO FIND ENGINE SIZE ON 1990 NISSAN PATHFINDER SE 6 CLY 4 WHEEL DRIVE
either VG30E 3.0 litre 153 HP V6 or KA24E 2.4 litre 140 HP 4cyl
Jun 14, 2010 | 1990 Nissan Pathfinder
Can one fit a 1.6 litre subaru leone engine EA82, into a 1.8 Litre subaru Brumby/ BRAT that used to have a EA81 engine
It should be possible, although you might need to compare the size of the engine to the size of the compartment, then maybe try a test fit to see if it fits and the mounting brackets line up.
hope this helps.
Jul 08, 2009 | Metra Subaru Lead To Car 87 94
Non selection on auto gearbox from time to time
Would it be possible to have ore info on the car. ie 4 speed or 3 speed. year and engine size thanks
Sep 05, 2008 | Chrysler Voyager Cars & Trucks
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
