Question about Samsung LN46B530 LCD TV
Lightnings like lines on a half screen
I gotta a lightnigs like line on my samsung tv. Looks like magic wand effect in photoshop. Colored in purple and green, mostly seen on faces on tv and appers only on left side of the screen. Please help.
    Top Expert:
  • Samsung Master
  • 75,462 Answers
Must be of a back-light problem. Contact any service technician. This is not a user repairable fault.
Posted on Jul 14, 2013
SOURCE: Purple and white distorted fuzzy lines running up and down and side to side on tv
I just had my lower Y-buffer board swapped out to fix a problem similar to yours. After an hour and a half of on-time, the lower half of the screen would flicker on and off with the same appearance you mentioned. Changing out this particular board fixed it for me. However, since it has gone from top to bottom on your set, it may be more of a main board problem for you (that controls both upper and lower halves). Beyond this, I don't know any more. I am considering getting a service manual to gain more knowledge about the various PCBs in the unit so I can fix any future problems myself.
Posted on Aug 27, 2007
Coldcut
  • 1554 Answers
SOURCE: Static lines one screen
as the top is ok and the bottom has this issue.
It looks like the circuit board has a bad connection to your screen.
it is not repairable by you and not an adjustment.
you need to have it repaired.
don't you miss the old wack on the side fix?
Posted on Feb 17, 2008
circuitworld
  • 335 Answers
SOURCE: green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Posted on Jan 04, 2009
  • 98 Answers
SOURCE: Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Posted on Feb 06, 2009
  • 267 Answers
SOURCE: Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Posted on Jun 26, 2009
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
My TV has been acting strange lately. When I turn it on, the screen looks purple and has these horizontal lines up and down the entire screen. They don't expand to both sides of the screen, though. WHen...
there seems to be a problem in the horizontal circuit...there is a control on the flyback transformer that is labeled "screen". (you'll have to take the back off) The flyback is the component that looks sort of round with the red high voltage lead coming out the top and connecting to the top of the picture tube.On the back of the flyback there will be 2 or 3 controls if 2 there will be 1 focus and 1 screen, if 3 there are 2 focus and 1 screen..using an insulated flat blade screwdriver, slowly turn the screen control counterclockwise to see if this will make the lines go away...if not then there is a horizontal cicuit fault and quit possibly a pincushion problem(hourglass effect)..these will need to be checked by a service shop
Jan 22, 2011 | Sylvania 6432TFY TV
How do I get rid of purple and green wiggly lines? The black screen that appears when switching between channels was green a couple of weeks ago, that problem stopped after I unplugged the set for a while....
You have a bad LCD control board,It overheats and causes colored lines,screen to darken,or the color go floresent. Also check the power supply for bad caps.
when you have it apart.They usualy go bad on these tv's. It will cause the tv to take longer to come on.Or you have to hit the power button several times to get it on.
Oct 26, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung Plasma TV has horizontal lines of colored dots
I have the same problem, currently searching for a solution. Have you resolved your problem yet? Looking to repair myself, any tips or ideas that you have/expirenced would be greatly appreciated. Thanks, Todd
Apr 10, 2009 | Samsung SPN4235 42 in. Plasma HDTV
SAMSUNG DLP TV HLR5067W
The main board is more than likely the cause of the trouble. Time for a new TV.
Oct 29, 2017 | Samsung DLP HL-P4663W 46" Rear Projection...
Aug 19, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical Green/Purple Lines on lower half of screen
I would contact RCA if the repair center dosent know how to troubleshoot this set. But I bet its an eeprom or ground issue. Contact RCA here at 580-634-0151 or At https://www.rca.com/secure/service/contactrca/1,,,00.html Good Luck
Jun 15, 2006 | RCA Scenium HD65W20 65" Rear Projection...
Samsung LN46B530 LCD TV Logo
85 people viewed this question
Jerry Greenberg
Jerry Greenberg
