Sony crt tv (KV-BZ14M70) led blinking five times in stand by mode, so it means
Also green color dominate in appearance on black
5 Suggested Answers
  • 8909 Answers
SOURCE: I have a sony 29''
Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Posted on Mar 28, 2011
sodeep
  • 3267 Answers
SOURCE: I have sony 29'' crt
2 blinks means - over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
Posted on Jun 23, 2011
jdvillanueva
  • 2098 Answers
SOURCE: sony crt tv (KV-BZ14M70) led blinking four times in stand by mode, so it means?
Hi Ullah,
LED blinks four times on KV series means that the Vertical deflection circuitry encountered a problem. You can repair it yourself if you have knowledge in electronics, knowledgeable in soldering and desoldering of parts on the board.
jimvincentvillanueva@yahoo.com
Posted on Jun 14, 2012
gopakumarg43
  • 75581 Answers
SOURCE: sony tv model no. kv-ha21m80 is on standby mode & its LED is blinking FIVE times blinking
Visit this site. Standby LED blinks to Sony televisions of all types are described in detail there. Usually five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 28, 2012
HOW DO YOU ADJUST RED,GREEN,BLUE TUBES
If your talikng about alignment that is done through the Convergence feature. If its the color balance youre refering too its most likley indicating that the CRT coolant needs replacment as that will make the red Tube dominate and wash out both blue and green colors untill they appear dull and dim.
Feb 17, 2011 | Philips 60PP9352 60" Rear Projection...
Grade 6 science quiz bee questions
suppose green pods are dominant and yellow pods are recessive. two yellow podded plants are crossed. what can you tell about the color of the pods of their offspring?
Sep 16, 2010 | Computers & Internet
Its glittery white because i briten the color but when darken it gets green
you must re-adjust in the RGB (Red-Green-Blue) setting. depending on the brand of your TV, because there are set manually from the TV (you must open the cover of the rear of the TV). and there is a set directly from the remote only, with the open "factory settings", then you can re-adjust RGB color, especially green, not too dominant with the other colors (RED-BLUE). how to set is that you need to neutralize the color, (color TV sets to zero level) so that the image becomes black and white. if the green is too dominant, then Decrease the level of Green Bias or Green Cut off/ G-drive.
Aug 05, 2010 | Televison & Video
I too have d same problem..
unscrew the monitor plugs and re seat, often these plugs come loose and the pins fail to make contact reseating them usually solves the color bvleed. other than that you are using the wrong driver
Jun 20, 2009 | SAMTRON 55V 15" CRT Monitor
Same problem w yellow on viewsonic pj550
Yellow is the mixture of 100% red and 100% green. what you may have here is a blue LCD failure in the machine. Try this to check. Open up PAINT and double click one of the colors on the bottom. now click add custom color. then in the RGB section put 0 for red 0 for green and 255 for blue. ok out of everything and fill the background w/ the blue. it should be a VERY intense blue, if its white or or kinda blue, you have an LCD issue
Apr 13, 2009 | ViewSonic PJ550 Multimedia Projector
Dominant blue
Can you post to the party who has too much green how to adjust the video adjustments? They need to know so they can see if
its just a simple adjustment.
In your case, first turn the color level clear down to where you
have a black and white picture. As in the case of too much green,
question is if the picture is black and white or if there is a color
on the screen so its blue and white? I suspect it will be which
is typical when the guns start to fail. Likely the green and red
guns are weak in output. There are screen adjustments in the set that a tech can set up that may help some, but the only real fix is to replace the guns which is expensive and requires a complete allignment. All 3 guns need changing to get it back to spec and it is a good idea to replace the flyback for reliability. Get an estimate and likely you can replace the set for the same money.
Jul 26, 2008 | Mitsubishi CS-27205 TV
Colors Not Plotting Correctly
You should try calibrating the colour and performing a print head alignment, if this doesn't work replace the colour print heads
Jun 09, 2008 | HP DesignJet 100 Plus InkJet Printer
Picture problems
CRT green gun is not working properly , maybe dry soldered or no green drive signal. Pink and red colour is due to missing of green colour.
Sep 09, 2007 | Sanyo DS27820 27" TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
