BAD PCB Showing when i am connecting to PC - Office Equipment & Supplies
    Problem Solver:
  • 7 Answers
To get rid of bad PCB, you can have 5 tips to help you to solve this problem:
Firstly, You have to first of all research and select suppliers earlier in the design circle. Talk with suppliers' customer service technical teams or sales teams, and determine just how well they can respond with quality across the whole range of your anticipated project style.
Secondly, you should optimize for cost and performance before layout. In a general sense, the fewer components that are needed to implement your circuit, the more reliable your end product.
Thirdly, develop your layout to the fabricator's sweet spot.?Regardless of whom you choose, your fabricator has a sweet spot-that place where designs are well inside the middle of the manufacturing process window.
Fourthly, verify your layout's manufacture ability with a supplier DFM tool.
Fifthly, manage prototyping costs and hidden costs,you can choose Elecrow pab service as your partner as it can offer you good service due to your need and lower cost.
http://www.elecrow.com/index.php?main_page=advanced_search_result&search_in_description=1&keyword=pcb+service
Posted on Jun 06, 2015
    Problem Solver:
  • 5 Answers
Do you know hqew.net? Know the pcb.hqew.net is the best PCB small batch customization supplier in China?
http://www.aliexpress.com/store/233890
or
http://pcb.hqew.net/?s=544849
Is custom PCB link
Posted on Aug 29, 2013
Error code E000064-0000
E064-0000 Description The presence of a high-voltage error is communicated by the composite power supply PCB (The output for primary charging, developing, or transfer has deviated from a specific level of voltage) Causes The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty. proce Remedy 1. Contact Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact? YES: Clean the contact, and set it once again. 2. Wiring Is the wiring between the contacts for the following normal: DC controller PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller? a. DC controller PCB (J301) <-> composite power supply PCB (J136) b. composite power supply PCB (J130-7) <-> primary charging roller contact c. composite power supply PCB (J130-1) <-> developing assembly contact d. composite power supply PCB (FT133) <-> transfer roller contact NO: Correct the connection. 3. Composite power supply PCB, DC controller PCB Try replacing the composite power supply PCB. Is the problem corrected? YES: Yes. NO: Replace the DC controller PCB
Nov 19, 2014 | Canon Ir 3300 Black & White Copier
Hitachi simple drive
1- Good idea as long as no "clicking" currently on drive
2- Not going to be easy to get pcb alone
Oct 29, 2013 | Computers & Internet
How do I fix this Sanyo 1080 P flatscreen with a white line and a color problem to the right of the screen
i believe white line is caused by bad or dirty connection on upper buffer which is either connected to ymain pcb or built onto pcb.color distortions can be caused by bad ymain pcb or x pcb.hope this helps.
Mar 16, 2013 | Televison & Video
Compool cp 3600 water temperature sensor
need more info are you looking for location if its showing shorted or over 104 degrees its bad look for it connected to plumbing after the pump the other side goes to the PCB board
Mar 13, 2013 | Pentair Pool & Spa
Yamaha rx-v630 in silent mode without headset plug into it
either the headphone jack is bad, or the cable from the headphone pcb is disconnected. Look inside the unit and follow the cable from the headphone board and make sure it is plugged into the main pcb.
Jan 02, 2013 | Yamaha Audio Players & Recorders
Canon ir 3300 error code e000803-0000
Similar to Description The 24V output from the composite main power supply PCB is absent for 1 sec or more Causes The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty. Remedy 1. Connectors Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely? NO: Connect the connectors securely. 2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller PCB (J300)? (J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3, J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3) NO: Replace the main power supply PCB. YES: Replace the DC controller PCB.
Aug 21, 2012 | Canon Ir 3300 Black & White Copier
STEAMER NOT WORKING SHOWING E8 FAULT
Hi, error 8 is showing you there is something wrong with temperature control pot. This is soldered to the pcb so you need to get someone to replace this or check the connections, otherwise the pcb needs replacing
Nov 28, 2011 | Combi Steamer electric built in steam...
E90 fault
Blue wiring loom that goes to the front control board from the maim control PCB has bad connection on the user interface.Clean PCB terminals and crimp connector to make connections tighter.if this doesn't work could be user interface fault or main PCB fault.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 02, 2009 | Washing Machines
E90 IS THE ERROR CODE IT IS SHOWING
E90 is a communication error between the main pcb and the display pcb.Check the blue wiring loom that goes from the main pcb to the display pcb.normally it is a bad/loose connection on the display pcb end.clean pcb tracks and tighten the blue connector loom pins up and hopefully it will work.if it doesn't solve the problem then you could have a faulty display pcb or main pcb.
May 02, 2009 | Washing Machines
Getting lines across the monitor screen
It may have one of reasons:
1. "Dirty" supplying voltage in the monitor - check all electrolytic capacitor.
2. Bad controller chip - check if it gets extremely hot when working, also you may see darkened area on other side of the PCB where that chip is located.
3. Loosed connection between controller PCB and the display itself - disconnect the cable and clean contacts, especially of blade connector on display side, check if there are some overpressed contacts.
Mar 07, 2009 | Samsung SyncMaster 910T-Black 19" LCD Flat...
73 people viewed this question
jasbo
jasbo
