Question about Toshiba Televison & Video
Cannot tune digital channels
MY TOSHIBA 37C3000A TV WILL NOT AUTO TUNE OR MANUAL TUNE DIGITAL CHANNELS.
HDTV GURU
  • 261 Answers
SOURCE: Digital channels off the air on Sharp LCD Tv
Yes, Go into menu and make sure you have at least rabbit ears hooked up and preferably a HDTV Antenna. If not, a Large paper clip will work in a pinch if you have one, but it won't pick up all channels. Give that a try and then go into the menu under search digital channels then, after you find a few, see what the signal strength is and go from there. Let me know how it works out for you and please give me a good rating. I am trying to do this to make some cash as well. Good day and happy HDTV ING. JAY
Posted on Feb 01, 2008
techman
  • 3130 Answers
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Posted on Feb 03, 2008
SOURCE: how do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Posted on Jan 01, 2009
ltfrc
  • 227 Answers
SOURCE: problem with tuning digital channel
I would believe from what you said, you have solved your problem. You will need a UHF antenna to receive the signal. Walmart or Radio Shack has a great amplified antenna that will work for you.
Mike
Posted on Mar 23, 2009
  • 273 Answers
SOURCE: unable to tune in my LG Electronics TV (model 37LC2d-ec) to receive digital channels. Bought in UK, now living in Australia.
use a scart lead connected between your digital receiver to your tv
Posted on Jun 03, 2009
How do I reconfigure an LG 32LY560H from Commercial setup to auto tune for use in personal residence?
possible that you need to have cable to do this, you might only have 6 digital channels, without cable
Mar 01, 2015 | LG Televison & Video
Toshiba rd-xv47kb auto tune
Check that you have the arial plugged in correct input otherwise it will not tune up.
May 11, 2008 | Televison & Video
I lost a few digital channels on an old LG LCD, tried to auto tune but could not retrieve. Followed a tip online that said to auto tune with the antenna cable which will wipe all saved channels, once...
hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
regards
shaun
Jun 29, 2014 | Televison & Video
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
I have just been given a Panasonic TC-29V26A colour TV in perfect working order. I connected my Digital box to it and had no problem, I just can't get any non digital channels to tune in...even following...
U only get digital channels,that work propperly notthing wrong.Get a digital antena might all the other digital not getting.Non digital will not tune in any more.
Feb 10, 2010 | Televison & Video
How to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
Nov 01, 2009 | Televison & Video
Tuning programmes on Toshiba 30HF83 30" TV Problem
Hello Skinno, Frist of all make sure that you are set to Antenna input and then connect your antenna to the TV this will pull in the VHF ansd UHF channels. Then perform the auto channel select. If this does not work perform a manual channel selection this should clear up your situation.
Sep 03, 2007 | Toshiba 30HF83 30" TV
Televison & Video Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
