Question about Garden
Westwood 1012h ride mower
Cutting width
  • 7 Answers
SOURCE: Hi, Mum has a wtd wanrite mtt model 548/12hp mower ride
Hi this sounds like there is a spot of dirt in tne fuel system
you will need to dismantle the carburettor which is quite straight forward (be careful not to lose any screws or gaskets
guive the carburettor a good rinse in neat petrol/gasoline and blow out any debris that may be there.
re assemble the carburettor and prime with fuel and you should then be ok.
One other thought if you have found that the motor runs fine without being on the grass (eg it doesn't cut out after a minute or two) then it could be that you have the cutting blades set too low for your first cut. To raise the blade adjust the height of the wheels. Always start cutting with a high setting especially if the lawn hasn't been cut for a while.
hope this helps
W
Posted on Jun 20, 2009
  • 2841 Answers
SOURCE: mtd riding mower: right mower blade cutting
The blade can be bent or the deck is not level. Adjust the deck and level it from side to side. Now level it from front to rear with the front of the deck 1/4" lower than the back. If after leveling it, you find it still cuts uneven remove all blades and inspect them. You will more than likely find one is bent. Replace a bent blade.
Posted on Sep 18, 2009
perpetually
  • 360 Answers
SOURCE: uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
Posted on Sep 21, 2009
  • 3911 Answers
SOURCE: I have acquired a Westwood T1300 Hydra Ride on
here is one on ebay. there are also many hits on google
http://cgi.ebay.co.uk/Westwood-S-T-Ride-On-Lawn-Tractor-Parts-Manual-1990-00_W0QQitemZ220485655907QQcmdZViewItemQQimsxq20090926?IMSfp=TL090926143003r8795
Posted on Oct 24, 2009
  • 10 Answers
SOURCE: my westwood ride on mower, model 2012 wont start.
Could be a few things, First, you say it's getting fuel, but is the fuel fresh? It may have water in it and act like your engine. Did this problem just start happening? Did you happen to ride over something that may have sheared the key on the flywheel? This would throw the timing off on the engine. If you can try to start it while spraying gas into the carb throat and it keeps running, then it could just be a dirty caburetor or a misadjusted carb float. Good luck, Bill
Posted on Dec 21, 2009
I need parts for a T1200 Westwood ride on lawn mower,cant find
Westwood Parts ' eBay
www.ebay.co.uk/bhp/westwood-parts
Find great deals on eBay for Westwood Parts in Lawnmower Parts and Accessories. Shop with ... COUNTAX WESTWOOD Parts Garden Tractor Breaking For Parts ... Westwood Countax T1200 Ignition On Off Starter Switch Repl Part No/ 1649.
BREAKING FOR SPARES WESTWOOD T1200 1400 RIDE ON ... - eBay
www.ebay.co.uk > Garden & Patio > Lawnmowers > Lawnmower Parts & Accessories £0.99 - ‎In stock
Breaking for parts - Westwood T1200, 1400 & 1600 years 1987-92. ... Ignition Starter Switch Fits Some WESTWOOD T1200 Ride On Lawnmower 1649.
Westwood Tractor Spares - Largest Genuine Spare Parts Dealer
www.westwoodtractorspares.co.uk/ Genuine Westwood spare parts dealer. Huge range of parts in stock for all models including T Series, S Series, X Series, W Series, V20/50 Series. We ship ...
Westwood T1200 Ride on Tractor Mower Parts
www.japgmowers.co.uk/westwood-t1200-ride-on-tractor-mower-parts-56-c.asp Mower Deck Parts Parts, spares and accessories for Westwood T1200 Ride on ... Westwood S1200, T1100, T1200 PGC Sweeper Grass Collector Drive V Belt ...
Westwood Parts - Buyamower.co.uk
www.buyamower.co.uk/category/westwood-parts.aspx Genuine Westwood Spare Parts. ... At Buyamower, we are Westwood main dealers and as such we stock thousands of ... Westwood Lawn Tractor Blades.
Westwood Parts Manual : Beltingonline.com, Supplier of power ...
www.beltingonline.com/garden...belts.../westwood.../westwood-parts-manual-850/ Beltingonline.com : Westwood Parts Manual - Rubber Timing Belts Garden Machinery ... Westwood Tractors Parts lists for ALL Models by year of manufacture ...
parts for T1200 Westwood ride on lawn mower Google Search
Apr 01, 2017 | Garden
Why does my Westwood T1600 keeps cutting out
I would adjust valves to start.
Apr 30, 2014 | Garden
If I recall, hydrostatic transmission should only be carried out at a properly equipped workshop. Check yellow pages for your nearest mower repair shop. They should be able to collect it if you are unable to get it there yourself.
Apr 16, 2014 | Troy Garden
My westwood ride on mower, model 2012 wont start.
Dec 20, 2009 | Briggs & Stratton Garden
I have acquired a Westwood T1300 Hydra Ride on Mower but it came without the instruction manual; can you provide me with one, please Roger Dennett Tel: 07816 152 705 rogerdennett@questsourcingt.biz
Oct 03, 2009 | Garden
Hi, I have a westwood ride on mower & the 3 bladed 36inch deck has started to whine bearings I think? Are they easy to change? special tools? parts off who? the machine is just 3 years old Thanks JT
I assume you are referring to the deck bearings. The easiest way to replace the blade drive bearings is to remove the deck from the mower. You can then easily remove the blades, clean the deck and be able to easily get to the bolts holding the bearings and pulleys in place. This is normally a straightforward repair and can be accomplished with common hand tools. You will need to purchase the parts from the dealer who sells the mower. Replace all 3 set of bearings. On a 3 year old mower ask yourself why the bearings failed. Are you washing under the deck when the bearings housings are hot? That will cause premature failure. Are you greasing the bearings regularly?
Sep 20, 2009 | Garden
hope this helps
W
Jun 12, 2009 | Briggs & Stratton Garden
Cutting size question
* f your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size. * For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size. * If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
Aug 27, 2008 | Ariens 34 In. Zoom Series Riding Mower
How many HP?
* If your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size. * For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size. * If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
Aug 27, 2008 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
140 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
