Question about Cameras
Meditens MH 8000P Tens EMS Combo - Cameras
I am greater than 3 hundreds, 2 tens, and 2 ones. I am less than 3 hundreds, 2 tens, 4 ones. What number am I
Let's build the two numbers in question.
HTO for hundreds, tens, and ones
322
324
What number is greater than 322 and less than 324?
Good luck.
Paul
Nov 12, 2015 | Office Equipment & Supplies
What is the answer of this problem? I am a four digit number. My ones is twice my tens. My hundreds is five less than my ones. My thousands place is the sum of my tens and hundreds. What number am i?
There are two possible answers to the above question, 4136 and 7348.
4136
My ones is twice my tens: The 6 (the ones) is twice as big as the 3 (the tens).
My hundreds is five less than my ones: 6 (the one) - 5 = 1
My thousands place is the sum of my tens and hundreds: 3 (the tens) + 1 (the hundreds) = 4
Jun 26, 2011 | Office Equipment & Supplies
My whirlpool mh 1140 xm microwave/ hood combo is not heating. everything else works fine, just the heat. I would rather repair than replace. Help!!
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 08, 2011 | Whirlpool MH1140XM Microwave Oven
Where is the cam sensor on a 2005 dodge neon sxt 2.0
Camshaft Position Sensor-On top of engine Operation The Engine Management System (EMS) uses the camshaft position sensor to manage sequential fuel injection and as part of misfire diagnosis. The EMS constantly monitors the number of pulses on the signal circuit. The EMS compares the number of camshaft sensor reference pulses and the number of crankshaft position sensor reference pulses received. If the EMS receives an incorrect number of pulses, Diagnostic Trouble Codes (DTCs) should be stored in the EMS. Some engine management systems will then default to multi-port or "gang-fire" injector operation. The camshaft position sensor signal is required to sequence the injector operation to the proper cylinder timing. If the camshaft position sensor or circuit is faulty, most engines will start. However, the EMS misfire diagnostic will likely be affected.
The following symptoms can be caused by an intermittent wiring connections or faulty signal to the EMS.
Related Symptoms
  • Extended crank time with a cold engine
  • Intermittent rough running
  • Unstable idle
  • Bucking
  • Hesitation
  • Stumble
  • Chuggle
  • Poor fuel economy
  • Stalling on acceleration
Aug 05, 2010 | 2005 Dodge Neon
High idle stalls at lights code for crank sensor
Crankshaft and Camshaft Position Sensors Camshaft Position Sensor Engine timing is determined from the relationship between the crankshaft and camshaft. This relationship is maintained by a timing chain or timing belt. The Engine Management System does not control engine timing but it does monitor the relative position and speed of these shafts by monitoring signals generated by sensors. The Engine Management System (EMS) uses signals generated by the camshaft position sensor to synchronize fuel injection to the valve sequence and for the on-board diagnostic procedure for misfire detection. The EMS energizes the injector at or near the time the intake valve opens. For misfire diagnosis, the EMS compares the number of camshaft sensor reference pulses and the number of crankshaft position sensor reference pulses received. If the EMS receives an incorrect number of pulses Diagnostic Trouble Codes (DTC’s) should be stored in the EMS.
If the camshaft position sensor or circuit is faulty most engines will start. Some engine management systems will then default to a pre-programmed injector firing sequence. All injectors may be energized simultaneously or all of the injectors on one bank may be energized at the same time. If the CMP data is required for misfire detection and reliable CMP data is not present misfire detection would probably be suspended.
Related Symptoms The following symptoms can be caused by an intermittent wiring connection or faulty signal to the EMS:
  • Unstable idle
  • Bucking
  • Hesitation
  • Stumble
  • Chuggle
  • Poor fuel economy
Crankshaft Position Sensor Engine speed is a very important input to the Engine Management System (EMS). Crankshaft speed and position are the basis for many calculations made by the computer. Crankshaft position values are transmitted to the computer by pickup coils also known as Permanent Magnet (P/M) generators, hall-effect sensors or optical sensors. The Crankshaft Position Sensor (CKP) also known as engine speed sensor is located in close proximity to the crankshaft.
In addition the EMS uses minute variations in the CKP sensor data to determine engine misfire. The EMS uses this information in conjunction with the camshaft position sensor to perform misfire diagnostics.
Related Symptoms: No Start/Intermittent Start Condition – Can be caused by a faulty crankshaft position sensor due to loose connections, bad grounds, high resistance in the circuit, or opens in the circuit
Jun 23, 2009 | 2004 Nissan Altima
Energizer 15 minute Ni-MH Battery charger
A flashing red light indicates that there's an error, or the batteries are defective.
No, the unit won't switch itself off once the batteries have been fully charged. The unit will start trickle charging instead.
Dec 24, 2008 | Energizer 15 Minute Battery Charger Combo...
Stop amitting signal after i conected worng batteries to it
Hello hadmcontrol1, I will need information on the error reguarding size, polarity, type of battery you connected including make, model and correct type battery for the unit. With this info I can advise or guide on your choice.
Oct 10, 2008 | Dual Channel Tens Unit ProM 500 with Ems
Sending EMS
Yeah I have the same problem!
Aug 03, 2008 | LG KU990 Viewty
Problem
1. Press Menu
2. Scroll to and Select Messages
3. Scroll to and Select Create
4. Scroll to and Select SMS/EMS or MMS or MMS Templates
5. Scroll to and Select Insert
6. Scroll to and Select Sound
The ringtone download is through EMS or MMS. When you receive the EMS and MMS from another party, you can retrieve the ringtone from an EMS or MMS message. You can also send the ringtone by sending an EMS or MMS.
Dec 12, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
