Lg front loading washing machine f1403YD25
F1403YD25 front load washing machine
SOURCE: LG intellowasher (front-loading washing machine) is starting to squeak.
I suggest u buy another washing machine. This one's had it!
Posted on Apr 23, 2008
  • 210 Answers
SOURCE: LG WM-1280 DD front loading washing machine
When the unit is off, open the door and spin the drum, does the noise occur? If the answer is no then there is nothing wrong with the bearings. Chances are the hall sensor on the motor is on the way out. Call for service and ask them to replace it. Make sure you are using a "HE" branded detergent,,,, less is best.
Sgt 48
Posted on May 31, 2008
SOURCE: LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Posted on Apr 11, 2009
SOURCE: Front Loading LG Washing Machine leaves smelly sludge in wash tub
This machine has a tub clean feature that you're supposed to run with bleach. I did this and it helped the smell s bit. Recently we had an error code and the repair man that came to fix it gave me some good tips. His experience has been that the smell is from too much soap causing build up in the seal and along the tub. His suggestion was to cut back on the amount of he detergent (he said a tablespoon is sufficient). His company recommends using a product called Whirlout (you can buy it at Home Depot). It was originally meant to clean scum out of hot tub jets. Apparently if you call LG they will recommend this product, but haven't bothered to suggest it in the owner's manual. I was told to put one to two capfuls directly into the tub (not the detergent bay) and run the tub clean cycle. I used it last night and it worked - no more musty, yucky smell!
Posted on Jul 09, 2009
App King
  • 55 Answers
SOURCE: LG front load washing machine water leaks with heavy loads
If your water is leaking with heavy loads, the first thing you want to check is the gasket (door boot) attached to the tub. Look for holes or rips in the bellows part(where the water settles) and around where it contacts the door. Any nicks or holes will cause leakage. Also, check the glass dome on the door towards the bottom. If it has dirt or hair buildup on it, it will leak with any pressure on the door.
Posted on Jul 15, 2009
Install drain pump lg washer front load 4.0 ultra
How to replace the pump on an LG washing machine ...
? 6:32
https://www.youtube.com/watch?v=8cPl22OC9f4
Apr 30, 2012 - Uploaded by eSpares
How to replace the pump on an LG washing machine ..... How to Fix an LG Front load washer machine that ...
Nov 14, 2015 | LG Washing Machines
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
Hello, I have the LG Washing Machine Model WM1832CW and I'm having drain issues. The machine itself wont drain the water out. The water remained in the machine. Please advised on what I need to do in...
heatman101
Apr 26, 2011 | LG WM-1832C Front Load Washer
Spin cycle not working on my LG WM0642HW
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 18, 2011 | LG WM0642H Front Load
Lg wh2277hw will not spin. takes water and attempts to spin but no.
heatman101
Jan 14, 2011 | LG WM-2277HW Front Load Washer
My lg WF-T552TH washing machine will not drain the water during a cycle just wondering how i can fix it??
heatman101
Oct 25, 2010 | LG WFT1071TP Top Load Washer
My LG washer will not spin
heatman101
Oct 07, 2010 | LG Washing Machines
I LG machine is not spinning. It is able to wash and rinse cloths but not spin them. Could you please let me know what could be possible issue.
heatman101
Sep 28, 2010 | LG WFT1071TP Top Load Washer
My LG washer wm2277hw does not drain water and
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | LG WM-2277HW Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
