Question about Samsung PCJ522R 52" Rear Projection Television
Picture Makes Me Dizzy
The picture has a curvature to it. It is great in the smack middle but as it moves to the sides the colors seperate and looks like I am seeing in third dementions! Can you help me? People told me to adjust the mirrors inside. I opened the back to find only one huge mirror connected to the back panel and the three color lenses on the bottem. So now I am clueless!!! Thanks for your time. DeAnn
  • Ken Jun 07, 2008
    Blue crt working but no convergance, red convergance works but not blue, yellowish picture
  • blendagour Jun 21, 2008
    I'm new at this I think I posted my problem in the wrong spot. Sorry!
    I just changed the convergence board on my TV, but the flash focus only gets to 37%. The blue will not work. The TV is watchable, but the words are still fuzzy. Is there something else I can do?
I changed the convergence board but the flash focus only gets to 37%. The blue will not work. I can at least watch the tv without it making me sick, but the words are still hard to read. Is there something else I can do?
Posted on Jun 21, 2008
    Champion:
  • 206 Answers
Everybody here seems to have basically the same problem so I will write a general fix for these Samsungs. First what you got is known as Convergence failure, A Ic or resistor, fuse or some other component has failed in the convergence circuit. So finding the service menu and trying to align the colors or spinning magnets on the CRT’s or a real bad idea of tipping a CRT or mirror would be the equitant of ripping the transmission out of your car because it had a flat tire. When the convergence fails no adjustment will bring it back, and if you do one of these stupid things then you have two problems. Now most of these Samsungs have an easily replicable board that all the convergence amplifiers are on. This can be found by removing the back and seeing if there is a board about 9 X 5 inches big and mounted to the CRT mounts, there will be 5 connector to this board. Now if your set does not have this board and instead has the two convergence Ic’s (these are about the size of a playing card and have the numbers STK392-040 on them) mount down on a board below and to the right ( this is known as the deflection board) this repair will not work for you. Instead you will need to component level repair the convergence circuit. But if you do have this separate convergence board the repair is fairly straight forward. Go to www.vancebaldwin.com or some other supplier and order BP95-00142E this is the convergence board. This board has been crossed several times through the years but this is the current version. Now once you get this board simply replace it making sure to get al the connector back in there original spot. The fire up the set and run Flash focus and for about 95% this will fix the set
Posted on Feb 13, 2008
SOURCE:
RCA rear projection tv picture bowed to middle. Red Green Blue colors have been seperated on screen.
If I had to guess I would say it's either the DLP chip or the prism. Simply put the lamp lights the DLP chip which directs the light into a prism and then onto the TV screen. The prism or prisms are responsible for aligning the colors correctly. The DLP chip is essentially a million little moving mirrors which direct light
If you're at all comfortable with electronics you might want to open the TV up to take a look. You might get lucky and find something obviously wrong with the TV. Sometimes adhesives melt and parts slip out of place. If your DLP chip is blown there isn't much you can do. You're probably right that this would cost a lot to fix and not be worth it.
Jul 24, 2012 | RCA Televison & Video
Sitting here watch tv and suddenly the picture went warped and discolored. Picture looks like the colors are seperated. blue green and red.
Your TV has convergence chips that need to be replaced by a tech. These keep tour red green and blue lights in sync with one another in order to give you a sharp color picture. When they fail your colors seperate.
Nov 07, 2010 | RCA D52W23 52" HDTV CRT TV
Hey I have a mitsubishi vs-80803 i have picture but it is a bit bowed on the right side and bottom of picture (black curvature space showing no colors or picture) maybe the convergence needs to be reset?...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 05, 2010 | Mitsubishi VS-80803 TV
On the left side it has a 3 d picture like the colors are seperating (green, and red) the middle and right side is perfect
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 24, 2009 | Televison & Video
Problem with tv picture
Smack it firmley on the side and see
if that cause it to happen or stop happening
if so you have bad solder in the vertical drive
it should look like an hour glass
Jun 23, 2009 | Televison & Video
RCA R52WH74 Picture is sagging, looks 3d, and double picture
Go to menu then setup look for convergence if you do not see convergence then you have A open FUSE It will be on right side of FBT flyback transfomer there is 3 of them in a roll they are small brown rectrangler looking caps but ARE FUSES it will be the one in the middle. Replace it and you have a FIXYA.
Feb 19, 2009 | RCA R52WH73 Projection Television
My tv the bolbs have moved out of place
I am assuming you mean bulbs. Typically the bulbs do not just move out of place on there own. Did the tv take a sharp impact or did some one hit the tv hard enough to move it. The bulbs are held in place with plastic sleeves that are typically held in place with 6 to 10 screws depending on the model. Your local repair shop may be able to assist you in renting the allignment tools for your bulbs. Typically the convergence chip goes and it gives the TV the appearance of the bulbs slipping and makes the tv look like the colors have seperated. One of the colors seems to have shifted to one side and doesn't line up with the rest of the picture. So check with your local dealer or write to the company and see ig your convergence chip is available and if you can rent the allignment tool.
Oct 23, 2008 | Televison & Video
Distorted picture
On the middle circuit board towards rear is a metal wavy plate.On the back side(actually towards screen when looking from rear of unit),the middle screw has a ground wire(light brown) that is loose.
Apr 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Picture problem
If this is a ctc 195 chassis then your likely problem is the convergence power supply that is mounted above the main board and the dynamic convergence board. On the board is an IC (usually) that can be changed: STK 730-010 I believe is the correct number...you can check the number, If it has a single transistor on the metal heat sink, I would suggest changing the whole board. Has only two plugs: one on each end of the board.
Dec 29, 2007 | RCA P52955 52" Rear Projection Television
Lines in picture
I had this problem around the time my TV was 3 years old. I ended up having to get it repaired at a TV repair place, it cost me $375.
Sep 24, 2007 | Toshiba 57H83 57" Rear Projection HDTV
Samsung PCJ522R 52" Rear Projection Television Logo
70 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
