Question about Car Audio & Video
Pioneer 7300 bt start up problem
It worked perfectly until last night when I pulled it out and took a look at some connector . I have a grande punto with a add"on to the radio so that my steering wheel buttons may work . What should I do ?
  • whitedavan_d Jul 18, 2013
    all of the wires are ok I tested the all maybe the microprocessors got fried ?
    New Friend:
  • 4 Answers
Ether your cord going into the power sorce is fried or a cuple wires came loose it hapend to my new car i put a sub in it and fried the power wire
Posted on Jul 18, 2013
JMuskovitz
  • 135 Answers
SOURCE: Steering wheel buttons
Contact Crutchfield (contact info in the link) to see if this will work in your vehicle: http://www.crutchfield.com/S-FaQ8Wkvuw07/cgi-bin/ProdView.asp?search=steering+wheel&i=127SWIJACK
Posted on Apr 04, 2007
SOURCE: New Sony radio doesn't work in a 1996 Fiat Punto
check that you have a very good earth seperate from the aerial or outer casing.
Posted on Jan 15, 2008
PyroPCMan
  • 405 Answers
SOURCE: connecting to a steering wheel buttons
Unfortuantly the steerring wheel audio controls can only interface with a stock radio. Once you replace the stock radio the buttons are useless and cannot be hooked up to any aftermarket radio, this goes for all makes and models of cars with audio controls on the wheel.
Hope this helps
Posted on Jul 06, 2008
SOURCE: 2005 Toyota Camry JBL Radio Replacement: Info button issue
Crutchfield sells an aftermarket kit that allows the steering wheel controls to work, but it's $74, and you head unit must be remote control capable. They also sell a wiring harness that works with Kenwood/Toyota as long as you have the original wiring harness that came with the Kenwoood. You'll need to do some snipping and krimping however.
Posted on Nov 18, 2009
SOURCE: PIONEER DEHP3500 ONLY VOLUME BUTTON WORKS PLAYS CD
All my buttons work, but the source button won't switch to aux. In. Cd and radio work fine. Sounds like you maybe have anti theft issues? Wiring harness? Check ur wires. Mine is in a 95 240sx.
Posted on Mar 10, 2011
I have a fiat grande punto and i had changed the alternator new but sometimes when i'm driving the battery indicator comes on and the steering will jam then i switch off the engine and start again and it...
The red bulb means your battery is dead, you should see if it can be recharged or if you need a new one.(they check them for free it auto part stores) Clean the battery connectors by taking them off the battery and removing corrosion from both the connector and battery. Adding distilled water to the battery uder the caps if it's not sealed.
Nov 08, 2013 | 2007 Fiat Grande Punto
Fiat punto grande 2007 horn came on itself only went off when fuse blew replace fuse horn not working
Check on steering wheel (remove it) behind it has got a copper ring and pins
Oct 26, 2013 | Cars & Trucks
Fiat grand punto duel logic wont go into automatic mode
had same problem with my car ..i took it to semi auto specialists! there was a error on the cars computer which they deleted free of charge ..& hey auto mode back on!
Jul 08, 2012 | 2006 Fiat Grande Punto
Konica 7020 error code f-26-2
Says that it is a PCL connector problem. Look at all of your connections and make sure they are ok.
Jun 24, 2010 | Office Equipment & Supplies
Psp works slow
press the power button on your psp phat then press the r button triggerly and go to the cpu speed then press x button then default thats it
Jan 05, 2009 | Sony PlayStation Portable (PSP) Console
Pioneer AVIC-D3 Audio Problems
Sounds like a problem with the sound chip in the stereo. Disconnect the rca cables from the subs and check to see if the audio returns. If so. try using a different rca connection in the back. Also i think on them radio's if there is a built in sub drive you need to turn that off if you are using a amp to run the subs.
Sep 13, 2008 | Pioneer AVIC-D3 Car DVD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
