Question about Microwave Ovens
Siemens oven hs 8435, service manual
Lamp replacement
Door glass replacement for siemens microwave oven
I suggest calling service any work on a door needs a special detector after the repair to any door part. Only service techs carry these units.
Nov 02, 2015 | Siemens Microwave Ovens
Can I replace the lamp in a panosonic microwave oven model NN CT 857
Hi.
The lamp replacement requires complete removal of the oven external casing. The oven must be tested for radiation leakage after the repair. The replacement must be done by a trained technician. Disassembling procedure is illustrated on the service manual available here: Panasonic Service/repair manuals,schematics.
Regards.
Ginko
Dec 15, 2011 | Panasonic Microwave Ovens
Where can I find a service manual for my Siemens TK54001/02
Choose the following link and register your product .You can get the support of your oven from the nearest service center close to the place.
log on to : http://www.siemens-home.com/
Mar 19, 2011 | Microwave Ovens
I need an operating manual for Siemens HF87951 800 Watts Microwave Oven
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 12, 2011 | Siemens HF87951 800 Watts Microwave Oven
How do I change the light bulb?
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Feb 09, 2011 | Siemens HF87950GB Convection Microwave...
Hotpoint bd35 electric oven instruction manual
Here is a link for you to download a PDF instructional manual for your Hotpoint cooker or Hotpoint oven.
how to use this service
1 click on Link,
2 click manufacturer (Hotpoint)
3 enter your model number and download the PDF file .
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Jan 28, 2011 | Microwave Ovens
How do i replac the interior light on my frigidaire fmv156dc microwave?
We have the service manual and have uploaded it to our site here to help you.
From page 33:
OVEN LAMP and Lamp Socket REMOVAL
1. Disconnect the power supply cord, remove the oven from
the wall and remove the outer case. (Refer to procedure
of "Removal of Oven from Wall" and "Outer
Case removal ".). And proceed as follows.
2. Open the door and block it open.
3. To discharge the high voltage capacitor, wait for 60
seconds.
4. Remove the three (3) screws holding the hood intake duct
R to the oven cavity top plate, the oven cavity front flange
and the fan duct. And remove the hood intake duct R.
5. Turn the lamp socket and release it from the magnetron
duct.
6. Screw the oven lamp off from the lamp socket.
7. Now, the oven lamp is free.
8. Pull the wire leads from the oven lamp socket by pushing
the terminal hole of the oven lamp socket with the small
flat type screw driver.
9. Now, the oven lamp socket is free.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 10, 2011 | Frigidaire FMV156DC Microwave Oven
My Siemens HF87950GB inner glass panel broke during cooking, do I need to replace the whole microwave oven or just the glass or the door? where I should I go to get a replacement? Thank you!
This is a problem that at least a few others have experienced with your microwave and may be the subject of a recall although I could find nothing on their website.
I would definitely go to Siemens first as this definitely sounds like a manufacturers defect. Even if they have not publicly stated this in a recall, they likely know it is happening and may fix it (even out of warranty) if you push. ConsumerReports.org may be interested... I would talk to them if you don't get any satisfaction from Siemens.
Otherwise, the glass should be standard tempered glass that a local glass shop can get if you bring the door to them, or just a sample of the broken glass (for thickness) along with the internal dimensions of the glass.
Make sure that the metal mesh/screen remains in place and is not damaged, as this is what prevents the microwaves from escaping the cooking chamber.
Siemens Customer Support Website
Siemens Service # 1-866-447-4363
Oct 21, 2010 | Siemens HF87950GB Convection Microwave...
How do I replace the light bulb ? \r\nI try to open in rear but saw 3 warning lables, plug I don't have tool to remove those screws. What can I do ? Please help thanks ian
There is no mention of lamp replacement in the manual. You should be able to access the lamp IF you unplug the oven and let is sit for 30 minutes or longer before removing the screws. Since there is no info on the lamp, it may be of a type that is not user replaceable (simple push in or screw in type), or is not readily available.
You may end up having to contact Samsung (number is in the manual) to obtain the lamp - or they may not wish to sell to the consumer - which would require a service man perform the work. You'll also need to buy the tool to remove the screws, too. Maybe you can live without the light.. or get it fixed or replaced entirely. A service call may cost more than it's worth.
Sep 14, 2010 | Samsung MW1080STA Microwave Oven
How to change the light bulp inside the oven?
Bulb replacement is not straight forward on this model, it requires the oven to be removed & stripped to gain access to the interior lamp... I recommend replacement by a Siemens engineer.
Mar 02, 2010 | Siemens HB77L25GB 900 Watts Convection /...
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
