Question about Vehicle Parts & Accessories
I just programmed a new remote and now the horn honks when unlocking the doors, instead of when I lock it. Is there anything I can do to change it to honk when locking the doors? Everything else works great.
  • 109 Answers
Don't know what car you have or year some cars and trucks you can go into settings and make it honk when you want
Posted on Jul 15, 2013
  • davy winkler Jul 16, 2013
    It a 2003 Buick century.
2 Suggested Answers
vetteman3002
  • 2299 Answers
SOURCE: working on a 2002 Cavalier
Have you tried disconnecting the battery and letting it sit for about 15 minutes. Let the BCM reset. The lock being unplugged may have corrupted the BCM.
Posted on Jan 14, 2011
When I press the unlock button, why doesn't the horn beep?
I have a 09 kia spectra, The only time the horn will honk. is when I lock the doors with the remote. Unlocking just makes the lights flash! God-Bless! and hope this helps you out.
Mar 14, 2016 | 2013 Nissan Rogue
Reset key fob
Unlock all doors, foot on brake, all doors closed. Cycle key quickly but carefully on-off appr 10 times until the car honks one time.
Do not turn the key far enough to start the car, just to the 'on' position so the dashboard lights up.
When the horn honks, open and close the driver's door, press any remote button and that's it.
Program another remote? Quickly open and close the driver's door again and push a button on the 2nd remote. That's it.
When you're done, remove the key and the horn should honk 3 times. You're all set.
Sometime it takes more than 10 on-offs to set program mode. Open/close the door, lock/unlock etc, wait 10 minutes, then try again
Jul 22, 2014 | Subaru Outback Cars & Trucks
Horn honks when unlocking doors.
If your vehicle is equipped with a factory keyless entry system and you have the owner's manual, there should be a section in the manual describing how to change your options with your system. But if you have an aftermarket system, which I am thinking this the case, you will have to manually go into your dash under your steering wheel and cut the wire going to your horn from the security system. Once you have accessed your wiring underneath your steering wheel, there is a main harness with a bunch of wires going to the steering wheel. In this harness you will find a DARK GREEN/VIOLET small gauge wire and you should see another wire tapping into it probably coming from the security module. Just cut it off but leave the DARK GREEN/VIOLET untouched and this will eliminate the horn honks.
Jun 26, 2012 | 2008 Chrysler Pt Cruiser
On the remote I will push the unlock button, then the car's horn honks and unlocks the doors. It also honks when I want to lock it. I am only pushing the lock or unlock button once. I'm not in the...
You can disable the chirp confirmation by using the following procedure
1. Turn the ignition on
2. Turn the ignition off
3. Press the valet switch 5 times, wait for the Status Light to flash twice, the parking lights to flash twice and the horn to chirp twice.
4. Press the valet switch 4 times, the MARS unit will respond with 4 Status Light flashes and horn chirps
5. Press the transmitter START button, the MARS unit will respond with 3 Status Light flashes and horn chirps
6. Turn thr ignition on to exit program mode
May 08, 2011 | Omega MARS-22 Remote Vehicle Starter with...
Sometimes when I press the starter button, my car with crank for a little bit, then won't start but the car is still on. I normally press the starter button again to turn off the car, then press it again....
These issues can both be solved through programming. The crank time needs to be extended and the door locks (may) need to be set to double pulse. Can you unlock the doors by pressing the unlock button twice within one second?
Please read all the way through to familiarize yourself with the process before beginning.
Let's try the programming; you will need the vehicle key and the remote. The control/programming switch is located in the antenna on the windshield.
Turn the key on then off; press and hold the control button on the antenna to select the menu. One honk of the horn/flash of the parking lights indicates menu one(1). Now, press and release the button five (5) times (door lock pulses), then press and hold the button. While holding the control button on the antenna, press the lock button on the remote once. You should hear two horn honks/flashes from the parking lights. The system is now set for double pulse unlock. DO NOT RELEASE THE CONTROL BUTTON.
We will now advance to the third menu; release the control button, immediately press and hold the control button. After three seconds the system will begin to advance to the next menu. You will hear two horn honks/flashes from the parking lights. Continue to hold the control button to advance to the third menu. You will hear three horn honks/flashes from the parking lights. Now, press and release the control button three times, then press and hold the control button. While holding the control button, press and release the lock button on the remote. You should hear two horn honks/flashes from the parking lights. Two flashes/horn honks is .8 seconds cranking time. Release control button. Turn ignition on to exit programming/learn routine. Test the system.
If after testing the system , you require a longer cranking time; re-enter the programming/learn routine, menu three, option three and press the lock button on the remote once to advance to one(1) second cranking time.
The programming/learn routine exits if the ignition is turn on, the control button is pressed too many times or there is no activity for 30 seconds.
Nov 28, 2010 | 1401 Remote Start/Keyless Entry System
Doors lock and unlock when not even around car
try changing the batteries in the remote.....
Jun 07, 2010 | 2000 Nissan Xterra
My wife lost her keys. I had to by another key and program it to the car. Now, she has found her keys and the remote does not work. Does it have to be reprogramed or do I have to get another one? If the...
The old remote can be programmed again but you need to take the remotes to be programmed together. They must be programmed at the same time and I believe you can program up to 4 remotes per vehicle. I think the venture requires a scan tool for reprogramming. Try this first- 1. Sit in the drivers seat and put the key in the ignition in the off position. 2. With your left hand hold down the unlock button on the door panel and turn the key to the on (not the run position) then off, then on and off. 3. If the horn honks, take one remote and hold down the lock and unlock buttons until the doors lock and unlock, then do the same for the second remote. 4. Now, turn the key to the on position, then off position and the horn should sound again. Try unlocking/locking the car with each remote. **step 2 may require the key to be turned on then off 3 times instead of 2 before the horn honks. This my not work but if it fails it will not change any of the current settings but you will need to have the dealer program the remotes together.
May 04, 2010 | 2000 Chevrolet Venture
I bought a new Keyless remote for a 2007 Forester from a Subaru Dealer to replace an original one that went bad after 2 years. I have followed the directions in the owner's manual to program it, but can't...
IMPREZA: 2005, 2006, 2007 and
FORESTER: 2005, 2006, 2007, 2008
Check for Immobilizer key on Forester XT models only.
information is always subject to change and correction imp05keylessremote1.jpg
new remote for 2005 Imprezas.
This is not the same remote as the 05 Legacy/Outback remote which also has truck/gate release on the front and a red panic button on the back.
Lock: press Lock button for 2 seconds or so to lock car, and arm optional security system. The car with chirp once and turn signals flash for locked, 5 short chirps and signal flashes if any door is not fully closed. The dome light goes on for 15 seconds and ignition key ring (if present) will light for 30 seconds when unlocked.
Unlock: press unlock one time for driver's door, press again within 5 seconds to unlock all doors inkling rear gate (wagon). The system does not open the trunk.
Panic mode: press and hold lock button for approx. 3-4 seconds to activate Panic mode. I panic model the horn honks and turn signals flash until either the lock or unlock button is pushed again.
Finder mode: Press lock button 3 times within 5 seconds to activate Vehicle Finder mode. The horn will honk once and the turn signals will flash 3 times
Distance: works within approx. 30 feet depending on battery strength, nearby concrete walls and etc.
Audible Chirp On-Off: the system will chirp when locked or unlocked. To turn OFF the chirps, unlock the door and then push both lock and unlock buttons at the exact same time for 2+ seconds. There will be 2 chirps indicating the the audible is off. To turn the chirp back on, repeat the process and the system will chirp one time when it is back on.
Battery: as the battery ages it will only work as you get closer to the car. When a battery is replaced, the transmitter must be re-synchronized with the Keyless control unit. To synchronize, press the lock or unlock button 6 times.
Programming: 4 codes may be programmed.
Sit in driver's seat and unlock all doors. Open and close the driver's door
Turn the ignition key from LOCK to ON position 10 times within 15 seconds. Be sure to stop at both lock and on. The horn will HONK once to indicate transmitter programming mode is activated. Leave key in LOCK position and don't remove it from ignition.
You now have 45 seconds to complete the programming as below.
Open and close driver's door again.
Push either lock or unlock button on the remote you want to program. The horn will honk 2 times when successful.
To continue and program other remotes at the same time: open and close the driver's door and push lock or unlock on the remote. The driver's door must be opened and closed between each remote you want to program.
Done programming? remove the key from the ignition and the horn will honk 3 times.
DELETE old codes? Reprogram 4 times, it will overwrite old codes.
Alarm Security System: optional on all models. When locked there is one chirp (can be turned off, see above), the turn signals will flash and the red 'security' light will start to flash once every 2 seconds except for STi which flashes twice every 2 seconds.
There will be 5 chirps if a door, hood, and trunk or gate is not fully closed
You can also arm the system by using the power lock button on the driver or passenger door as you get out of the car and then closing the door behind you.
Disarm the system: push unlock for 2 seconds
Lost remote, alarm activated? When you can't use a remote to turn off the system: open the door with a key or try to start the car and the horn will start to honk. Turn the key on-off 3 times within 5 seconds and the alarm will go off and you can start the car. It's simple!
VALET mode: To set valet mode or just to disable the security alarm system: 1. unlock all doors 2. physically open the driver's door 3. hold the UNLOCK button on remote for 2+ seconds. The red 'security' light will then flash 2 times a second until the car is turned on.
System has been Tripped (except for STi): if you unlock the door with the remote and it chirps the signal light flash 4 times, the system has been triggered;
Identification mode: To find out what happened and why the system was triggered:
Open and drivers door, leave it open. Turn ignition key from LOCK to ON 2 times and then leave in LOCK position.
Tripped code: 1 security light flash: a door has been opened, 3 flashes when the impact sensor was triggered, 4 flashes when the ignition was messed with or battery disconnected
Nov 19, 2009 | 2007 Subaru Forester 2.5X L.L. Bean...
Keyless remote locks the doors but the horn doesn't honk.
Your lock settings were most probably changed from your remote unit. By pressing both lock and unlock keys together for around two to three seconds you can switch between silent mode and horn mode. Hooe that helps...
Sep 16, 2009 | 2002 Nissan Altima
Keyless remote still works but the alarm system and horn seems to be deactivated. What could be the problem?
If you look in the jeeps owners manual for the keyless remote section, you can program the horn to honk or not honk when you lock the doors.
Oct 03, 2008 | 2002 Jeep Liberty
Vehicle Parts & Accessories Logo
41 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
