Question about Siemens Ovens
Hs8435, service manual
How to replace lamp
How to change light in oven westinghouse florentine
Turn off the power to the oven. Grip the glass light cover and turn anti-clockwise. I think the lamp then unscrews.
Replace lamp, turn on power and check if lamp lights up, replace cover twist clockwise to fasten.
Jun 29, 2014 | Ovens
Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Dec 10, 2007 | Bosch HBN 442 / HBN446 Electric Single...
Both oven lights out
Are you buying hi quality oven grade lamps for this purpose that'll take the intense heat inside an oven? I wonder if they're halogen or tungsten filament lamps. Defective solder, frosty joints and/or ring fractures on lamp driving areas of a circuit board ARE indeed capable of causing problems with lamps.
Mar 16, 2014 | Dacor MCS130 Millennia Electric Single...
I have an Indesit oven model FIE 36 K.B GB, I need to replace the bulb but I'm struggling to get the glass lamp protector off. I've looked in the manual and it says it should just twist off but all...
A common problem with some oven manufacturers I'm afraid. The screw thread of the glass almost welds itself to the metal casing it screws into.
It will turn and you can remove it. However, the easiest way is to get leverage on the glass. This is best done by using a Baby Boa Strap Wrench, which you can pick up for a few pounds in a DIY store. I have removed many apparantly stuck round glass oven lamp covers in this way.
Sep 06, 2011 | Ovens
Need to get access to electric panel on GE Spacemaker Cooking Center -- it is on the upper right side -- need to remove switch that controls the 'surface light'. It has died.
Hi
Please check this video for light switch replacement:
Hope this helps...please post back for further assistance.
Daniel
May 19, 2011 | GE Ovens
Built in oven no power but cook top is working
Is this a range with the oven in the bottom and the hot plates on top. If so does it have an electronic timer/clock. If it does the electronic timer must be set to manual for the oven to work. If unsure turn the oven on and then adjust the mode control on the timer. If it is set to auto now and you can get it to manual the oven indicator lamp should light and the oven should work.
If it is a separate oven and cooktop there may be a separate power supply for the oven at the switchboard.
Feb 10, 2011 | Ovens
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
THE LIGHT HAS GONE WITHIN THE OVEN. HOW DO WE REPLACE?
WE MANAGED TO FIND THE CORRECT BULB & FITTING IN A LOCAL ELECTRICAL SHOP IN COLCHESTER. IT WAS £4.85 AND ALL WE DID WAS UNDO 6 SCREWS AND TAKE THE COMPLETE SURROUND OFF. IT TOOK MY HUSBAND ABOUT 10 MINUTES SO I WAS WELL CHUFFED!
Jan 15, 2010 | Ovens
How do I remove the oven lamp assembly and replace
make sure you have voltage to your switch, it may be that you have a bad switch. If you have power to the switch make sure you have power to the light from the switch. If so its your socket. my light is in the back of the oven if yours is that way you'll have to pull the stove out and take the back off to get to the socket.
Aug 23, 2009 | Ovens
NEFF Oven
brute force i'm afraid. try using a pair of mole grips. its not the end of the world if you break the glass
Oct 02, 2008 | Ovens
Ovens Logo
29 people viewed this question
Top Siemens Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Siemens Oven Expert? Answer questions, earn points and help others
