Question about Rc2 JLX OverDrive
The battery wont fit in the charger to my jlx overdrive!!!
I lined up the possitive and negative signs to the ones on the charger and it wont go in. It looks like the battery is to big for the charger. Ive charged and used the battery and car before but I forgot how to put in the battery to the charger.
3 Suggested Answers
SOURCE: Got the JLX overdrive for
Im having the same problem. The battery only lasy 15-20 minutes.
Posted on Dec 28, 2010
alpug
  • 1961 Answers
SOURCE: I have the JXL Overdrive
Hello!
You can order replacement parts by calling 1-800-704-8697
If you have a problem or question related to your recently purchased JLX Overdrive remote control car please contact the manufacturer directly via the following web address: Jlx.johnnylightning.com
For your convenience I've included the manufacturer's contact info below which can be found on their website.
Email: mailto:CustomerService@JohnnyLightning.com
Posted on Apr 21, 2011
Trying to charge battery for first time. It says connect two red connectors. Do you charge it first then connect the connector afterwards?
1. I assume this is a car battery so the first thing you do is to disconnect the vehicle cables from the battery terminals. The negative first and then the positive. The positive terminal is marked with a plus sign ...+ ... When refitting the cables to the
battery after it is charged you fit the positive cable to the positive battery terminal(+) first and fit the negative(-) last.
2. Now that the battery is unconnected from the vehicle you can fit the charging cables to the battery terminals. The charger you have should have 2 cables leading from it , a positive with a red plastic insulation on the clip and a negative cable probably with black insulation on the clip.The instructions with the charger will tell you in which order the cables are to be attached to the battery and the order you remove them. Each of the 2 cables has to be clipped onto the correct battery terminal. The positive cable(+) from the charger goes to the positive battery terminal (+)and the negative cable(-) from the charger goes to the negative battery terminal(-).
3. Once the cables from the charger are properly connected to the battery, you can plug in the charger and turn on the power.
4. Batteries generate explosive gasses when being charged and it only takes one small spark to ignite them. Don't reconnect the battery after charging for a half hour or so and make sure the area where you are charging is well ventilated.
Dec 18, 2015 | Cars & Trucks
Does the battery have to go in a charger for charging
lila, yes you have to put the battery on the charger to charge the battery, if not the charger wont charge anything, after you put the battery on the charger hold, before that don't forget to equalize the pin charge with the battery there was a marking or emboss note negative pole and positive pole for the battery fit on it charge, then you can go for the electric plug. For additional note there is light indicator green for full battery, orange for the half battery energy and the last one is red light blink for the on going charge the battery. i hope it help, remember safety first.
Nov 11, 2015 | Samsung ST66 16 MP 5X Compact Digital...
Battery possitive closer to windshield or neg?
Positive is red,negative black.Should be a plus sign and minus sign by terminals.
Dec 14, 2012 | 2003 Kia Sorento
Replaced battery clamps, got in to start it up to find the car totally dead. the battery seems fully charged when I put it on the slow charger. Does this car require a special clamp, and or cable set up?
First Make sure the batter was charged with possitive on the plus and negative on the minus sign. For some crazy reason my battery drained and I charged it by just looking at the colored pads and the previous owner had them on backwards so I basically reversed the poles on my battery. (The car wouldn't start either). Use a volt meter to be sure it will show - minus sign if backwards
Make sure all your cables were reinstalled, (red wire to alternator and starter) Black wires to grounds.
If all that checks and your battery show good voltage try your (Large fuses) mains that are 20,30,40,50,and 60 amps.
Feb 21, 2011 | 1998 Toyota Sienna
I have the Travel Pal plugged into the charger. The charger has a green light on for electricity being on but there is no light on where it shows it"s charging. And it's not charging.
have yoy checked that the battery is well pluged. meaning possitive with possitive and negative with negative. sometimes grasse is stock on the joints of electricity, so brush them with a metalic brush, that should solve the proble.
Jul 30, 2010 | RTO Mega Motion 3 Wheel Travel Pal Scooter
Ignition wont start
Check for power on the thin wire going to the solenoid when ignition is turned al the way to start possition,if so it probably won't be the same voltage as your battery, it will be lower.
You need to fit a universal relay so that the solenoid gets the same voltage as the battery when measured with a multimeter between the negative and positive poles.
If no power present on the thin wire with key turned to start possition,there is a wiring problem or broken (thin wire) from ignition switch to the solenoid.
If ignition switch is wired correctly, check if power is transfered from one of the thicker wires to the thin wire feeding the solenoid when key is turned to the start possition, on the ignition switch where the wirng is connected.
Regards
Phillip
Sep 12, 2009 | 1989 Ford Bronco
Lights out, wont crank, message center shows every sign from batt
try taking your possitive battery cable off touch it on negative terminal for 10 seconds and hook back up if that don't work you may have a computer issue
Aug 18, 2009 | 2004 Chevrolet Monte Carlo
Where is negative connection for battery on 2006 dodge charger srt8
Also, to add to some mild confusion, the terminals under the hood on the charger are just there for a jump, thus there is only a positive terminal. The battery is actually stored in the trunk next to the spare.
Oct 13, 2008 | 2007 Dodge Charger SRT8 Sedan
Rc2 JLX OverDrive Logo
23 people viewed this question
Top Rc2 Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Rc2 Toy Expert? Answer questions, earn points and help others
