Sharp er a495i
Bloccato non apre cassetto Resta acceso anche con chiave su spento
PABLOCSA
  • 1124 Answers
SOURCE: hp dv 6373
CIAO, or you have a bad motherboard or bad the battery connector on the motherboard.
Arriverderci!
Posted on Oct 03, 2008
mikedituri
SOURCE: Brother DCP-115C su Vista home premium
Prova a scaricare il driver dal sito brother.
Posted on Sep 02, 2009
  • 52 Answers
SOURCE: Non si apre il cassetto e sul display compare la
Firstly if there is a dvd stuck inside the machine and it won't eject then try the following: Turn off the power at the plug socket and remove the plug then look on the underside of the machine. On some Philips dvd players there is a plain white label below where the dvd tray sits under this label is a slot which gains you access to the manual release. If there is a label and slot gently pierce the label using a small screwdriver and push the screwdriver gently in until it stops then move it from right to left. This action moves a lug sited under the drive unit, this lug is the manual release for the tray. You will then see the tray open and will be able to remove the disc, moving the lug back will close the tray.
But this problem on Philips dvd players and recorders is a fault with the dvd drive and is common on some Philips machines. The only way to cure it is to replace the dvd drive unit itself, the one positive is that Philips used their standard IDE or SATA internal dvd drives, the same as in desk top computers. However a replacement drive would have to be comparable to the exisisting unit to avoid further complications. Please take note as a safety warning this is a technical solution involving the opening of the machine exposing potentially live electrical parts and should only be under taken by a trained technician.
Hope this info helps, James
Posted on Apr 22, 2010
  • 358 Answers
SOURCE: Salve ho inserito la chiave
non solo emette segnali router Belkin e tutte le reti wireless dipendono da una singola password, controllare il prodotto in modo da poter ottenere Connected
Posted on Nov 01, 2010
SOURCE: UN MIO AMICO HA UN
ciao.
ho lo stesso problema.
per caso l'hai risolto ?
renato.cazzolla@macplast.it
Posted on Jan 12, 2011
Como puedo recupea mi cuenta de facebbok
Es posible que pueda volver a su cuenta de Facebook respondiendo a una pregunta de seguridad, utilizando una direcci?n de correo electr?nico alternativa que aparezca en su cuenta o obtenga ayuda de amigos. Tenga en cuenta que s?lo ver? estas opciones si las configura. Para ver si tiene estas opciones: Vaya a la p?gina de inicio de sesi?n de Facebook y haga clic en ¿Olvid? su cuenta? O ¿No puede iniciar sesi?n? En la parte superior derecha. Rellene el formulario para identificar su cuenta. Seleccione He olvidado mi cuenta en la siguiente p?gina si se le solicita. Consulte la lista de direcciones de correo electr?nico que aparecen en su cuenta. Si no tiene acceso a ninguno de estos, haga clic en Ya no tiene acceso a estos? Siga las instrucciones proporcionadas para responder a su pregunta de seguridad o para obtener ayuda de amigos, si ve estas opciones, o p?ngase en contacto con su proveedor de servicios de correo electr?nico. Una vez que regrese a su cuenta, puede cambiar su direcci?n de correo electr?nico de acceso en cualquier momento desde la configuraci?n de su cuenta.
May 14, 2017 | Facebook Computers & Internet
AIUTATEMI!!!! NON RIESCO A COLLEGARE INTERNET
Nintendo DSi / DS / Ds XL si connette a Internet tramite connessione wireless. ? necessario conoscere le impostazioni del router. Sono elencati di seguito i passi su come si intende accedere al router e ottenere le informazioni necessarie per voi da collegare.
Come accedere al router:
1. ? necessario conoscere il ipaddress del router. ? possibile fare riferimento al manuale o controllare il gateway predefinito del computer (Assicurarsi di collegare il computer al router tramite un cavo Ethernet per voi per ottenere il gateway predefinito). Fare clic su Start poi Esegui. CMD tipo sul piccolo riquadro in basso a sinistra dello schermo. Tipo IPCONFIG nella finestra nera e ottenere il valore della vostra gateway predefinito (che inizia con 192.168.xx)
2. Aprire un browser, digitare il gateway predefinito sulla barra degli indirizzi del vostro browser. Vi chieder? un nome utente e password. (Consultare il manuale del vostro router o inserire un messaggio in modo che io in grado di fornire il nome utente e la password del router)
3. Vai alla pagina delle impostazioni wireless del router. Cercare il SSID o il nome di rete e theNetwork chiave o passphrase. Si pu? personalizzare in modo che si pu? facilmente ricordare i dettagli.
4. Assicurati di collegare al proprio SSID e inserire la chiave di rete per renderlo sicuro.
Ora che sappiamo gi? le impostazioni del router poi il suo momento di collegare il Dsi alla rete.
1. Vai alla Nintendo Wi-Fi Impostazioni di connessione del Gioco
2. Ricerca di un Access Point (SSID)
3. Seleziona la tua rete (SSID), Se si dispone di una rete aperta, basta cliccare su "OK" e dovrebbe funzionare bene! Se si tratta di un lucchetto rosso, sar? chiesto di specificare una chiave di password o di rete. Questo ? il motivo per cui reson accedere al router.
4. Verificare la connessione.
Sep 03, 2011 | Nintendo DSi XL Burgundy
Message Code: CA1
ANCHE A ME MI DA CODICE MESSAGGIO CA1 E NON MI DA LACCESSO AL POKER MI RESTA DI PENSARE CHE SIA TUTTA UNA TRUFFA AL QUADO ANCHE COMPRANDO CIPS NON MELE INVIA
Mar 05, 2011 | Zynga Texas HoldEm Poker
Vorrei sapere se il flash Metz 50 è utilizzabile a distanza sulla Canon eos 500D - Grazie
Ciao.
Il Metz 5023 non e' compatibile con Canon. Il Metz per Canon e' 58 AF-1, come questo: http://www.dgrin.com/showthread.php?t=82424
I flash Metz non sono mai universali i flash Metz per Canon funzionano solo su Canon/Nikon.
Metti anche in conto che per installare un flash Metz devi usare un adattatore.
Leggi o traduci quest' articolo: http://www.ayton.id.au/gary/photo/photo_Metz.htm
Dec 19, 2010 | Metz Cameras
Salve ho inserito la chiave di rete nel router belkin che ho acquistato e funziona ma ora ho un problema mentre il pc entra in automatico con il cell. IPhone ogni volta mi chiede la chiave di rete...
Oct 26, 2010 | Belkin (F5D7230-4) Router (587009)
OFFICE PROFESSIONAL 2007
please help to activate my microsoft office 2007
Jan 31, 2010 | Microsoft Office Professional 2007 Full...
Hp dv 6373
Arriverderci!
Sep 05, 2008 | HP Pavilion dv6000z Notebook
jasbo
jasbo
