Question about Sony KDF-E60A20 60 in. LCD HDTV
Projection lamp shuting down
Projection bulb shuting down then coming back on . Thought problem was not enough air flow due to a fan not working but fan was ok.We have four of these in a sports bar,I have replaced lamps in them but have not seen this problem. I am a electronic tech for nasa. Any help would sure be great. Unit may run 3 or 4 minutes or may run 10, there is no set pattern.
    Problem Solver:
  • 5 Answers
I experienced a similar problem with my Sony KDFE60A20, the projection bulb would turn off for about 90 seconds and come back on for the same amount of time then cycle off and on for about half an hour. I cleaned the circulation fan in the rear turned the tv back on and it was ok for the rest of the day. It started all over again the next day so I then took a look at the bulb, I found that the bulb has a venting/cooling screen at the top and bottom of the lamp holder, the top screen was plugged with dust, cleaned it and put it back together and the problem has been resolved now for 1 week. Seems like the problem has been resolved. Tv is exactly 18 months old and is connected through an APC UPS Backup.
Posted on Mar 10, 2008
  • 4 Answers
I had this problem and ordered a new replacement XL2200 lamp from Sony and that fixed it. By the way, the lamp installs from the front so there's no need to pull your TV out from the wall. Look at you manual, it is accurate in this respect. My lamp only lasted about 15 months. It costs $200 plus about $16 to ship. You can order direct from Sony on line service.
Tom
Posted on Feb 27, 2008
Confirm if this is happening during explosions screenshots or high white tones images. I noticed that my set goes black immediately after an explosion or during commercials (Essurance commercials for example). I'll have a technician tomorrow to replace the power board (another problem), but I'll also show him my observations to get his feedback about the blank screen...will let u know!!!
Posted on Oct 23, 2007
I have a mitsubishi 1080p wd-65731 just replaced lamp , tv comes on works fine for about 30 minutes and then shuts off , cleaned vents good , has good air flow light that says lamp turns red in the fr
Could be the fan. It will cool tv but could also be to much for tv to handle.
You can also try reseating the lamp. It may say ok but be wrong.
I have a Mitsubishi 5500 projection tv . have had the type of issue you have had and I have replaced a lamp as well.had to reseat the lamp three times before it worked without shutting down.
Hope this helps.
Jan 14, 2015 | Mitsubishi Televison & Video
Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Mar 30, 2011 | Samsung HL-S5087W DLP TV
On-going problem where tv is turned on and almost immediatley says it will shut down because of an air-flow problem. After turning on several times it used to then work but lately it just repeats the same...
The fan is shorted and might be dead.The projection bulb been in the tv and used for the last 3 years?The projection bulb,life span are over.Require a new projection bulb.
Jul 04, 2010 | Mitsubishi WD-57732 Projection Television
Air flow problem
Pull Lamp Out and see if when you try to turn it on if the Ballast Board has a spark/arking noise coming from it? If So Replace the Lamp.
Jan 14, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My 55vs69a temp and lamp indicator lights are flashing, we replaced the bulb last year, we were told that the cooling fan for the bulb is not working account it is too warm where we have the tv and the...
The Lamp Fan should be open enough to clean. I wonder if the fan is turning at all causing the error to occur. It is always good to keep all the vents clean so air can circulate.
Hope this helps,
Skyassoc
Jul 18, 2009 | Hitachi 55VS69 55" Projection HDTV
Television is now 4 years old, have replaced the lamp 4 times, last time was last week, this lamp lasted three days am waiting for new lamp to see if the last one was faulty. is this a common problem...
Make sure all Airways do not have alot of dust builted up blocking Airways this can cause Lamps to Blow, also keep in mind these sets are only desinged to play between 5000 to 8000 hrs you cannot leave them on day and night like regular TVs,and yes New Lamp does not mean that it was not Defective sometimes companys do have a run as to where they have alot of defective Lamps it Happens
Mar 16, 2009 | Loewe Articos 55 55" Rear Projection...
Green people on my mitsubishi wd62827
could be the green bias control on the crt board
May 26, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Sound but no picture
there are several things that need to take place for the lamp to turn on. first the color wheel needs to turn on ( if you can hear a whinning noise then this is fine) next the tv will send a signal to the lamp ballast to turn on, and the ballast needs the 130v dc supply from the power board ( simoly remove the lamp and reinstall the lamp door, turn tv on, and if you hear an arcing noise from the ballast you know this is fine too. the board that controls all of this is the dmd board. so if the color wheel works, ballast starts then i would replace the dmd board....
Oct 24, 2007 | Samsung HLP5085W 50" Rear Projection...
Screen going black Sony KDF-E60A20
Remove the lower front panel by removing the 2 large round screw heads at the lower back corners, one on each side. Remove the retaining screw on the right side of the metal horizontal retaining strip in front of the bulb holder, remove bulb retaining screw in the upper left corner of the bulb holder. Pull the bulb holder out towards you and check for dust build up on the top screen on the bulb casing, if there is an abundance of dust it will restrict the airflow across the face of the bulb which causes it to heat up and turn off. Once the dust has been cleaned your bulb should now work as it should without a problem.
Oct 08, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Cooling
Check if the condensar ( outside fan unit) is getting enough free ventilation. IF there is no free air flow you will mostlikely be triping the unit due to short cycling. Ie the unit is pulling its own discherge air causing the compressor to trip due to high back pressure
Sep 04, 2007 | Haier HPAC9M Air Conditioner
Sony KDF-E60A20 60 in. LCD HDTV Logo
336 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
