Question about Friedrich Heating & Cooling
Resitor cracked on Friedrich em18l34-b
While cleaning the filter on my Freidrich em18l34-b I found that the resistor block,part # P61808001, is cracked. What problems would the cracked resistor cause in the ac unit? I've noticed the unit is not sensing that the room temp has elevated and turns on. When does finally turn on it stays on for a short amount of time. I've also noticed the air is not a cool as it was last year. Could these be the symptoms of a cracked resistor block? Also, if I change the resistor block do I need to discharge the capacitors? Thanks!
  • 23 Answers
SOURCE: Gold Star GWHD5000 capacitors.
If all your doing is washing it out and fixing bent fins it's not necessary to discharge the capacitors. I would only discharge them if I was disassembling it to the point that the capacitors were out in the open or there was a change I could touch the wires on them. To discharge any capacitor is pretty simple really, first make sure the airconditioner is UNPLUGGED , then using two screwdrivers, make sure that you are holding onto the INSULATED HANDLES ONLY, put the tips of the screwdrivers on the terminal connectors on the capacitor and cross the screwdrivers. Sometimes, depending on the capacitor, it is possible to do this with only one screwdriver by shorting across the terminals with the shank of the screwdriver. Just make sure the A/C is UNPLUGGED and you are holding onto the handle ONLY.
Posted on Feb 07, 2008
  • 20 Answers
SOURCE: AC not putting out enough cool air
it sounds like the compresor is over heating tri pluging it in on difrent outlet or lowering the demands of other outlets on that circuit or run dedicated outlet
Posted on May 27, 2008
  • 143 Answers
SOURCE: Friedrich RS10J10-C: Only half the coils are chilled...
If the evaporator coil is only half coated with water, this means it is low on Freon. You need a repairman to fix the leak and add Freon, but this costs way over a hundred dollars.
Posted on Jul 25, 2008
  • 148 Answers
SOURCE: UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
Posted on May 03, 2009
  • 133 Answers
SOURCE: Just cut on 8 year old Goodman CPLE24-1 AC for the
Due to the many different questions I see about Air Conditioning, I am including this overview to help us better understand each other for trouble shooting. A basic air conditioning system has a Thermostat, Air Handler or Furnace Fan and a Condensing unit. In a split system, the condensing unit (Condenser) is separate from the furnace and usually in the back yard. When working properly, it blows hot air. It connects to the cooling part of the system by 2 copper lines. One large line and 1 small line. The part that cools the house is the "Evaporator" and is usually on top of the furnace inside the square metal box (Plenum). When the Air Conditioner is running, the large copper line should be cold and the smaller line should be warm. Common signs of low refrigerant are that both lines are the same temperature and/or frost or ice has built up on the large line at the condenser. The thermostat will normally display room temperature on till it is touched to change the setting. It could have a "Span" setting as well as times and temperatures. The operating "span" of MOST residential thermostats is 40 to 90 degrees. That means you can set it as low as 40 degrees and no higher than 90 degrees. It probably has a fan switch also. When in the "ON" position, the fan will run constantly, 24 / 7, but the condenser will still cycle on and off as needed to keep the house at set point. If you have a suggestion to include in this paragraph, please let me know.
I think I have it covered above. Let me know if you need something more specific. Thank you. Roger
Posted on Apr 12, 2011
Setting flame sensor (Honeywell)
The flame sensor has no setting it bolts in place in the pilot assembly or burner area. 23735280-wil0gxehsfojcry3vcxysbjd-5-0.jpg
Mar 05, 2014 | Friedrich Heating & Cooling
Freidrich ptac won't start
Check for a reset or circuit breaker on the unit.
Jun 14, 2012 | Friedrich PTAC (PDH09K35B) Air Conditioner
My Freidrich air conditioner is 2 years old. It seems to run very "rough" - it's hard to explain the sound I'm hearing. Still cooling off the room.
Sounds like your unit is maybe unlevel causing the fan blade to rub or its not draining properly and the fan blade is running through water and should be pulled and cleaned.
Jul 27, 2011 | Friedrich Heating & Cooling
Our Freidrich air unit is very old but still works . We can't find out where the filter goes or comes out so we can replace it or wash it out. Where is the filter located? Does the front of the unit come...
On a older friedrich unit, located on the plastic front should be a flip down grille with the filter located in front of the evaporator coil. The evaporator coil looks kind of like a radiator and this is actually what the filter is for: to keep the evaporator clean. (The filter should be right behind the plastic front and right beside the knobs)
Apr 16, 2011 | Friedrich WallMaster WS07A10D Air...
Front blower only works on high, what part do i
There are two things I can think of that may be causing your problem. First the blower switch in the dash may be bad if you do not have an electronically controlled blower, if you do it could be the control unit itself, but usually they stop working alltogether. The other part which may be bad is the resistor pack on your blower motor.
If your blower has four speeds on it like most blowers these days then this resistor pack will have four resitors mounted on it. They look like coiled wires. These resistors vary the voltage coming from the blower switch so you have different blower speeds. Kinda acts like a filter dropping the voltage for the lowest blower speeds incrementally.
If you want to diagnose this yourself it shouldn't be too hard. You will need a 12 volt test light or a multimeter to test for voltage. The blower motor should be located unther the hood of your vehicle on the passenger side against the firewall. It looks like a round black box with wires going to it. Where the wires connect to it the resistor pack is on the other end of the connector inside the motor housing. There are usually two screws or bolts holding it into the housing. If you take these bolts out it should come right out. You can visually inspect it and you may notice some charring on the circuit board where the resistors are.
I would measure power with you test light from the connector before it goes into the resistor pack. If you are receiving power at all blower settings then your blower switch is likely good since this feeds the signal to the blower motor.
You can then use a multimeter to ohm out the resitors on the resistor pack. If any of them show to be open you have a bad resitor coil there. You have two options at this point, you can unsolder the old resitors that are bad and try and replace them with comparable resitors from radio shack. Or you can go to rockauto.com and order a new resitor pack. They run about $16.00-$20.00.
Apr 08, 2010 | 2001 Dodge Grand Caravan
Freidrich cp06e10 will not cool room. Cool mode
is it just the condensor motor thats not comming on
Apr 08, 2010 | Friedrich QuietMaster SL28J30A Air...
Need replacement cover or grille for model # KM18J30
Johnson supply out of Texas has an account with Freidrich. They are an A/C supply house. I believe they are based out of Houston. I would give them a call and see if you can get one through them.
Mar 19, 2009 | Friedrich QuietMaster KM18L30 Wall/Window...
Heating & Cooling Logo
42 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
