Question about Bryant Heating & Cooling
We have a Bryant AC Model # 663CJ036-F; it has stopped blowing cool air, the outside unit stopped spinning
Clean filter, did a few "on/off" starts, cleaned out the outside unit free of debris using water hose w/garden sprayer, the outside unit will start turning with assistance and remain on but the inside rooms are not receiving any cool air,
    Genius:
  • Bryant Master
  • 1,363 Answers
Change capacitors.
Posted on Aug 13, 2015
  • 86 Answers
SOURCE: Stand alone AC blows cool air but does not cool the room
send tank capacity.model mail me mintex007@yahoo.com
Posted on Mar 17, 2008
Master_Tech
  • 770 Answers
SOURCE: kenmore ac blowing black peices all over room.
that is foam insulation around the seal of the evaparator box pull the unit from the wall remove the cover to get to it and clean or replace it
Posted on May 10, 2008
  • 142 Answers
SOURCE: Bryant central air unit fan doesn't stop.
This is a condenser fan and as long as the A/c unit is in cool mode, this fan will run. The only time it should shut off is when temperature setting is satified and the unit shuts off.
Posted on Jun 05, 2009
james3751
  • 614 Answers
SOURCE: bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Posted on Jun 16, 2009
skrbin
  • 121 Answers
SOURCE: Outside unit will not start...while inside unit blows warm air
probably a.c. was left with out a gas,and compressor will not start and there is no cooling.
Posted on Jul 04, 2009
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
KF9000e. Why has it stopped blowing cool air?
Depending on the age of unit either filter blocked needs cleaning or freon low is fan blowing do you have outside of unit clear of obstacles these are all things to check also remember if it's 100 outside AC will only drop air temp 20 or so degrees
Aug 17, 2015 | Amcor Heating & Cooling
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
Furnace blowing warm air, ac overheats
Sounds like it is tripping on it's high pressure switch. This could be caused by a dirty condenser coil, overcharge of refrigerant, or non condensables in the system ( air most likely). I would get a second opinion from a repuatable company, sounds like he's trying to rip you off.
Sep 25, 2012 | Bryant Heating & Cooling
It is a Bryant Legacy AC unit. Model #123RNA060-B. It has been running fine, now it has suddenly shut down. The interior fan is working, but the fan at the compressor shuts down. It will work fine for...
I had a unit do the same thing to me, everytime I would leave, it would stop working again. I had a bad fan motor that would spin fine and work for a little while, but would shut down. It was the motor windings that would overheat and shut off, as soon as they cooled, it would start back up. One way to check is to feel the top of the unit where the base of the fan mounts and see how hot it is, best to check while it's not working how it should, but try not to run it very long or you could damage the compressor. Hope this helps!
Jun 27, 2011 | Bryant Heating & Cooling
Ac units in apt. is fully charged,but it blows cool to cold air and will constantly run all day with out shutting off. at night when it cools off outside it will run like its supposed to. the fan unit...
Your ac thermostat is defective and not switching off the compressor resulting in excess cooling and need replacement. Also ensure that all doors and windows are closed. Could be some window is opened behind the curtain without your knowledge. That could be yet another reason for your unit continuously running.
Finally check your relay unit and this should solve your problem!
Jul 10, 2009 | Heating & Cooling
Bryant air condition fan outside not coming on
Jun 15, 2009 | Ruud UBHC Air Conditioner
AC is set on cool & furnace comes on blowing hat air
My first thought is a bad thermostat or control board or maybe something is wired wrong. If all that seems to be working I would look at the outside unit. if that condenser fan motor is not operating then you wont get any cooling. look for a swollen capacitor. Read more
Jun 06, 2009 | Bryant 463AAC005BA Air Conditioner
AC unit outside turns on but no air blows through the vents
The first problem sounds like the wiring is wrong up at the heating unit not turning on the blower fan in the heater when you call for cooling. Most typical is either something has chewed the wires or the wires have been stripped b something else. The AC not cooling your house can be either it is low on freon or the system is to small for your house. Also check your filter and make sure that it is not blocked and everything is clean with the filter
May 28, 2009 | Heating & Cooling
Heating & Cooling Logo
272 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
