Question about Ricoh 4506 Copier
Aficio mp 5000 sc 302 - Ricoh 4506 Copier
Bubbabear64
  • 2794 Answers
SOURCE: Functional Problem SC 302
SC 302 has to do with you charge corona wire.  It's unrelated to the toner spill.  It could be a bad conora wire.  Sometimes it's the power supply.  There could be a lot of troubleshooting and repair to do on this one, you might want to contact a dealer in your area since the have the right tools for the right job.
Posted on Oct 04, 2008
wheatlandsvc
  • 1110 Answers
SOURCE: Ricoh Aficio MP 4000 sc 870 error after power cord
SC870 = Address Book Data Error. This is most likely a hard drive failure especially considering the power loss. This is about a $175 repair in case you want to call around locally and get estimates to replace the drive. There is an outside chance you can get someone to walk you thru the Service Mode and do the following to reload the address book:
1. Enter the SP mode
2. 5846-50 (Initialize All Address Book)
3. Turn the machine off then on again.
Good Luck
Posted on Oct 20, 2009
SOURCE: Ricoh Aficio MP 161 giving me an error code of
One of the following controllers is
installed to the basic model:
* The controller of the MFP
model
copier/facsimile model
printer/scanner/copier
model
OR
The controller of the optional
printer/scanner is installed to one of
the following models:
* The MFP model
* The copier/facsimile model
* The printer/scanner/copier
Posted on Dec 04, 2009
Ickoajnc
  • 183 Answers
SOURCE: Ricoh Aficio MP 1600 Le error code sc 322 occured
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
Posted on Jan 13, 2010
SOURCE: Sir, My copier model RICOH MP
My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 101
Posted on Nov 18, 2010
@wAm getting a sc 302 code on a gestetner mp 171.I have changed the whole drum unit.
Hello!
When you change the PCU did you conect the blue plug????
If this is not the case remove the PCU again and if you look deep down you will see a metalic shaft. Clean it and install again the PCU.
Hope this helps you
Aug 01, 2011 | Ricoh Aficio 2015 Copier
Error occured SC:302 Functional Problem Turn main power switch off and on if the error appears again. Call Service
SC:302
Charge roller current leak
Symptom: A current leak signal for the charge roller is detected.
Possible Cause:
?? Charge roller damaged
?? High voltage supply board defective
?? Poor connection of the PCU
May 27, 2011 | Ricoh Aficio MP 1600L Black and White...
Sc 302 error code
You have a leak power in the charge roller.
It may just be a defect or poor contact on the roller charge, but you can also have problems in the power supply.
If you have no technical training I advise you to call a professional.
Jan 31, 2011 | Ricoh Aficio MP 1600L Black and White...
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
Sc 302 - charge roller current leak.aficio 1018
Replace the PCU assy (drum unit) or a service call to rebuild the unit, sorry...-Carl
Nov 01, 2010 | Ricoh Aficio MP 2000 Black and White...
Functional problem sc 302 in ricoh photocopier model aticio1600
the charge roller in the drum unit is faulty or need to be cleaned.strip the drum unit and clean the unit
Sep 06, 2010 | Ricoh Aficio MP 1600 Black and White...
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
How can i solve error code sc:302 in ricoh Aficio 2000 copier.
Is there any immediate solution for the ERROR SC302 for aficio 1018?
tnx
Aug 24, 2010 | Ricoh Aficio MP 2000 Black and White...
Error occurred sc:302
this is a charge roller error there may be charge leaking from the bushings or the roller isnt sitting correctly in the drum unit. dirt build up on the surface can cause this as well it may need taking out and cleaning.. water and a soft cloth only on the roller surface to be used..
Jul 21, 2010 | Ricoh Aficio MP 1600L Black and White...
Ricoh 4506 Copier Logo
26 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
