Question about Hyundai Excel Alternator / Generator BeckArnley BA1860345
Why does my alternator keep geting loose
I keep tightening the bolts holding it in and then about a week later it comes loose and rattles. and why does my timing belt keep squeeking? how do I fix these problems
    Top Expert:
  • Hyundai Master
  • 42,757 Answers
The alternator is held in place by either 1 long bolt at the bottom or 2 bolts one for each mounting lug. It is adjusted by a slotted strap that has a bolt holding the alternator in place. If the alternator is coming loose all the time place a flat washer and a spring washer under the head of the bolt in the adjusting strap. The timing belt is a tooth belt and will not squeal but a loose drive belt for the alternator, .power steering or a/c will make a noise if not tensioned properly. Belts have to run at the top of the pulley and not on the bottom as this is an indication of worn pulleys or incorrect belt in use.
Posted on Jul 14, 2013
Replacing alternator belt on 2007 1.3 cdti combo is it easy to do
Loosen alternator, push it towards the block until belt is loose. Pull the belt off and replace. Once the new belt is on push the alternator away from the block until belt is tight and tighten bolt/bolts. You might need a bar to keep tension on the alternator while tightening bolt/bolts.
Oct 18, 2016 | Cars & Trucks
2003 elantra alternator problems
This case needs an expert to check whether the threads where the bolt goes in are good or are worn.If worn has to remake new threads and renew bolt.
Aug 16, 2012 | Hyundai Motor 2003 Elantra
Show picture of how to put alternator on 2.2 s10
This answer is in a previous question; just keep in mind this procedure to install:
  1. Position the alternator in the vehicle and loosely install the retaining bolts.
  2. On 1994-98 models, tighten the top alternator bolt to 22 ft. lbs. (30 Nm) and the bottom bolt to 32 ft. lbs. (43 Nm).
  3. On 1999-99 models, tighten the rear bolt to 37 ft. lbs. (50 Nm) and the front bolt to 18 ft. lbs. (25 Nm).
  4. On 1994-98 models, install the alternator brace, then tighten the retaining nut(s) and bolts to 22 ft. lbs. (30 Nm).
  5. On 1999-99 models, install the alternator brace, tighten the brace-to-alternator and brace-to-intake retainers to 18 ft. lbs. (25 Nm). Tighten the brace-to-engine stud nut to 37 ft. lbs. (50 Nm).
  6. Install the battery terminal wire and tighten the retaining nut, then engage the alternator wiring connector.
  7. Hold the serpentine drive belt tensioner, back off the belt while slipping the belt over the alternator pulley. Gradually lower the tensioner into contact with the belt, then check for proper alignment and tension.
  8. Connect the negative battery cable.
Previous question link HERE.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 21, 2012 | Cars & Trucks
Simpson Encore 605 agitator bolt comes loose - does it need loctite?
The wear is preventing it from tightening correctly, loctite won't be a long term fix, it will still come loose again due to the forces put on the bolt by the vibrations of the agitator. The only way to fix it is to replace the agitator.
Mar 06, 2012 | Washing Machines
I am trying to hange the serpentine belt on my 09 lancer rallyart and it keeps slipping off
Locate the two belts on the left side (passenger side) of your Mitsubishi Lancer. The outer belt is a serpentine belt, operating four pulleys and the inner belt is your alternator belt.
  • 2 Follow the serpentine (outer) belt to the three pulleys lined up vertically near the front of the engine compartment. Locate the middle pulley, which is the tension pulley for the belt.
  • 3 Loosen the bolt on the middle pulley with a socket wrench by turning counter-clockwise. Do not remove the bolt, just turn it a couple of times. Loosen the tensioner bolt on the side of the of the pulley, facing the front of the vehicle.
  • 4 Remove the serpentine belt and then loosen the bolt on the alternator. With the alternator loose, move it forward so that the alternator belt loosens up and then remove belt from the pulleys.
  • 5 Install the new alternator belt by placing it over both inside pulleys. Tighten the tension on the alternator belt by moving the alternator back and keeping tension on it by holding it back with a long screwdriver. While the alternator belt is tight, use a socket wrench to tighten up the bolt on the alternator.
  • 6 Place the serpentine belt back on the pulleys and then use a socket wrench on the bolt on the front of the tension pulley. Once the serpentine belt is tight, tighten up the bolt in the middle of the tension pulley.
  • 7 Start the Mitsubishi Lancer's engine to test the alternator belt and make sure it is working properly. Once you have verified it is working, turn the engine off.
  • Oct 25, 2011 | 2008 Mitsubishi Lancer GTS CVT Sedan
    I replaced the front brake pads on my 1999 fatboy i tightened both caliper bolts but when i ride i can hear a slight rattling sound coming from the caliper. please help. ...
    Did the original pads have anti rattle springs attached to them? If they did, you should have transferred them onto the new pads. The rattling isn't dangerous by any means, but it can be annoying.
    Jun 28, 2011 | 1993 Harley Davidson FLSTF Fat boy
    The toilet seat is very loose and I can't figure out how to tighten it. Please help! Its about to come off completely Thanks
    Usually there are plastic caps that snap down over the bolt head.
    Shut toilet lid and get down close with a flashlight.
    Seat attaches in two places.
    Reach underneath and you can feel two bolts with nuts.
    You don't need to see them, just feel with your hand.
    The bolt head is covered with a plastic cover.
    The cover is added for aesthetic purpose only.
    Use small screwdriver or fingernail file or nail or scissors to pry up the cover and reveal bolt head.
    Use bigger screwdriver to tighten bolts.
    You may have to keep one hand on underside to hold nut while turning bolt clockwise.
    Another trick is use hand to push bolt all the way up, and then finger tighten bolt most of the way, and use screwdriver for last few turns.
    Tighten bolts good and tight, but don't overdo it.
    Bolts will come loose again and you can tighten more later.
    Dec 13, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
    Front end rattle
    It's a loose steering column. Remove the black plastic shield under the steering wheel. Lossen the bolt that holds the two shafts together, slide them together as far as they'll go, and re-tighten the bolt. It's that simple... to stop that annoying rattle.
    Mar 06, 2009 | 2005 Chevrolet Equinox
    Altenator replacement
    its not hard to replace an alternator,,,there are 2 bolts that hold it in place that you have to take out.make sure you take the pos battery cable loose so you dont short anything out , once you remove the bolts he alternator will move freely there is a wiring harness hooked to the back of it that you have to take loose and then you can pull the alternator off the try.you put it back the same way you took the old one off and when you go to tighten the belt you need a prybar to apply tension against the alternator and then as you keep that tension on therer you tighten the golts to keep the belt tight. thats about all there is to it
    Jan 19, 2009 | 2002 Volkswagen Jetta TDI
    Hyundai Excel Alternator / Generator BeckArnley BA1860345 Logo
    43 people viewed this question
    Top Hyundai Electrical Supplies Experts
    john h
    fred_therese
    Are you a Hyundai Electrical Supply Expert? Answer questions, earn points and help others
