Question about Maytag MDE9316 Dryer
Maytag performa pdet910ayw dryer
What is green screw in rear?
jumptrout51
  • 3361 Answers
SOURCE: Maytag Performa PYET344ATW dryer noise problem
unplug the dryer.
Raise the lid.
Remove the front panel.
Inspect the blower wheel on the motor.
If loose on the shaft, replace it.
Inspect the glide supports on the front drom support.
Remove the drum.
Inspect the rear rollers for sticking.
Inspect the belt tension roller for wear.
Posted on Mar 12, 2009
Illeagle
  • 525 Answers
SOURCE: maytag performa dryer will not heat up
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
maytag performa dryer Model PDGT910AWW
"No Heat" complaint.
Firstly, make sure that you have selected/ascertained a "Heat" setting, then read the checklist below provided by; www.repairclinic.com
They also provide disassembly diagrams and repair parts..
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Jul 08, 2009
  • 67 Answers
SOURCE: need belt diagram for Performa PDET920AYW dryer
Flat side of the belt goes agaist the drum. The diagram is on the new belt
Posted on Aug 15, 2009
SOURCE: looking for heating element breaker or reset on a performa dryer
you have to take off the back its to the bottom left
Posted on Aug 31, 2009
localwonder
  • 6784 Answers
SOURCE: Where is the thermal fuse located on the Performa
Hi. The fuse is mounted directly on the heater element, in between the heater duct, and duct exhaust.
Click here to view a picture of the fuse.
Posted on Dec 20, 2009
Loud Squeaky Performa Dryer Mod# PDET910AYW. I am guessing I need a rear drum bearing kit, perhaps as well as the felt pad/glide? For some other models, like Frigidaire, it looks like they sell the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 09, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Performa # pdet910ayw dryer will start but stops in 30 secs
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 28, 2011 | Maytag Dryers
I hae a Maytag Performa Model PDET910AYW electric dryer. I need to replace the belt. I have the belt. What is the easiest way to open up the dryer to get to the belt?
lift the top you will need a putty knife in the front there are two clips one on each side push in and lift up once up there is a screw on each side remove and the front comes off
Apr 22, 2010 | Dryers
My Maytag Performa won't run at all
I looked up your model. The blower wheel on these 31001317
causes the dryer to over heat. The fuse kit LA-1053 mounts here:e930c75.jpg
Apr 13, 2010 | Maytag PYE2300AY Electric Dryer
Where is the thermal fuse located on the Performa dryer model PDET910AYW?
Dec 20, 2009 | Maytag PYE2300AY Electric Dryer
Changing the 3 prong dryer cord to 4 prong
White in the middle.
Green outside the cover to the ground screw.
Black and Red to either right and left.
Mar 23, 2009 | Maytag Dryers
Maytag performa dryer assistance
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Thanks,
Juan J.
Jun 07, 2008 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
