Question about Konica Minolta magicolor 2430 DL Laser Printer
Toner Empty Message won't go off
My 2430DL printer prompted for the blck toner to be replaced as it was empty. I replaced the toner with a brand new out of the box toner, but the Toner Empty Black message stays on. I followed the instruction to press the Cancel button, but the message remains. Please help. Thanks.
  • Anonymous Apr 23, 2009
    same problem.. printer will not print because toner is out even though new toner cartridge. Status of k shows 0% other CMY show about 65%. Minolta / Konica 2350.... suspect mirror tab at end of cartridge indicates fill level.. not sure why problem with K only. Printer set to print when toner out but override does not seem to work.
  • Anonymous Mar 24, 2014
    the F2-74 error message was on the screen. Replaced black toner but the error message is still showing
    Champion:
  • 214 Answers
Check that the toner is inserted correctly, reboot print.
Posted on Dec 07, 2007
SOURCE:
I keep getting an error message stating to install a waste toner box and close all doors.
Printers usually have a waste collector where excess toner is collected. Obviously, yours needs to be changed.
Mar 07, 2016 | Konica Minolta Bizhub C452 Color Copier,...
It says replace a waste toner
The waste toner box is full.You have to replace it now.Replace the waste toner box with the new one or empty the waste toner box and fix it again.Your problem will be solved!
Apr 09, 2014 | Samsung CLX 3305 - multifunction fax /...
How do I know which toner is empty on samsung clp315
  • 1.Log on to your computer and print a test page to the printer. Click on the "Start" button, choose "Control Panel" and then "Printers and Faxes." Right-click on the laser printer, choose "Properties" from the drop-down menu and click the "Print test page" box.
  • 2.Look at the quality of the print on the finished page. If the print is light or faded, the ink cartridge is probably empty or at least empty enough that it should be replaced. You can try to get some extra life out of your toner cartridge by taking it out of the printer, shaking it vigorously and putting it back in. Under normal printing loads, this can give you one to three days of additional printing capacity.
  • 3.Open the printer cover and carefully pull out the toner cartridge. Set the cartridge aside while you open the box containing the new toner. Pull the new toner out but do not yet remove any of the packaging materials. Compare the weight of the new toner with the old one. If the old toner is very light, it is nearly empty and should be replaced.
  • Sep 22, 2011 | Samsung CLP 315 Laser Printer
    Minolta 2430dl, cyan, magenta, and yellow toner cartridges all show empty. Black shows 42% remaining. How do I get printer to print?
    Some printers will refuse to print _anything_, until you replace/refill _all_ of the empty toner cartridges. So, replace/refill.
    Dec 30, 2009 | Konica Minolta Office Equipment & Supplies
    Printer reports 'Toner Empty' error whereas actually the toner is not empty.
    If its printing then it will continue printing till the toner finished.
    If you have refilled then the message will continue may damage the printer also.
    If the toner is already exhausted. We request u to replace the Toner from market ( not from the New Printer Box). Sales Toner
    Dec 10, 2009 | Samsung SCX-4216F All-In-One Laser Printer
    Replacing a cartridge
    Title:
    I replaced my ink cartridge, but the LCD is still displaying "Ink Empty". What can I do?
    Description: This is typically caused by an incorrect selection made during the LCD prompting after a cartridge is replaced. When an ink cartridge(s) is replaced, the LCD will ask, "Have you removed Blck? 1 Yes 2 No". This question will be asked for ALL 4 colors in sequence, regardless if the color was replaced. If "1 Yes" is NOT selected for the color(s) that was replaced, the LCD will return to "Ink Empty". Do the following to clear the message:
    1. Pull the scanner cover release lever located below the control panel and lift the top cover.
    1. After 15 seconds, re-close the top cover and then re-close the control panel cover.
    2. The LCD will then display Have you removed Blck? 1 Yes 2 No.
      The LCD will display this question for ALL 4 colors (not just the ones replaced). BE SURE to select 1 YES for each ink cartridge that was replaced.
      If 1 Yes is selected, the LCD will then display Change to new (color)? 1 Yes 2 No. Again, BE SURE to select 1 YES.
    Note "Change to new (color)?" will only appear if 1 Yes is selected for "Have you removed (color)?" If 2 NO is selected for the "removed" question, the LCD will then move on to the question for the next color.
    Oct 11, 2009 | HP Photosmart 3310 Printer
    Tried to install new toner on my OKI 5800ldn today and it keeps saying it is empty. I have cleaned the connections, restarted, shook the cartridge and nothing is working. This printer is brand new..I am...
    Does that printer require you to insert a chip?
    look in the toner box and see if there was a chip (or a card) that needs to be inserted into the printer.
    May 13, 2009 | Office Equipment & Supplies
    How to reset Black Toner Empty Message on 2430Dl
    There are many problems like that and its not recommended to change toner from one printer to another.
    but you should try: put the old toner (emty) in again, then turn off the printer, change toner and turn on printer again.
    if thats not helping, then maybe you have a old FW so you can try to update the firmware.
    Jan 13, 2008 | Konica Minolta magicolor 2430 DL Laser...
    Konica minolta 2400w toners problem
    My Konica 2430DL does this every time I start the printer, I am quite sure it is supposed to do this as I it rotating the toner and calibrating itself. On one occasion I recently had the status monitor say to install cartridge... I removed it, shook it, reinstalled it with the same results. I just purchased a new Konica brand toner, replacing the old one and 'voila' sucess! It still does the little dance (rotation) every time, but it always has, but after installing the new toner the message went away. If you reinstalled the toners, this may be your problem - you need all new toners; spendy but it should solve your problem, otherwise; if you've already done this, I don't have an answer. Good Luck!
    Dec 28, 2007 | Konica Minolta magicolor 2430 DL Laser...
    Konica Minolta magicolor 2430 DL Laser Printer Logo
    1,068 people viewed this question
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Adorjani Laszlo
    George Mclaughlin
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
